Old 03-15-2014, 05:27 PM   #1415
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Defending or not, it was a good point.
Originally Posted by s2d4 View Post
Not defending shiv at all.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 03-15-2014, 05:34 PM   #1416
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cjsporl1996 View Post
@shiv@vishnu I will begin my installation of the Vortech kit at 9am EST that I purchased from @nelsmar. Is it possible that we could talk about modifying your oft300 map to work with the MAP sensor I am using. I believe Nelsmar posted more information about the MAP a few posts back. I'm also assuming I am one of your first customers running this tune?
I have not tested the effects of MAP sensor miscalibration. Or calibrated any sensor other than the one that comes standard in the Vortech kit. So I am not even remotely comfortable with inputing unknown/untested values in the OFT300 map and sending it to you to test. Nor should you be comfortable with it. As I've been saying for several days now, I highly recommend you get the standard sensor from Vortech.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Cross (03-15-2014)
Old 03-15-2014, 05:36 PM   #1417
Kodename47
Kodename47's Avatar
Drives: UK GT86
MAP sensor changes is a couple of values in the ROM that were mentioned above. Not one single other table or value needs to be changed and it won't impact one bit how the map runs. This isn't a case of it not being tested one bit. I understand where CJ is coming from, I also understand Shiv might not be available but as he's already sent a map then he's already offered his help.
As far as I see it, having those map values changed are part of the core principles of the OFT, surely?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-15-2014, 05:46 PM   #1418
DAEMANO
Time Traveller
When writing code to release into a production environment (i.e. giving it to the users to make use of it). I would NEVER make a change (even a minor one) without methodically testing it first. That's just plain reckless. In most software & hardware development environments there are full departments devoted to nothing but Q.A. and UAT prior to any release no matter how small.
Personally, I'd deem it foolish and unwise to send out untested code (even if the change seems small) for untested hardware (the new sensor). I would also deem it unwise to try to speak for the core principles of an organization and it's products that one is not directly involved with.
Respectfully,
DAE
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Cross (03-15-2014), MagicBobert (03-15-2014)
Old 03-15-2014, 06:05 PM   #1419
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I can't get a part number...
cjsporl1996 is offline   Reply With Quote
Old 03-15-2014, 06:06 PM   #1420
s2d4
s2d4's Avatar
Wait, so he ignored your advice and proceeded to push you just because he decided to install the kit today?
The Following User Says Thank You to s2d4 For This Useful Post:
Cross (03-15-2014)
Old 03-15-2014, 06:20 PM   #1421
Shiv@Openflash
Drives: 2013 FRS
I'll try calling Vortech on Monday and will try to get that info for you.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
cjsporl1996 (03-15-2014), Cross (03-15-2014), nelsmar (03-15-2014)
Old 03-15-2014, 07:56 PM   #1422
cjsporl1996
@shiv@vishu that oft300 file you gave does not contain a file for the supercharger
stage 1
stage2 el
stage2 uel
stg2 el e85
stg2 uel e85
i believe you sent me the .dev file for 1.56
Old 03-15-2014, 08:03 PM   #1423
Foobar
SLO NO MO
Foobar's Avatar
http://iapdirect.com/omni-power-hond...FahlOgod7isADQ
They also have it on Amazon of you prefer
[ame="http://www.amazon.com/gp/aw/d/B006ID45MM"]OMNI-Power Honda/Acura K-series Plug and Play 2.5 Bar MAP Sensor:Amazon:Automotive[/ame]
Old 03-15-2014, 08:32 PM   #1424
cjsporl1996
anyone have the oft300 .dev that you can send me?
Old 03-15-2014, 08:49 PM   #1425
Shiv@Openflash
Drives: 2013 FRS
I can resend it to you this evening when I get home. I'm was pretty sure I sent you a dev file for the OFT300 map. But it's not beyond the realm of possibility that I sent you the wrong dev file.
Old 03-15-2014, 09:01 PM   #1426
cjsporl1996
Ok. Thank you shiv. On the top of your head do you know what the name of the .dev file is because the one you sent me had the same name of the 1.56 dev file.
My email is cjsporl@me.com
For the oft300 dev
Thanks again shiv I really appreciate it.
Old 03-16-2014, 12:03 AM   #1427
Shiv@Openflash
Drives: 2013 FRS
For the oft300 dev
I checked out outbox. I definitely sent you the correct .dev file. You have delete the .dev file you have in your OFT and add the one I emailed to you instead.
Old 03-16-2014, 12:12 AM   #1428
cjsporl1996
That's what I did. I'll put in a few screen shots one second
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
