Old 01-23-2015, 02:15 AM   #1429
CSG David
CSG David's Avatar
Originally Posted by romin View Post
I thought I'd toss this data point up here given I had a lot of questions about it while it was being built.
My original engine died, broken end cap, while running laps at Cota.
It had 13K track miles on it and ran 4 months in the Texas heat with a Jackson Racing SC before blowing.
Engine version 2.0 has a Full Blown built short block (10:1), Full Blown stage 2 heads, Jackson Racking SC, and a Rev Works header.
Power feels much better but I'm still having issues with cooling on the track despite having a Koyo radiator, JR oil cooler, ceramic coating my header and over pipe, and adding a vented hood. Upgrading the fan shroud next.
Here's the power with 93 octane and VP MS 109 via a conservative track tune from JRTuned:
@romin great data. We suggest you look into getting SPAL fans, relays, and getting that fan shroud done. *Shameless plug* We stock piled SPAL fans and relays for this reason.**
Keep in mind, there is a ton of restriction with all those cores in the front of the car. The fans help pull the air through those fins and aid in cooling.
Also, we have found with a good tune and 100 octane, temperatures droped across the board despite running additional power. E85 will see additional benefits, but we proved that 100 octane alone is good enough.
Old 01-23-2015, 02:35 AM   #1430
You need fans, not a radiator. Put on some SPALs. PM me if you want a pair plus wiring (relays).
Old 01-23-2015, 03:15 AM   #1431
sw20kosh
Drives: 2013 Black FR-S
Your 270 whp dyno run AFR looks scary...
Old 01-23-2015, 06:33 AM   #1432
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by sw20kosh View Post
You could try replacing the 15 row in the kit with the 25 row. @CSG Mike has tested out my car with the 25 row at Buttonwillow: 198 F coolant and max 215'ish F oil @ 75-80 F ambient.
The downside to the 25 row is that it cools too well for the steet, especially in the winter. I have to block flow to it on the street to get oil to go above 160 F. It is worth it for me though as I have peace of mind at the track (I am there a lot). Stock radiator btw. Mike actually believes the stock radiator is more efficient at shedding heat than the Koyo.
Turbo'd at 280-300 whp.
@romin
Is that with a thermostatic adapter?
Old 01-23-2015, 06:35 AM   #1433
Calum
That Guy
Probably a problem with the dynos sensor.
Old 01-23-2015, 08:41 AM   #1434
dp1
driving smoother faster
Drives: Sold
http://www.ft86club.com/forums/showthread.php?t=70154
dp1 is offline   Reply With Quote
Old 01-23-2015, 11:01 AM   #1435
sw20kosh
Ya I have heard nothing but bad stuff about prime and Junior. I would honestly look elsewhere for a tune. PM me if you want my recommendations.
Old 01-23-2015, 11:02 AM   #1436
sw20kosh
Yes.
Old 01-23-2015, 08:00 PM   #1437
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
Mike and David, what issue were you trying to solve with the relay kit?
I've ordered a shroud from Carolina Dyno with two Spal VA10-AP70/LL-61S fans. I believe their kit plugs directly into the OEM harness.
romin is offline   Reply With Quote
Old 01-23-2015, 08:07 PM   #1438
I've ordered a shroud from Carolina Dyno with two Spal VA10-AP70/LL-61S fans. I believe there kit plugs directly into the OEM harness.
High powered fans draw more power, and need their own relay; the stock relay is only utilized as an on-off switch.
If a fan draws about the same power as stock, it probably doesn't flow much more than stock.
Even medium sized SPAL fans will blow the stock fuse.
Old 01-24-2015, 09:27 AM   #1439
dp1
Drives: Sold
To the OP, my oil/water/egt temps dropped down quite a bit once tune was fixed...you're in TX so you may need more cooling...in North East summer on track, temps looked good...JRSC, JR oil cooler, Koyo, stock hood, euro castrol edge 0w30 (switching to Motul 300V 5w30 this season)
Old 01-24-2015, 08:34 PM   #1440
romin
romin's Avatar
Was there an indicator of the tune issues in your log files?
Short of the AFR being lean under load I don't know what would point to a heat issue.
Old 01-24-2015, 10:16 PM   #1441
dp1
Drives: Sold
Yes, explained in the thread I shared yesterday, by an Ecutek master tuner
Old 01-30-2015, 03:19 PM   #1442
M23
Drives: 86
@CSG... what's your current full header back exhaust setup? Anything stock still? Stock catback?
M23 is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
