Old 07-17-2019, 11:02 PM   #1429
zachseidy39
Drives: 2014 base manual Raven FR-S
I've done my first four drift events at club loose Englishtown this past year. First two events were on the back track on the road course (and the front track at night but i sucked). 2014 FR-S. Car only had muffler delete and handbrake button.
https://youtu.be/wmbgi***Bs4
Then they had a beginner's only event on the go kart track. Car setup was the same.
Last weekend was the second go kart track event except this time i installed front camber bolts and pulled the abs fuse instead of just holding the traction control button. The car felt great and i'm definitely learning.
Car drifts great stock and i still have a lot to learn but a little angle, power and coilovers wouldn't hurt lol
Ended up snapping two studs when changing my wheels so I installed stronger ones.
zachseidy39 is offline   Reply With Quote
Old 10-15-2019, 02:03 AM   #1430
DriftinFRS
Drives: 2014 Scion Frs Whiteout
Anyone drifting with a High HP Fa20 500 HP plus?
DriftinFRS is offline   Reply With Quote
Old 11-13-2019, 05:08 AM   #1431
Shahano
Drives: LS3 Dry Sump BRZ
Has anyone had problems with the power steering stiffening up? I am using partshop max angle kit and my steering stiffens up if drifting on grippy tarmac. Not sure why this is happening. Anyone had this before?
Shahano is offline   Reply With Quote
Old 11-16-2019, 05:15 AM   #1432
elekidcircus
Drives: 13 Scion FRS
I think Im having a similar issue with fdf but im not sure
Ill be installing a new steering rack to see if thats the problem
Sent from my SM-G955U using Tapatalk
elekidcircus is offline   Reply With Quote
Old 11-18-2019, 09:36 AM   #1433
MaryDorifto88
Drives: GT86
I have the same "problem" i would say its coused by bump steer and steering radius overall.
Are you guys running spacers in front?
MaryDorifto88 is offline   Reply With Quote
Old 11-20-2019, 11:08 AM   #1434
Shahano
Hi let me know if the new rack solved the issue. Is it stock?
running 33mm spacers upfront. What is bump steer and how do we fix it?
Old 11-21-2019, 07:50 AM   #1435
Boomerang
86
Boomerang's Avatar
Love this car....
Old 11-23-2019, 01:14 AM   #1436
elekidcircus
Will do.
Yes its a stock used steering rack
Old 12-01-2019, 01:03 PM   #1437
Deezee
Drives: 2013 FRS
Just picked up a 2013 as a second drift car! Are you guys that run the PBM diff and subframe risers still having broken axle issues? Turbo, 275whp, 1”-1.5” lowered (I’m guessing)
Deezee is offline   Reply With Quote
Old 12-07-2019, 07:42 PM   #1438
Boomerang
86
Boomerang's Avatar
another shot
Old 01-26-2020, 01:07 AM   #1439
Starfox9
Drives: Subaru Brz
Love this post and am glad to have read all 103 pgs. Thanks to all involved.
Wisefab vs. Pbm angle kits, please advise???
I currently have a few sets of 18x9.5 +40 wheels with lots of 265 35 18 tires. Will either kit allow me to keep them?
And
Is it possible to I stall an abs bipas switch so I don't have to keep pulling fuse, has anyone else done it?
Starfox9 is offline   Reply With Quote
Old 02-09-2020, 04:34 AM   #1440
Eleanor
Drives: GT86
And
I can tell you that I drive with 255/35/18 tires and using Megan Racing rack ends inner tie rods which increases my angle from 17 degrees to 22-23 degrees, did you try them?
I'm thinking about purchasing drift knuckles Unicorn Angle Kit to add some more angle -I haven't got them yet as I'm using my car as a DD and I'm afraid that that having this set will convert the car to a track car =/
You can check out some of my drift the the following links
Eleanor is offline   Reply With Quote
Old 02-09-2020, 05:02 AM   #1441
Boomerang
86
Boomerang's Avatar
Nice driving! Turbo?
Old 02-09-2020, 06:48 AM   #1442
Eleanor
Drives: GT86
Yes, Efr 6758 - around 450whp, although in the video I'm driving on low boost, around 330whp.
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
