#127 | ||||||||||
Radio wiring harness guru
Drives: 1996 SVX L AWD
Most LOCs are "passive" -- they don't require any power for the LOC function. But there is a small chance that yours is "active" (contains powered components for the audio circuits). The amp trigger circuit definitely requires power to work (but you don't need that feature). Quote:
Since it's a 5-channel amp, you could even use it to power your door speakers instead of the tiny OEM amp. Just be sure to start out with the Alpine amp's GAIN knob all the way down, and turn it up slowly. ![]() If you do that, you could use a regular Toyota harness (the type normally used to install an aftermarket HU -- Metra 70-1761, Scosche TA02B, or equivalent -- should be easy to find one locally). Then you won't need to splice into any factory wires. You should re-pin it so the wire colors are in the appropriate pins for their functions (e.g., WHITE wire into 10-pin pin #3, for Left Front Positive. Re-pin the 4 GREEN and VIOLET wires into the pins for the outputs to the door speakers). [ADDED: See this thread: How to use the OEM amp Wiring]. Connect things as follows:
You can use the amp's CROSSOVER knobs to free the door speakers from trying to reproduce the lowest frequencies (which may make them perform a little better). Quote:
#128 |
Drives: 2014 Scion FRS 10 Series
Just a bit of info... I see the RCA wires run with the power. This is never a good idea, the reason is the magnetic flux you get off of the power wires really plays havoc with you sound signal. Even a good twisted pair of RCAs will be effected in the long run. Best thing to do is run the power on one side and the audio on the other side of the vehicle.
The other thing that could happen is say God forbid, but you have a short in the main power wire you will not have to worry about it buring a hold in to your RCAs and shorting out the inputs on your amp. A short to ground is bad too, but most amps have fuses there to protect themselves, but not in the RCA side of things. Just something I noticed a lot of people don't think about or know when they run the wires for the Subs. That and I never like to see anything bad happen to our babies Take care, Jay F.
2014 Sc10n FRS 10-Series #655 of 2500 ![]() |
#129 | |
Drives: Scion FR-S 10 #853
You are absolutely right, in my case though the power is the only line run to the front of the car. The RCA go to an adapter spliced into the amp directly below. They just look like they're run together, but really just end up in the same place. Good tip though.
| Subwoofer prewiring | Nate219BRZ | Electronics | Audio | NAV | Infotainment | 3 | 09-09-2013 06:56 PM |
| Adding a sub enclosure yet ? | rikdrt1 | Electronics | Audio | NAV | Infotainment | 10 | 06-08-2012 10:28 PM |
| Adding navi to FRS | Pake1 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 06-04-2012 11:14 AM |
| Does BRZ and FRS come with a Subwoofer? | R0ME0 | FR-S / BRZ vs.... | 6 | 05-07-2012 03:54 PM |
