Old 12-14-2014, 07:17 PM   #127
s2d4
s2d4's Avatar
I'd love to see one post out of your that isn't a sarcastic asshole commenting.
I'd love to see a post out of you that is helpful and contributes to the forum, not negates it in every factor.
Every post from you is negative. It's just damn old now. I don't give a shit about your experience if you're gonna wear the crown with no pants on.
Sorry for your butt hurt and stalker antics.
I wasn't born on this earth to help morons.
Old 12-14-2014, 07:18 PM   #128
FirestormFRS
Sure hope you didn't spend the day reading all 2383 posts!
FirestormFRS is offline   Reply With Quote
Old 12-14-2014, 07:22 PM   #129
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Typical, another leader to infinity. Useless.
What you have in knowledge, you lack in being human.
Old 12-14-2014, 07:25 PM   #130
s2d4
s2d4's Avatar
Good for you.
What you lack in being human, you lack in knowledge.
Being a dumbass is pretty far from my life ambitions but some people just can't help themselves.
Old 12-15-2014, 12:00 AM   #131
KoolBRZ
KoolBRZ's Avatar
:offtopic::threadjacked::bs:
Old 12-15-2014, 12:16 AM   #132
Koa
If someone spends money building a high rise out of tissue paper, would you also thank them for spending money and showing you that it doesn't work?
THIS TIMES A MILLION.
Old 12-15-2014, 12:20 AM   #133
R2
Originally Posted by KoolBRZ View Post
KoolBRZ, I for one am at least happy you are out there swinging your bat. Regardless of results, I wish more people would try out random ideas and see where they go. Lots of us don't do this, but instead we sit around and get our jollies by bantering online.
Quick hunch to pass along before I exit this thread - next time try doing dyno pulls at much less than full throttle. I suspect your A/R modified header will show low rpm torque gains under those conditions vs an unmodified header.
R2 is offline   Reply With Quote
Old 12-15-2014, 02:06 AM   #134
KoolBRZ
KoolBRZ's Avatar
Thanks for the words of encouragement.
Thank you. I did learn something from the comparisons. Look at the comparison of stock tunes, pictures 1, 2, and 3. The un-modified header performed really badly because there wasn't enough back-pressure for the stock tune. This car comes with such a restrictive exhaust that the stock tune has a lot of valve overlap. Shiv has tuned that overlap out of his stage 2 tunes because they are for headers and more open exhausts. I believe now I might make better power from a stage 1 tune for 91 Octane with the 0420 error turned off. I'll have to load one up and try it tomorrow. Thanks for the words of encouragement.
Old 12-21-2014, 10:32 PM   #135
KoolBRZ
KoolBRZ's Avatar
Could it be more low-end torque?
I worked on my exhaust today because the over pipe was rattling on the sub-frame. I also wanted to switch out the 2.5" catless front pipe for the stock catted pipe to see what it would do for power and MPG. Wow, what a difference. Starts quieter. Takes less throttle to accelerate, (as seen on the OFT as throttle %). Could it be more low-end torque? I don't know, but it sure feels like it. Because I'm using less throttle to accelerate, my city MPG has gone up. I'm going to give it a week to evaluate the pros and cons and decide whether or not to change it next weekend. The extra power could also be caused by the flange on the over pipe at the header. I mounted it slightly crooked to get more clearance over the sub-frame. That edge could be reflecting pressure waves back up the header primaries. I should probably straighten it out next week to eliminate that possibility.
Old 12-22-2014, 02:03 PM   #136
Ris
Ris's Avatar
Drives: 2013 Whiteout FRS
Send a message via MSN to Ris
whenever my flanges were a bit crooked i just slightly loosened the nuts and gave it a few hit with a rubber mallet and it lined right up.
Ris is offline   Reply With Quote
Old 03-28-2015, 03:33 PM   #137
Koa
I'm reviving this thread to see where you're at on this @KoolBRZ
Old 03-28-2015, 04:21 PM   #138
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Nooooooooooooooooooooooo.....
Old 03-28-2015, 04:32 PM   #139
KoolBRZ
KoolBRZ's Avatar
Here's where I'm at with this. The dyno pulls showed there is a consistent loss of about 5-10 hp with the modified header over the unmodified header. I had the unmodified header coated and installed it. I now have a partially stripped head stud and an exhaust leak. Power is not what it should be, and the leak interferes with the MAF scaling I need to do to compensate for a Skunk2 intake without insert, (about 3.125" wide). I found just recently however that the VVT is the way to compensate for changes in back-pressure, not by welding in inserts. I changed my AVCS intake and exhaust safe tables to match @mad_sb's safe IAM1 tables after reading the AVCS tuning thread you started. VVT changes not only valve timing, but lift and cylinder fill % as well as compression ratio. I think it is the single most important change to make with our ECU's and yet so little is known about it.
Old 03-28-2015, 05:06 PM   #140
Dipstik-sportech
Dipstik-sportech's Avatar
So in the end what everyone told you ended up being true. It wouldn't work and you wasted your time.
guy knows nothing, world's last, zero facts
Wtb ft86 uel header 86socal Want-To-Buy Requests 1 08-23-2014 09:00 PM
Anti A-Hole Button ButtonMasher Off-Topic Lounge [WARNING: NO POLITICS] 45 07-25-2014 12:55 PM
Eibach Anti-Roll Kit babykwiss Canada Classifieds 1 07-14-2014 09:29 AM
Fastest FT86 in the World 9.10@256km/hr! Bahraini86 Forced Induction 94 02-19-2014 12:25 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
