Old 04-14-2019, 08:54 AM   #1401
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
no problem
by the way still have a few kits for sale......
Matt@Cosworth is offline   Reply With Quote
Old 04-14-2019, 09:30 AM   #1402
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Matt@Cosworth View Post
no problem
Why does going for my PhD have to be so expensive and deprive me of such opportunities?!
MS, CSCS, TSAC-F, CPT
Old 04-16-2019, 07:53 AM   #1403
Wil
Wil's Avatar
Drives: Drives like a crab.
Originally Posted by vagthomas View Post
Good day to all.
Would a cosworth kit with 35000 km be trustworthy as second hand? Is there something I should look for prior proceeding with any action? And finally is the price of 3200 euros considered normal?
Thanks for any feedback in advance guys!
Shipping from Belgium to Greece is going to be expensive, ahah ! He raised the price to 3500€ though... strange tactic.
Wil is offline   Reply With Quote
Old 04-17-2019, 03:52 PM   #1404
Matt@Cosworth
hmmm
not much more to have a new one really
Old 05-08-2019, 05:56 PM   #1405
Sylvas808
Drives: 2015 wrb series.blue brz
Looks like the kits are officially discontinued on rallysport. A few other places might have them still but if you're still in the market I'd hurry up and snag one before they all disappear.
Sylvas808 is offline   Reply With Quote
Old 05-16-2019, 08:56 AM   #1406
ajc209
Drives: GT86 Cosworth
Hola! Havent been on here a while. Ive jsut spent an hour catching up on everything! Some new owners I see - Welcome!
Mine been on the car 3.5 years and covered about 15k miles of which 8-10 trackdays (been slacking the last year) and a few drive training courses.
Smaller pulley has been on about a year and the car runs nicely in all situations, be in crusing on the motorway or hammering it at the track. Boost is up to about 0.7Ba peak now.
Weeder you are back in a 86/BRZ now?
I never installed a catch CAN after speaking to Matt about it and the low levels of blow by they experienced. My view is that adding more complexity in the form of extra pipe connections and routing when not needed it just adding and extra failure point for no good reason.
In other news I also run the Forester oil cooler now and it works quite nicely with the low temp T stat at keeping oil temps below 130C at the track.
Pic for attention
ajc209 is offline   Reply With Quote
Old 05-16-2019, 09:22 AM   #1407
weederr33
weederr33's Avatar
Pic for attention
About time you show up!
I am back in an Twin, a 2017 BRZ in particular. I'm rocking the 1.3 set up by Cosworth still.
It's great your car is running so well after nearly 4 years. BTW, have you ever taken your car on any long distance cruises? I feel like Europe would be the perfect place to do that.
Old 05-16-2019, 11:29 AM   #1408
ajc209
Probably the longest trip I have taken it is a 7 hour trip to my parents, but we stop half way so 3-4 hours at 75Mph in 25-30C heat last summer. It just plods along along with the occasional blast to please my 3 years old son LOL
Old 05-16-2019, 11:32 AM   #1409
ajc209
I feel like ive been blessed with reliability considering all the issue people have had with modifications.
Well I say that but a bleeder seized on my AP racing calipers - currently being fixed
Old 05-16-2019, 06:18 PM   #1410
pjp
Drives: frs
AP brakes
Do you like your AP brakes
I was thinking about a set
Pros and cons!
Thanks Paul
pjp is offline   Reply With Quote
Old 05-16-2019, 07:25 PM   #1411
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Longest trip I've made is 5 hours. Went mostly non-stop with no issue. I had a few problems initially but I think all of these were due to installation issues. I installed the kit myself and so there was a learning curve. I had some initial vacuum leaks and a leaky fuel pump when I upgraded it. I got those fixed and Matt helped tweak the tune a bit to dial it in. Now the car runs great. I can't really say that there are any issues at all at this point. I'm averaging 28-30 real MPG with this car.
One issue I did have was a slight hesitation while under very light throttle going uphill. I looked over the ECU log and noticed that the spot where it hesitated, it recorded 0% throttle. I know I was giving it a little bit of gas and so this did not look right. The mixture would rise lean temporarily and then richen back up...
I reset the ECU and re-did the throttle calibration procedure. Only this time I added a step I read on a WRX forum. Let the engine idle until fully warmed up before touching anything.
So turned on the ignition (KOEO) and pressed the throttle 3 times to WOT for 15 seconds. Then I started the engine and let it idle with all lights off, air off, everything. It idled for about 20 minutes and when the cooling fans finally kicked in, I shut it off. Since doing this, I have not had any issue at all with hesitation. Maybe this is just an issue with the 2016. I don't know.
sly is offline   Reply With Quote
Old 05-18-2019, 12:51 PM   #1412
gtengr
Drives: 2017 BRZ
Same here. Had a few install hiccups but it's been running like a dream the last few months. Car is very well behaved under all conditions.
gtengr is offline   Reply With Quote
Old 05-22-2019, 07:55 PM   #1413
Cosworth_0686
Drives: Cosworth ('17 BRZ, '76 Vega)
In looking into my P0171, I looked at the Fitting Instructions pdf, as I thought there was a torque spec for the bolts that hold the SC manifold in place, but it only says "fit the original manifold bolts to tighten the inlet assembly down – work across the manifold to tighten both sides down gradually"
What torque would you guys recommend?
Cosworth_0686 is offline   Reply With Quote
Old 05-22-2019, 11:48 PM   #1414
sly
sly's Avatar
https://www.ft86club.com/forums/show...postcount=1230
I tightened mine in stages. 20, 40 and then 60 fl/lb. You need to be very methodical when tightening your bolts so that you compress your gasket evenly.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
