#127 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#128 | |
That said, the RCE lowering camber plates would certainly make life easier (hey...TIC has some in stock right now!) but yeah that's not cheap. I will say this...and it's not sales pitch I promise. The 400 lbs/inch custom valved Bilstein shocks I just rode on in a beast-mode supercharged BRZ were very comfortable. Baltimore City daily driveable. Exceeded my expectations. That car kicked ass and had a decent drop (30mm -ish). The firm spring rates help with the limited travel, but the valving has to work with the rates. My point is that the potential is there for a good all around set-up. It sounds like you're very close. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Markiv (03-05-2016) |
#129 | |
Should we be looking into roll center correction kits too? That worked wonders on my Impreza. |
#130 | |
Drives: GBS BRZ
#131 |
Drives: 86
Thanks for the replies on my question.
Seems that swapping out springs is not as simple as it looks! |
| The Following User Says Thank You to Dihudaxia For This Useful Post: | JoeHK (03-05-2016) |
#132 | |
![]() - Andrew |
#133 |
Drives: 22 GR86, 13 FR-S, AP2 S2000
I've been using a custom valved set of Bilstien PSS with 672 lb/in (12kg/mm) Swift springs (7" - 70mm ID) for years now on my S2000. The shocks and valve job are literally 6 years old now with years worth of track events on them and they still feel good as the day I bought them.
The revalve was done by the Bilstein Service Center down in SoCal. They were very good about recommending valving specs to the springs I wanted to run and the manner by which I would be using the shocks. Edit: In the interest of full disclosure, I've only put about 20k miles in those 6 years since the rebuild. But those are some of the hardest 20k miles one could put since a several thousand of those miles represent back and forth to various tracks around NorCal and the track time that came with it.
A. Miracle #013
TunerCloud 86 Go Fast Parts Last edited by AyJay; 03-06-2016 at 04:42 PM. |
| The Following User Says Thank You to AyJay For This Useful Post: | strat61caster (03-06-2016) |
#134 | |
I mean I am running Impreza Group-N top hats right now! |
#135 |
Alexandrino_Auto
Drives: series.Blue
[ame="https://www.youtube.com/watch?v=MHyVoiP0o_8"]Scion FR-S / Subaru BRZ | Comparing OE vs Bilstein vs FCM dampers, v2.38 - YouTube[/ame]
I'm shocked (pun intended) that Tein measured a difference between FRS & BRZ shocks, considering the cars share part numbers. I'm guessing their measurements could be attributed to variation in manufacturing, or a failure to test shocks from the same model year, considering the 2015 change from Showa to Sachs. Unless there's something I don't know... Also, as per FCM's contestant recognition of the importance in considering motion ratios and cycles for flat ride, it continues to baffle me as to why people try to spring this car equal rates front & rear.The car in this video is basically running 5.8k F & 8.9k R
The Shadetree Project: I turn wrenches
#136 | |||
![]() Quote:
Real motorsports engineers don't give too much of a shit about flat ride. There I said it. lol. I've heard that from TONS of engineers that are "in the business." OptimumG for example: Quote:
There is no magic formula for setting up a vehicle. Your rear wheel drive car shouldn't be tuned the same as a front wheel drive or all wheel drive car or a car with double wishbones all around, etc. The specific rates you mentioned may work well on a BRZ with no rear bar and a large front swaybar. That has it's own compromises. - Andrew |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | Captain Snooze (03-12-2016), Hyper4mance2k (03-07-2016) |
#137 | |
Alexandrino_Auto
Drives: series.Blue
The freeways out here are like glass compared to SoCal, but the surface streets are a nightmare in comparison. Compromises everywhere. If you've ever driven the 405S in LA you realize how damn important flat ride can be. A stock twin at speed on the 405 feels like the street is paved with ruffles.
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | Racecomp Engineering (03-07-2016) |
#138 | |
I loled at "paved with ruffles". That sounds about right. Baltimore city is a just a car destroyer. Most of our highways aren't terrible, but regular streets even in the nice suburbs can be miserable.- Andrew |
#139 | |
Alexandrino_Auto
Drives: series.Blue
#140 |
FYI I'm getting an occasional loud "ping" from the front springs, like they are popping back into place or something. Usually when going over speed bumps/curbings (round curb on my driveway) and sometimes when turning. It only happens once though and stops... I'm thinking the springs are too low now and they aren't compressed at all when at full droop?
| **NEW**Bilstein B8 HD Struts and Shocks Released | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 118 | 09-12-2016 02:54 PM |
| Bilstein B6/B8 and B14 shocks setting | Mars2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-26-2014 11:24 PM |
| Swift Spec R with Bilstein B8 shocks? | JMoore412 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-23-2014 02:52 PM |
| Bilstein shocks & struts | Fizz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-31-2013 03:56 AM |
| Bilstein Shocks | wahsaihin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-23-2013 04:12 PM |
