Old 12-17-2015, 03:51 PM   #127
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by PureShield View Post
If you don't lift off of the clutch pedal after putting it into neutral and just rev match is that all right?
Oh, of course it is. It's fine. Rev match after it's in the lower gear [before engaging the clutch] so your passenger doesn't get whiplash. That's all.
BTW, for those folks knocking on people learning how to drive stick from the interwebs, consider an entire generation who did not have the luxury of experienced parents to teach them proper technique.
The web can be a great resource. I, for one, will continue to do my best to be supportive and helpful to the best of my ability.
Old 12-17-2015, 03:58 PM   #128
Ultramaroon
not playing cards
Originally Posted by Anthony View Post
Yeah, I still can't heel toe well. It sucks.
It's the damn DBW and VSC. It fights you adding throttle if the brake is engaged.
I'm not sure if I'm imagining it but I started pedal dancing on my commute again and I think it kills that function too.
Try it and let me know if that seems to help you.
Old 12-17-2015, 04:29 PM   #129
The only real issue is that people trying to learn from the printed word can misunderstand. These things are something that can be shown within a few minutes but descriptions do not do them justice.
That and the fact that no two people agree on all the techniques and how, when or even if, they should be used.
I know if I was trying to learn from one of these threads I would have said "screw it" a long time ago and just went and drove my car to figure it all out on my own.
I will still try to assist people when they ask and pass on the methods I believe to be accurate and best and they can choose my info or that of the others as they so desire.
Cole (12-17-2015), Ultramaroon (12-17-2015)
Old 12-17-2015, 04:59 PM   #130
Ultramaroon
not playing cards
Amen. There is no substitute for one-on-one. Printed word leaves even more to be desired than the spoken. That's why it takes immense patience and empathy to insist on maintaining the dialog after a requester shows signs of embarrassment for "taking too much time."
In for a penny, in for a pound.
Cole (12-17-2015), Tcoat (12-17-2015)
Old 12-17-2015, 05:13 PM   #131
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Oh, of course it is. It's fine. Rev match after it's in the lower gear so your passenger doesn't get whiplash. That's all.
if the passengers head whiplashes, then it wasnt a rev match
driftartist is offline   Reply With Quote
Old 12-17-2015, 05:24 PM   #132
Ultramaroon
not playing cards
Isn't that what I said?
Old 12-17-2015, 05:29 PM   #133
Cole
Not a troll
Cole's Avatar
@Tcoat and @Ultramaroon think I've told this story many times here before, but after I got my first stick car, my dad picked it up for me while I was at work and left the keys and a note in the kitchen. The note basically said "you have a week to practice on your own, then you'll get a week with me teaching". I went out that first day, stalled, burnt the clutch, spun the tires a lot from popping the clutch and fucked up just about every way in the book. After 2 or 3 days, I got a lot smoother.
Then I went out with my dad, he drove me around for about 30 minutes showing me some of the finer points, then got me to drive. The first thing he did was instructed me to get to the biggest, steepest hill he knew about in town. Told me to pull over, park the car and shut it off. Gave me some pointers and told me to get to the top of the hill. That was a fun experience that took probably 15 times longer than it should have. (Also taught me the ebrake thing )
He never taught me how to rev match, instead he just told me to down shift a gear whenever I could, without the car jerking around too much. Worked for me for 2 and a half years.
Had I bought an MT frs, I'd probably have tried learning to heel-toe, but it's definitely not a necessary skill for the 90% of situations you'll be in when you're driving, let alone just learning to drive stick.
Edit: though, with that said, I often got lazy and did the neutral roll.
The Following 2 Users Say Thank You to Cole For This Useful Post:
Braces (12-18-2015), Ultramaroon (12-17-2015)
Old 12-17-2015, 05:45 PM   #134
Ultramaroon
not playing cards
I think it's like rolling through a stop sign. Technically, it's illegal but most people do it from time to time.
Cole (12-17-2015)
Old 12-17-2015, 06:31 PM   #135
3nl
Drives: 2015 FR-S 6MT
If you are cruising, just leave it in gear or downshift once until you are doing like 5 or 10mph - even in fourth you can still step on the gas and move for an emergency, albeit like in a Prius. Then you can shift to second without ever letting the clutch out until you are totally stopped and somebody is behind you if you are worried about getting rear-ended. Still get some engine braking, can step on the gas, and you aren't rowing through gears.
If you can't heel-toe, you shouldn't be rowing anyway since you are going to be slowing down without any brake lights - what is the point of staying in gear to have power to escape a rear end if you are slowing down without your brake lights? Either that your you will look like a fool stepping on the brakes, taking your foot off to downshift, then lighting them up again over and over...
You can be in 6th and still brake to a snails pace before the car wants to stall. Why ever roll in neutral if you are over a few miles per hour?
3nl is offline   Reply With Quote
Old 12-18-2015, 08:39 AM   #136
redfred
Drives: Red BRZ
I don't always downshift when rolling to a stop, but when I do I always blip & match.
Matching revs in this car, especially when exiting a highway, is one of the joys of ownership. So is the occasional autox and blast through country roads & hills.
redfred is offline   Reply With Quote
The Following User Says Thank You to redfred For This Useful Post:
Ultramaroon (12-18-2015)
Old 12-18-2015, 09:56 AM   #137
86kahl (12-18-2015), redfred (12-18-2015)
Old 12-18-2015, 12:46 PM   #138
Celica00
Celica00's Avatar
Drives: 86
Ideally you want to rev up the engine to the RPMs it will be at in the new lower gear, with the clutch engaged (not pushing the pedal), then shift to the lower gear. If done perfectly, the car won't lunge at all and the shifter will go into the next gear buttah smoov.
Say you're at 3,000 RPMs in 5th gear, but you want to go to 4th. If you were already in 4th gear at your current speed, we'll say that would be 4,000 RPMs. So... ideally... you would:
1. Push in the clutch pedal
2. Shift to neutral
3. Left off of the clutch pedal
4. Rev up to 4,000 RPMs
5. Push in the clutch pedal
6. Shift to 4th
7. Let off of the clutch pedal
That'll save your synchros, your clutch, and just be a cool thing to do. It takes practice, but not as much as you might expect from my 7 step instructions.
With all this leg movement to sound cool, you'd think everyone was talking about death metal drumming.
How many RPMs of give do you have when you blip? for example if I wanted to downshift into 4th and ideally that would be perfect at 4,000 RPM. Could it still feel somewhat smooth at 3,800-4,200 RPM? When practicing this, my biggest hang up is revving correctly. This could also mean i'm doing it too slowly
Celica00 is offline   Reply With Quote
Old 12-18-2015, 02:09 PM   #139
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Just to throw a spanner into the works �� What about all that wear and tear on the throw out bearing by coasting with the clutch pedal depressed?
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 12-18-2015, 03:52 PM   #140
Ashikabi
Ashikabi's Avatar
Who seriously uses a spanner? Who are you, Chewbacca?
kr-s is colorblind
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 10:59 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 07:55 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
