| View Poll Results: What Exhaust set-up should the FT come with? | |||
| Single Exhaust - 1 exit |
86 | 36.60% |
| Single Exhaust - 2 exits (2 mufflers) |
71 | 30.21% |
| Single Exhaust - Centre |
15 | 6.38% |
| Dual Exhaust |
63 | 26.81% |
| Voters: 235. You may not vote on this poll | |||
#127 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
6al-4v is Gr5...yup. What's really impressive about it are how minimal the differences are between forged and cast for component use.
Regardless, vibaration/resonance will be what causes the weld to fail, with my guess. Old Greg's idea for testing actually isn't bad. Now to keep in mind, the exhaust isn't (or shouldn't be) rigid mounted. So a flex section/bellows will allow it to wobble/swing and then is is still suspended by rubber or poly exhaust hangers. I wouldn't worry over cracks is overkill for anything behind the flew section. The exhaust manifold which is rigid mounted to the engine (a large vibrating unit) where the pipes are growing in multiple axis', that is where your concern for ti tubing weld failures should be IMO...see usage of slip joints and bellows. I plan to play with some 2xxx series alum for the catback. Probably 2024. It costs was less than ti and does reasonably well with heat. |
#128 | |
Rocket Surgeon
Drives: PSM GGA OMG
Yep, inertial and vibration as well as thermal expansion/contraction and engine movement. Slip fits are good for thermal expansion, but I'm not sure how well they do with bending. |
#129 | |
Kuruma Otaku
Because titanium. |
#130 |
Drives: '06 AM V8V Coupe
You showed me that link before
![]() I still want to try aluminum out because at temperature they're all about the same strength, and 10000 psi yield is still just as good as say nylon. Perhaps not for the bends, but for straight sections, with slip fit...maybe some reinforcement on the bottom. |
#131 | |
Kuruma Otaku
Homemade brought up an interesting point of using 2024. Stronger at high temp than 6061 or 7075. Plus the fact that there are aluminum mufflers. Could probably do a reasonably reliable axle-back with it. Problem is all the pre-bent tubing (U and J bends, etc...) for fab is usually 6061 so you would need access to a bending setup (I will need this if I do a Ti system as well...).
Because titanium. |
#132 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
it comes down to which one increases hp the most/price!
#133 |
2024 and all 7xxx are expensive, and 2024 is not very corrosion resistant due to copper content. However on Onlinemetals (among other places) you can get 6063-t52 round tube which is cheaper, weaker, but less brittle than 6061-T6. I suspect that at 500F it's probably around the same strength as 6061. Apparently 6063-t52 is easier to bend than 6061-t6, although since this is already pretty ghetto I might just reuse stock bends or get stainless steel ones.
My idea is that using a strong exhaust tube isn't the most mass-efficient way...the tube only needs to hold in the gas and sorta not deform. Using a larger number of aluminum fasteners that spread the load across a greater area of the tube should be able to cut cost and weight. Hopefully. Thin walled tube is pretty cheap so I'm definitely trying this someday, keyword being someday. EDIT: sorry 6063 only comes in 1/8" wall on onlinemetals...I probably was looking at 6061. But still on the quest to find cheaper aluminum! 5xxx would be nice since it's particularly corrosion resistant. |
#134 |
Rocket Surgeon
Drives: PSM GGA OMG
There's no point in using anything hardened for exhaust tubing. Between the welding and the high service temperatures it's all going to end up annealed anyway, so just start with T0 and make life easier on yourself.
#135 | |
Kuruma Otaku
I don't know where the '6061-T6 has bad machinability' comes from. Unless there is a major difference between the official 'T6' and the industry-common 'T-651' treatments. AFAIK T-651 is just T-6 (precipitation hardened and artificially aged) that is pulled or something, some minor cold working. I actually had a little argument with a project planner at work a few days ago about this. Worked with some 'mystery' aluminum and it was awful.
Because titanium. |
#136 |
Rocket Surgeon
Drives: PSM GGA OMG
I was thinking in terms of bending tubes. Machining-wise I love 6061-T6, other than getting built-up edges on tooling I've always found it quick and easy to work with.
#137 | |
Kuruma Otaku
Problem I can foresee is where the steel joins to the aluminum. If you want maximum weight savings it will require more more aluminum, which means closer to the engine, and hotter. Then the expansion, corrosion and vibration/fatigue stuff becomes worse. Especially at the joint. Flanges will be no-good, slip-fits I can't see working due to different expansion rates, which leaves V-bands, maybe? Properly welded 20gauge full cat-back titanium is the way to go, Serial! You get the weight benefits from less density (though more than aluminum), plus the reduced material amount from the much thinner walls.
Because titanium. |
#138 |
Gahhh too much $$$ for my cheap ass :P
I just remembered, there is water in the exhaust, and the aluminum will rot away where it touches steel, if it does at all. I think silicone can withstand exhaust temperatures at the pipe (it's good up to 600F or something), so maybe some silicone between the pipes? |
#139 |
Rocket Surgeon
Drives: PSM GGA OMG
#140 |
High enough? lol
Silicone insulation should work I think...it loses strength at 300C (er that's like what, 572F?) but probably won't go up in flames until well above that (I hope) It's used in cookware, and doesn't explode into flames upon contact with an open flame so...
| ft 86 exhaust | dalli | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-08-2010 10:16 PM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
