Old 07-22-2017, 11:42 AM   #127
Colin86
Drives: 86
Those with magnetic mounts like Scosche, can they be trusted to hold the phone through track duty? Wanting to utilize my phone for bluetooth/ODB gauges during track days but wasn't sure if the magnets were strong enough to hold through track driving...
Colin86 is offline   Reply With Quote
Old 07-22-2017, 01:02 PM   #128
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I haven't had an issue with mine, it sticks pretty well. I have the metal plate behind a thin case as well. My phone is fairly light though.
Old 07-22-2017, 02:25 PM   #129
Colin86
Drives: 86
Have you had a phone mounted during track events?
Old 07-22-2017, 05:30 PM   #130
Andrew025
Andrew025's Avatar
Yes
Old 07-22-2017, 06:11 PM   #131
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yes
Yeah but you only do parade laps.
Andrew025 (07-23-2017)
Old 07-23-2017, 12:52 AM   #132
Andrew025
Andrew025's Avatar
This guy...
The Following User Says Thank You to Andrew025 For This Useful Post:
Ultramaroon (07-23-2017)
Old 12-14-2017, 09:53 AM   #133
ermax
ermax's Avatar
I just did this yesterday.
I'm sure everyone has seen mounts like this before. It has a ball joint so it pivots and uses magnets to hold the phone. You put a thin sheet of metal behind your phone case to attach it to the mount. What I like about this version of the mount is it has a screw in the bottom center that attaches the base to the ball. I am going to get a slightly longer screw and a washer so I can hard mount it to the dash and not have to rely on adhesive. I spent a bunch of time on Amazon trying to find a mount which had a threaded hole for hard mounting. I looked at user photos and read reviews and none of the mounts seemed to have a hard mounting option so I gave up and picked this one somewhat at random. I was happy to find out it does have a way to hard mount.
Here is the link if anyone is interested:
http://a.co/adSt1e9
So far I haven't been able to shake the phone off this mount. I have an iPhone 7 with an Apple Silicon case. The silicon seems to help it grip the rubber mounting surface of this mount so it doesn't slide around on the mount at all.
Old 12-14-2017, 11:14 AM   #134
TommyW
TommyW's Avatar
Drives: '13 Whiteout
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-14-2017, 11:44 AM   #135
ermax
ermax's Avatar
Originally Posted by TommyW View Post
Thought about something like that but then it blocks the screen and mounting/dismounting isn't as simple as a magnet. I also like the low profile of the magnet mounts.
Old 01-06-2018, 03:41 AM   #136
neilr
Drives: 2018 Cayman, 2013 FR-S
Originally Posted by westendRIOT View Post
Arkon makes several of these mounts: 15, 18, and 22 inches. Do you recall the length?
neilr is offline   Reply With Quote
Old 01-06-2018, 07:53 AM   #137
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I have the 18" mount.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
neilr (01-06-2018)
Old 01-06-2018, 01:13 PM   #138
neilr
That looks nice and clean. I notice that you don't have the arm tied down to anything - is it fairly stable? Some of the Amazon reviews indicated a lot of vibration while driving (as opposed to the flexible section drooping).
Old 01-06-2018, 02:48 PM   #139
churchx
churchx's Avatar
Drives: 2014 GT86
Nice & clean .. except if one drives on track with passenger. I think that this way of mount may interfere if knee is pushed against pad & this mount over it when passenger secures his position to be more stable for side-Gs.
Also if using this mount .. imho it's worth to attach charging cable with zip-ties or alike to mount arm, for less clutter/neater looks. (and connect charging wire to cig-plug adapter in glove-box).
Old 01-06-2018, 03:53 PM   #140
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yes, that might be an issue for the passenger...I don't have that problem but someone might. As for the cable, that pic was from when I was using OFT so the cable now is just a thin USB charge cable but I like your idea about securing it to the mount arm.
Initially it was "stable" but after bumping into it once or twice, that was no longer the case. I ended up pulling the knee pad and finding a spot to hook a zip tie, then daisy chaining another zip tie to that to go around the arm as seen below. This setup has worked well over the last 2 years, no vibration or movement whatsoever.
neilr (01-06-2018)
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 04:28 PM
Is it possible to use a phone as a BRZ key? Killianti Electronics | Audio | NAV | Infotainment 19 08-13-2014 05:55 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 03:36 AM
Let's talk phone mounts l0aded Electronics | Audio | NAV | Infotainment 41 06-14-2013 01:53 PM
Phone app. DanoFA20 Site Announcements / Questions / Issues 6 10-23-2012 12:55 AM
