Old 05-05-2018, 10:38 PM   #1401
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by BRZ RN View Post
are the megan racing tie rods holding up well for you? any reliability issues?
Long gone. Sold my car about 3 years ago. Plenty of other people have/currently are running them without issue though AFAIK
TylerLieberman is offline   Reply With Quote
Old 06-27-2018, 12:00 PM   #1402
Kouki86
Drives: 2017 86
I'm sure this has been mentioned before, but what is everyone doing for front clearance? Im pretty low, and i rub at full lock on the inside of the fender/frame rail. I've got Megan inner tie rods, and 17x8 +35 wheels. Running 225/45 firestone Indy 500s. Im thinking smaller tires and spacers. Any recommendations on tires and spacers?
Kouki86 is offline   Reply With Quote
Old 06-27-2018, 04:30 PM   #1403
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Spacers and camber. I run Parts Shop Max stackable spacers, goes from 15mm to 30mm in small increments
tato.valverde is offline   Reply With Quote
Old 07-03-2018, 12:56 AM   #1404
elekidcircus
Drives: 13 Scion FRS
I run 17x8.5 +30
215/45/17
With 25mm spacers
-3.0 degrees of camber
Inner tie rods and modded knuckles
I rub but i think its very minimal
Sent from my SM-G955U using Tapatalk
elekidcircus is offline   Reply With Quote
Old 08-08-2018, 09:58 AM   #1405
JoeBro
JoeBro's Avatar
Drives: Scion FR-S
Originally Posted by 6-Shift View Post
Okay, so after Saturday's event, I'm pretty sold on cut knuckles/extended inner tie rods for a cheap alternative for a "legit" angle kit. The only issue I ran into was binding under high angle and deceleration. Other than that, the quicker steering made quick transitions easier. My total investment into steering angle stuff is about $350 right now, which blows any angle kit available out of the water.
Summary, if you drift your car and don't have $1000 for the PBM stuff, go to your local drift shop and have them cut and weld your knuckles.
Looking like I'll be running more or less the same setup for my event this weekend. What exactly are you finding is binding? When I go full lock right now it looks like my sway bar end links are gonna bind but everything else seems to look pretty solid. Wondering if you found anything out about this. I've heard of people not running front sway bar but also heard a lot of negatives about that.
JoeBro is offline   Reply With Quote
Old 08-09-2018, 03:40 AM   #1406
MaryDorifto88
Drives: GT86
I also running no sway bar in the front and in the rear.
in the front, because of my modified PBM Kit there is no room for mountig the sway bar
In the rear i think i helps to give more grip, because the BC Coilovers have not that much stroke to work well when the swaybar hangs on it...
MaryDorifto88 is offline   Reply With Quote
Old 08-09-2018, 11:21 AM   #1407
cheeseburger
IG: @_southwell_86
cheeseburger's Avatar
Drives: Rwd Prius.
Thinking about making a thread about swapping in the Lexus is300 differential (welded). Anyone interested. I only ask because it seems that people really don’t use this forum.
2013 frs
I 🖤 drifting.
https://youtu.be/XW5XBQuLDUM
IG: @_southwell_86
cheeseburger is offline   Reply With Quote
Old 08-09-2018, 11:22 AM   #1408
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
2013 frs
I 🖤 drifting.
IG: @_southwell_86
Old 08-10-2018, 12:52 AM   #1409
elekidcircus
Would running that make much of a difference ?
Old 08-10-2018, 05:44 AM   #1410
MaryDorifto88
Drives: GT86
Would be super cool to see how you did it :-)
Old 08-10-2018, 08:04 AM   #1411
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
For drifting a welded differential would hugely advantageous in comparison to the stock vlsd.
2013 frs
I 🖤 drifting.
IG: @_southwell_86
Old 08-10-2018, 08:05 AM   #1412
Kouki86
Drives: 2017 86
I'm interested, I've been considering it for a while now.
Old 08-10-2018, 08:14 AM   #1413
Trust86
Drives: 2016 Halo FRS
Is it the 3.91?
Trust86 is offline   Reply With Quote
Old 08-10-2018, 08:24 AM   #1414
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
At some point today I’ll get something posted up.
2013 frs
I 🖤 drifting.
IG: @_southwell_86
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
