Old 01-21-2018, 04:26 PM   #1387
DaveyBonesJones
Drives: 2013 Scion FRS
Has anyone else broken or had issues with their diff? Mine makes a hard clunky noise at low speeds and has a bunch of play in it. It still works but just the noise is bugging me’. It’s not the axles either. I just put new ones in and the clunk is still as loud as ever.
DaveyBonesJones is offline   Reply With Quote
Old 02-06-2018, 08:16 PM   #1388
eherschend
Jesus! Just did my first event after getting the knuckle kit, solid mounts, and traction + toe rods. What a world of difference. Car is wayyyyyy more predictable and the increased angle definitely helped me from spinning out. I didn't encounter issues with the sway bar binding either.
Has anyone upgraded their sway bars? I've had a night and day experience with my s13 and I'm considering them as my next mod.
eherschend is offline   Reply With Quote
Old 02-07-2018, 01:21 PM   #1389
jlafo018
Drives: Frs
[ame]http://youtu.be/TVsQleYVKPI[/ame]
Just joined ft86club!
jlafo018 is offline   Reply With Quote
Old 02-22-2018, 09:37 AM   #1390
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Thought I'd throw a couple pictures up of how having modified knuckles looks angle wise. Just have the Megan inner tie rods and cut and welded knuckles. Current limitation is the lower control arm. Looking into modifying that with a notch or something similar next. The modified knuckles make the steering a lot heavier, and it's actually a bit nicer to drive since you don't have to use as much steering input.
NOTE: looks weird because I had 235's on the front that were rubbing everywhere and have the car jacked up. I have 215's on the front now, will try to get pictures on the ground and pictures of the knuckle itself once it's not Antarctica outside.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 03-05-2018, 08:39 PM   #1391
6-Shift
Señor Member
6-Shift's Avatar
Okay, so after Saturday's event, I'm pretty sold on cut knuckles/extended inner tie rods for a cheap alternative for a "legit" angle kit. The only issue I ran into was binding under high angle and deceleration. Other than that, the quicker steering made quick transitions easier. My total investment into steering angle stuff is about $350 right now, which blows any angle kit available out of the water.
Summary, if you drift your car and don't have $1000 for the PBM stuff, go to your local drift shop and have them cut and weld your knuckles.
Old 03-12-2018, 05:29 AM   #1392
6-Shift
Señor Member
6-Shift's Avatar
More pics, because why not. Tempted to get a print of one of the photos from this event.
Old 03-25-2018, 11:32 PM   #1393
eherschend
Anybody mind sharing there alignment specs? Here's mine for the last event. I'm going to try to ask for more caster next time I goto the alignment shop, i felt like the car didn't self steer as much as it should of.
Old 04-03-2018, 01:56 PM   #1394
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
is it the stock diff? how is your fluid?
i had a cusco 1.5 way in my s14 and forgot to fill the thing when i put it in (brought the whole pumpkin home with me from japan, drained it to save weight but forgot)
it clunked like hell for the week it survived until the ring and pinion started destroying itself on the freeway. scary shit. swapped in the stock pumpkin and learned a very unfortunate and expensive/dangerous lesson.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 04-04-2018, 06:58 PM   #1395
DaveyBonesJones
ya, Fluid is full. After having all the noise issues and checking everything in the rear to make sure it was all tight I ended up getting all of the rear end solid subframe and diff risers along with adjustable RLCA's and adjustable toe arms from PartsShopMax. Had the car properly aligned and all the noises went away.
I cannot say enough amazing things about the products from PBM. Quality and fitment is second to none. Even the alignment guy was telling me how easy they were to adjust when he had it on the rack! If anyone is on the fence about getting any of the parts they offer for our chassis, Do it! You will thank yourself!
Old 04-24-2018, 04:00 PM   #1396
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by TylerLieberman View Post
They make a solid difference for sure. Anybody buying one of these to go drifting, I would recommend these as an immediate purchase when you buy your coilovers and LCAs. Stock angle on these cars is just pitiful.
The tie rods are are very inexpensive solution and add the kind of steering angle these cars should have had from the get go.
are the megan racing tie rods holding up well for you? any reliability issues?
BRZ RN is offline   Reply With Quote
Old 04-25-2018, 07:21 PM   #1397
Jtempleton
Drives: Silver 2015 Frs
Great results these! Still had to add 30mm spacers and put a spacer in the steering rack to prevent rubbing. Lmk if you have questions.
http://www.driftknuckles.com/product...angle-knuckles
Jtempleton is offline   Reply With Quote
Old 04-26-2018, 05:55 AM   #1398
Kouki86
Drives: 2017 86
I've had mine on since January and no issues. They're supposed to be stronger than the stock ones.
Kouki86 is offline   Reply With Quote
Old 05-03-2018, 12:50 AM   #1399
elekidcircus
Drives: 13 Scion FRS
Where did you get the steering rack spacer from? My install is half way with the knuckles being installed
I need that unicorn angle
Sent from my SM-G955U using Tapatalk
elekidcircus is offline   Reply With Quote
Old 05-03-2018, 09:23 AM   #1400
Jtempleton
https://www.cjponyparts.com/steering...2004/p/HW3457/
I guess it's actually called a limiter. It take away maybe an eighth of steering wheel turn. Just have to pull the boot away and it sticks right on there.
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
