Old 09-28-2015, 02:11 PM   #127
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by sales@delicioustuning.com View Post
Aaron,
I forgot you'd been tuned by Church! Typically we setup our Flex Fuel tunes to read ethanol content through "Custom Map P Result". More than likely, Shawn has his setup on a different custom map. Your best bet is going to be to ask Shawn which map he setup ethanol content to read through so you can view ethanol content.
When our App displays "-.-%", that typically means the Bluetooth device is not properly connected, or that Bluetooth has been turned off. In the event of a failure, the app would actually resort to reading a flat "0.00%", and your vehicle would run best on 91.
Hope this helps!
Sincerely,
Zach
It was in Custom Map A Result. Whew. Box is all good. Thanks again Zach!!
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
Old 11-06-2015, 10:42 AM   #128
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
So...its getting toward the end of the year. How's the iPhone app coming?
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline   Reply With Quote
The Following User Says Thank You to quicksilver30 For This Useful Post:
Deadpool_25 (11-06-2015)
Old 11-11-2015, 12:02 PM   #129
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
It's coming! We fully intend to keep you all on the edge of your seats until December 31st at 11:59 pm
In other news!
Now through the end of the year we're offering 5% off on the purchase of a Flash & Go/Innovate/NA tune + our Flex Fuel kit. This can also be combined with an EcuTek License and/or EcuTek Cable Kit. Use coupon code DT-COMBO-5 at checkout. Enjoy and happy holidays!
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
FRS Justin (01-04-2016)
Old 11-29-2015, 04:55 PM   #130
DeliciousTuning
In other news!
Sincerely,
Zach
We also have a not so known 10% off coupon through the end of today on all Flex Fuel Kits. DT-BLKFRI
Cheers,
William Knose
Old 12-18-2015, 08:34 PM   #131
HaloFRS
Drives: 2020 Subaru BRZ Limited
So i just finished reading through the whole thread. I was checking your guys website and quite confused. So how much would it cost me for the FFBT kit plus the tune for NA. (No ECUtek license or cable yet) And how much would it cost if i get a retune for a header. I also haven't seen dynos of a e85 NA Stock. On your site it just shows the 91 oct dyno. Thinking about gettng this when i get back from my deployment. I just want to research everything before hand. Thanks @DeliciousTuning!
HaloFRS is offline   Reply With Quote
Old 01-04-2016, 03:06 PM   #132
DeliciousTuning
I can't give quotes over the forum here, as it's against the rules. If you'd like, send me an email over to sales@delicioustuning.com.com. I'd be happy to give you a complete quote there!
PS - Apologies for the late response, we left on the 18th for the holidays and just returned.
Sincerely,
Zach
Old 01-18-2016, 10:08 PM   #133
DBee
That Guy
Drives: 2013 Scion FRS - Whiteout
Any update on the iPhone app yet?
DBee is offline   Reply With Quote
The Following User Says Thank You to DBee For This Useful Post:
quicksilver30 (01-20-2016)
Old 01-28-2016, 01:35 AM   #134
FT86RGV
@sales@delicioustuning.com Just yesterday a similar thing happened to me. When connecting to the Bluetooth with the app. I get the following -.-%
I checked custom map p and it is working correctly. is there a way to fix the problem with the app. I uninstalled and reinstalled it. I check the connections to the black box and everything seems fine. I actually do use the app a lot in the winter. Since the lowest temps we see are usually in the 40s I try to keep ethanol % between 70-75%. I'm usually able to start the motor at first crank that way. We consistently see 80% at the pumps here so I do have to monitor the app and add necessary amounts of 93 to keep that ideal percentage for max power and ability to cold start.
FT86RGV is offline   Reply With Quote
Old 01-28-2016, 01:41 AM   #135
FT86RGV
posting pic just for the sake of it.
Old 01-29-2016, 01:39 PM   #136
DeliciousTuning
Hello,
Please send me an email at sales@delicioustuning.com.com to get this issue resolved as quickly as possible for you.
Sincerely,
Zach
Old 02-03-2016, 11:46 AM   #137
Yoda
Drives: Crystal Black BRZ(Sophia)
So about that iphone app...
Yoda is offline   Reply With Quote
Old 02-08-2016, 09:57 AM   #138
enivid
enivid's Avatar
Drives: WRB JR BRZED
What's the minimum ethanol content before the advanced timing kicks in?
enivid is offline   Reply With Quote
Old 02-08-2016, 01:39 PM   #139
DeliciousTuning
We start advancing timing at just over 10%, which is pump gas for most states.
Sincerely,
Zach
Old 02-08-2016, 03:43 PM   #140
enivid
enivid's Avatar
Sincerely,
Zach
Is it possible to get a custom tune where it stops advancing timing at a certain ethanol content? So E85 would produce the same whp as E40 if the timing stopped at E40?
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
