Old 10-22-2022, 06:38 PM   #127
redlined600
redlined600's Avatar
Drives: Fr-s
Received enough parts to get started mocking up the oil pan. I also bought an additional subframe so I can do most of the work outside the car.
Old 11-12-2022, 04:31 PM   #128
redlined600
Drives: Fr-s
Current baseline weight with 1/4 tank of gas, no driver. Hoping for at least 50lbs weight loss from the swap. It would be nice to get some weight off the nose.
That puts the current P:W at 13.9
Old 11-13-2022, 08:46 PM   #129
redlined600
Drives: Fr-s
I've been struggling with what to for brake pads a little. I really like the Project Mu Club Racer but they wear really quick. I tired hawk DTC-60s, they were ok but seemed to wear faster than the Club Racers.
My Friends got me hyped on the Raybestos ST-43. They claimed good feel and long life so I ordered a set (that's a whole other story).
I tried them at BHF and was not impressed but also confused as to what was going on.
-First session was damp and the brakes felt fine.
-Second session was dry and the pads felt like they were starting to fade part way through the session, bad enough that I cut the session short.
I talked to the supplier and he was in disbelief that I could have faded the pads on such a light car (compared the the vettes and camaros he's used to).
Which leads me to this. I came across thermocouples that can be inserted directly into the pads. Between this and rotor paint I will have a pretty good idea of what is going on with my brakes.
Additionally I've started tracking wear so I can be objective about how much each pad is actually wearing. (I really wish I would have done this years ago)
Old 11-13-2022, 09:04 PM   #130
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
FWIW rice_classic runs a 47/43 stagger on his T4 race car and swears by them. I bought 47's for the front and 45&47 for the rear of my car to try. Love the CSG pads, wanted to try something else.
Old 11-13-2022, 09:31 PM   #131
redlined600
Drives: Fr-s
Interesting, LPI talked me out of the 45s.
Much like the PF08s, I'm doubtful that I will get double the life out of CSG pads to equal double the cost.
I'm also going to stick a thermocouple in the rear. Given the lack of wear I'm almost questioning if they actually get up to temp.
Old 11-13-2022, 09:54 PM   #132
Pat
Pat's Avatar
Drives: 2023 BRZ
Great discussion.
Old 11-14-2022, 12:25 AM   #133
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Much like the PF08s, I'm doubtful that I will get double the life to equal double the cost.
Strange, I talked with Porterfield Brakes when ordering and they thought the 47's with less rear pad would be about right. rice_classic thought the 47's on the rear will be way too much. He was getting a bit of rear lockup on Hosiers with 47/45. My setup isnt far off yours. Wing, splitter, T2's.
The thermocouple for the pads is super cool.
Old 11-14-2022, 10:51 PM   #134
redlined600
Drives: Fr-s
I usually run on 200tw tires.
Here is the friction chart from Raybestos, looks like the ST-43 starts falling off around 1200f while the St-45 might hang on a little longer.
DTC-60s are rated to be pretty stable past 1600f, and I never experienced fade from them.
I couldn't find a chart for the Club racers but I've never felt them fade. They claim they are good up to 1400f
Old 11-14-2022, 11:29 PM   #135
Pat
Pat's Avatar
Drives: 2023 BRZ
DTC-60s are a common favorite amongst 86 CUPers here.
Old 01-05-2023, 11:20 PM   #136
redlined600
Drives: Fr-s
Small update:
Ordered an ATI damper and it showed up damaged so I need to order a new one.
Got the water neck installed.
Santa delivered with a new passenger seat.
I hesitate to post this since my welding is such shit but whatever. First pass at the oil pan is done. The rear turned out fine and fits nice around the subframe but I'm not happy with the bump out and am planning to cut it off and re-do it. I think I was too conservative and could probably add almost another half to a full quart by adding some space to the front and using a smaller angle between the main pan and the bump out. I have a little time since the electronics package hasn't shown up yet anyway.
Old 02-15-2023, 06:47 PM   #137
redlined600
Drives: Fr-s
Not much progress on the swap lately due to the cold but in other news...
Big boy rollers on the way!
Old 02-15-2023, 11:19 PM   #138
clu
Drives: 2013 Subaru BRZ
https://www.facebook.com/visionspeed...fknJZmSVnRGzul
Would really love these in 17x9. Don't need much more for my racecar larping
clu is offline   Reply With Quote
Old 02-16-2023, 10:47 AM   #139
gt5759
Drives: 2017 BRZ
Thats excellent news! about time someone decided to do a 17x10 in the 5x100 and at a good price.
gt5759 is offline   Reply With Quote
Old 06-18-2023, 05:13 PM   #140
redlined600
Drives: Fr-s
Due to my lack of time and a mix of life events, the swap is on pause for the summer. I'm basically doing the minimum to be able to run a few events this summer and will hopefully pick back up in the fall. I have 95% of everything I need to complete the swap and the exterior of the oil pan is complete, leaving only the baffling before I can button up the engine.
Now on to better news.
ARP wheel studs installed in anticipation of new wheels.
17x10s showed up with 255 RE71RS
On the car.
The rear fits perfect with a 8mm spacer and the front fits pretty good but needs steering rack limiters to be safe, those are on on the way
Through assessing the clearance I noticed that I really don't have much shock travel in the front. I sent out an email to Racecomp asking if I have headroom to shorten the bumpstops. My assumption is yes but I'm not interested in damaging the struts. Then it becomes a balance of how much ramp rate from the bump stops I can accept.
I also pulled out 6lbs worth of unused brackets, door speakers, ect.
One of these things is a racecar, the other is fast.
The Rebirth of an Italian FlowForm_Wheels Other Vehicles & General Automotive Discussions 16 06-01-2014 11:46 AM
Trackday GPS Recommendation milhouse Tracking / Autocross / HPDE / Drifting 12 03-24-2014 12:19 PM
Trackday at ORP jblmr2 Northwest 6 02-21-2014 05:30 PM
2nd trackday in FR-S icemang17 Tracking / Autocross / HPDE / Drifting 4 09-24-2012 04:40 PM
1st trackday in FR-S icemang17 Tracking / Autocross / HPDE / Drifting 10 09-01-2012 10:02 PM
