#1401 |
i'm sorry, what?
Drives: Canada
I’ll have to disagree with you here
One should be able to drive correctly at any speed. We’ve had this problem a few years back when pulling together instructors for our schools, and a few of whom ended up being poor instructors because they had trouble driving at half pace and nailing their reference points and using too much or too little steering. While knowing tricks like aiming for inside the apex and letting the car understeer are important, they are for the advanced group. Steering input and turn in/brake reference points shouldn’t change just because you have less grip.. only the speed And one of the most important aspects of learning to drive on the track is driving within the tire’s limits.So starting out with a low grip tire will have you learn that at a lower speed. If you need grip to drive “correctly,”then you’ve never learned to drive correctly in the first place (with all due respect).
#1402 | |
Also, being consistent in your time is a great thing; you can start to see how changing one piece changes your time overall.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | nyfries (06-05-2014) |
#1403 | |
Drives: FR-S Firestorm 6MT
Learn to drive on street tires. You don't need to throw on Uniroyals to learn, but a decent street tire. Once you have gained experience, you can step up to stickier rubber. |
#1404 | |
Drives: First SWP BRZ-L
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#1405 | |
Drives: 14 FRS Whiteout
Thanks I guess I shouldn't even think about wider and sticker till next season? I'm gonna try to go to as many event as possible and sign up for at least one course. How much would you say having sticker tire would improve my time difference with other frs driver? 2 sec just for having stickier tire given that my skill level is the same? Just want to know as comparison with other ppl next time. I promise my baby to give her one big mod a year lol. I guess non suspension mods wouldn't affect my learning pace? Say like some lightweight catback? |
#1406 | |
In terms of the time difference tires will make, that really depends upon what kinds of mistakes you are making. Stickier tires are able to cover some mistakes more than others. If you are plowing into understeer going through corners then tires can give you a good boost (but without addressing the underlying issue). If you are over braking and getting out of the power band then tires won't do anything to help that. Of course there are lots of other kinds of mistakes but I think you get my point; without riding along with you we don't even know what kinds of mistakes you are making, let alone how much time you can get from the different rubber covering some of those mistakes.
#1407 | |
Drives: FRS
Reread my post. It clearly states that FOR ME , (not someone who doesn't know how to drive.) Slippery tires got in the way of ME not effectively getting accurate smooth lines to the apexes due to the car pointing in the wrong directions during controlled slides. The stock, slippery tires are a good way to learn drifting. Many instructors I have seen have had no teaching training and fail to observe and learn whether the student is an auditory, visual, or kinesthetic learner and apply the wrong teaching methods to the needs of the student, (saw that again at Mosport last week with a seasoned fast tracker and an Apex instructor). Хорошо ? ![]() CERBERUS |
#1408 | |
Drives: 2013 FRS / 2013 427 Vert
Learning on the Primacy's has several advantages. Keeps the speed down where you can focus on learning the line and hitting your marks consistently. Provides enough breakaway so you can get comfortable with corrective steering input and eventually turn off the aids. Next up will be utilizing brakes and throttle as additional steering aids as well. The Primacy tires are seriously hard and may still look pretty good although your skills may be ready for the next level so don't base that decision just on the condition of the tires.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#1409 |
i'm sorry, what?
Drives: Canada
car control is car control I sense a misunderstanding in the core mechanics and a belief that certain tires suit a certain driving style the oem tires are good for drifting because of the large slip angles... certainly a better choice than a V710 or something, but that doesn't mean you have to drive at those slip angles. you can just as easily drive within the limits of the tires and not drift, with the only consequence being a slower laptime. I did MIR, DDT and a handful of autocrosses on stock tires, my lines and attack strategies were no different than when I was running RA1s on my older cars, you figure out where the limit is and you stick to it.
| The Following User Says Thank You to 7thgear For This Useful Post: | ddeflyer (06-06-2014) |
#1410 |
Wouldn't sticking within the limit have a faster lap time than drifting all over the place
#1412 | |
#1413 | |
Drives: FRS
Your sense of a core misunderstanding is deceiving you. I sense a pre-conceived notion. You don't have to drive at those slip angles unless you are learning to drift. Driving within the limits of a slippery tire do result in slow lap times. When you figure out the limit of sticky tires you save the cost of tracking with slippery tires first. На здоровье ![]() ![]() CERBERUS |
#1414 | |||
And when they don't know what to do because they are blasting at crazy speeds and sliding through a corner as they find out the limit then what?
| The Following User Says Thank You to ddeflyer For This Useful Post: | SirBrass (06-09-2014) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
