Old 09-04-2014, 11:20 PM   #1415
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
I'm actually interested in the lip skirt... Appears to be cut to size stick on. Time to look for some flexible black bathroom tub surround. LOL
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-09-2014, 12:50 PM   #1416
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Originally Posted by hanabie View Post
which bayson R kit are you using? ABS or PU?
Fitment and kit's finish experience?
Did you repaint your kit?
Thanks your car looks expensive now
and yeah amazing photography skill.. if that was a start, then you should keep doing it. Dem you have a bright future ahead u :P
Ummmm.... I don't think I ever answered this. For some reason I don't get all the notifications. My bad! And thank you! Still improving my photography one day at a time. Still debating switching up cameras.
I have the PU Bayson R and I can tell you that it can take a BEATING! I did crack the front lip finally after pretty much driving the car into an elevated portion of the road from a driveway, but just bumping it into a curb while parking doesn't hurt it too much. It's got extra bolts on it, though.
The 3M tape liner for the side skirts sucks. For the price, though, it's okay to work around it.
I've left it gloss black for now while I'm still in Alaska. I might have it painted after I move. Alaska is just rough on cars in general, especially since they lay down gravel for the winter and not salt. For how often I wash my car, I think I'd rather deal with road salt, but I think a lot of people would disagree. Gravel sucks because it gets kicked up from about November through May.
Old 09-09-2014, 08:44 PM   #1417
exfortuna
exfortuna's Avatar
Drives: 14 BRZ, 93 Cherokee, 94 Ninja 250R
Originally Posted by ModalSoul37 View Post
All good bro, you don't have to go to the trouble of doing that...much appreciated tho
Hope this helps:
There are two screws you need to, uh, screw on behind each arrow. There are conveniently placed holes for these to go into behind this part of the grill. You will need to remove both layers of the underpanel to be able to screw them on. I have small hands and could not get it on through the grill, I had to remove it after trying for a long time. Make sure you note what you take off to remove the panels, I had one screw left over I couldn't find a place for
I also recommend using double sided tape along the edges of the back plate that touch the grill, as it can still wobble around with both screws on.
Once your backing plate is secure, you can snap the badge right on, there are tabs on either side. It's not hard to remove (I removed it at this weekends autocross... because of reasons).
Sorry for the potato quality photo.
exfortuna is offline   Reply With Quote
The Following 3 Users Say Thank You to exfortuna For This Useful Post:
Beyer Subaru (09-10-2014), chanomatik (09-09-2014), ModalSoul37 (09-10-2014)
Old 09-10-2014, 12:27 PM   #1418
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
@exfortuna
Thanks for the install guide! Once I get my exhaust, I'm gonna stick that badge on.
ModalSoul37 is offline   Reply With Quote
Old 09-12-2014, 06:53 AM   #1419
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Got the STI Pink Brake Pads with ATE Tye 200 DOT 4 Brake Fluid installed yesterday. The brake pads would make a noise only when the brakes are applied extremely lightly without letting go of the brake pedal in traffic (i.e. very early in the brake pedal stroke), otherwise they are pretty dead silent. The brake response seems way more than enough for spirited street driving.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
chanomatik (09-12-2014), Trap63 (09-25-2014)
Old 09-30-2014, 11:14 AM   #1420
mister.bond
Drives: BRZ Subaru
Does anybody know if these Babys will fit on the BRZ , too ?
Price is much Cheaper !
LINK 1 : https://www.japanparts.com/parts/detail/45747
LINK 2 : https://www.japanparts.com/parts/detail/45746
mister.bond is offline   Reply With Quote
Old 09-30-2014, 11:16 AM   #1421
aznatama
aznatama's Avatar
WRX Sti parts, probably not fit without adapters. Why not just get aftermarket bbk, or ts brakes?
'14 BRZ LTD MT DGM
Old 09-30-2014, 12:55 PM   #1422
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah you're asking if 2015 STI parts fit on the BRZ. We know that 2008-2014 STI Brembos will, but I don't think anyone's done anything with the 2015 STI parts yet. You can be the guinea pig.
The Following User Says Thank You to chanomatik For This Useful Post:
Trap63 (10-06-2014)
Old 09-30-2014, 07:14 PM   #1423
DSOmegaX
DSOmegaX's Avatar
2015 brakes are the same as 08-14. What that means is that the calipers are usable as long as you swap the bleeders for the front calipers. The rotors are not compatible as they are 5x114.3. You can find aftermarket rotors cross drilled for both bolt patterns
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
chanomatik (09-30-2014), Trap63 (10-06-2014)
Old 10-09-2014, 01:07 PM   #1424
mister.bond
Drives: BRZ Subaru
Thank you very much, can You please tell me where i can buy these rotors or give me a Link for
the Rotors i need ?
Old 10-09-2014, 01:37 PM   #1425
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
If you just look at the pictures, you'll see that they are dual-drilled for DBA 4000/5000:
http://www.rallysportdirect.com/2014...ce-Brake-Rotor
Looks like the STI brake hoses are back (unless I missed that they have been back).
https://www.japanparts.com/parts/detail/45774
$185 for the full set.
Old 10-09-2014, 10:40 PM   #1426
DSOmegaX
DSOmegaX's Avatar
Looks like rubber instead of the original stainless steel. Falls in line with both STi and trd recalling both their ss lines for the car
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
chanomatik (10-13-2014)
Old 10-10-2014, 02:03 AM   #1427
Poodles
Drives: 2015 Series.Blue
I never understood how they couldn't fix the lines...
Old 10-12-2014, 11:30 AM   #1428
cslntuee
Drives: Subaru BRZ Limited
What's different between these two STI strut for BRZ?
https://www.japanparts.com/parts/detail/45136
https://www.japanparts.com/parts/detail/45805
Thanks.
cslntuee is offline   Reply With Quote
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 06:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 11:30 AM
