Old 08-14-2015, 01:38 AM   #127
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by sissupr View Post
Awesome. Now plan on 8h of bitching putting it in... lol. Good stuff..
What did you make on the 3.125 pulley on ethanol?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-18-2015, 08:44 AM   #128
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I did 349whp on E85 with the 3.125 pulley. Here's the link:
http://www.ft86club.com/forums/showp...&postcount=335
Tye300 is offline   Reply With Quote
Old 08-19-2015, 10:10 AM   #129
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Is anyone running a perrin oil cooler or any other T-stat oil cooler with the Vortech kit during cold winter(snow days)? I live in NJ & PA and it is really cold here in winter.
I know that the perrin oil cooler is T-stat, and the oil should not flow to the cooler until the temp reach 185F. However, is it actually work that well in real life?
A simple question is: Will the engine heat up as fast as a car without oil cooler?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 08-19-2015, 04:13 PM   #130
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Simple answer, yes. It works just like your radiator.
bee_are_zee is offline   Reply With Quote
Old 08-23-2015, 01:55 AM   #131
Dezoris
Dezoris's Avatar
Even with the thermo plate there is a trickle flow to oil cooler to prevent air lock. So in winter it takes 2-3x a long to get up to temperature and when that cooler is in clean cold air it wont allow temps to get much above 165F during normal driving.
The Following User Says Thank You to Dezoris For This Useful Post:
Figo (08-23-2015)
Old 08-23-2015, 01:58 AM   #132
Figo
Figo's Avatar
Thank you.
So it might be better to get 2 plugs from home depot and disconnect the pipe I think...
Old 08-24-2015, 01:54 PM   #133
Dezoris
Dezoris's Avatar
Thank you.
This is what I did in Winter:
Figo (08-24-2015)
Old 08-24-2015, 02:02 PM   #134
bee_are_zee
Drives: GBS BRZ
Huh. Thanks for the info, I apologize for being misinformed. I'm running the forester factory cooler so it doesn't really matter all that much.
The Following User Says Thank You to bee_are_zee For This Useful Post:
Figo (08-24-2015)
Old 08-26-2015, 03:15 PM   #135
Figo
Figo's Avatar
Can you tell me where did you find those two blue plug?
or can you share the info of the thread size with me?
Old 12-26-2015, 05:39 PM   #136
Foobar
SLO NO MO
Foobar's Avatar
Went through my first belt replacement this weekend - original one was starting to squeak quite a bit and figured it was time to replace it. Based on the original post, I got a bunch of the Gatorback 4060970 (replacement for K060970) at like 5 bucks each on Amazon. Figured I might as well stock up at that price in case I needed more later.
I've got the original pulley (3.48 I believe) and I'm not sure this belt is the right size - has anyone managed to get it on with the original pulley? I know that the original configuration called for the K060975 but I believe since belts were getting trashed, they started going with the K060970. The difference between the two is a little more than half an inch.
For reference, I'm trying to slip it over the alternator pulley as the last move while fully detensioning (that's a huge pain in the ass by the way). I was hitting the limit on the detensioner and there's just no way to squeeze that belt on the alternator.
Maybe I'm doing it wrong?
Edit: I've given up - with the detensioner fully open, there's simply no way that the K060970 is going to fit on there. I tried from the alternator as well as from the smooth pulley by the AC. I'm going to have to go back to the K060975. When Vortech made the switch to the 97 inch belt, perhaps that was only meant for the upgraded pulleys and not the standard 3.48".
Edit2: The 97.5" belt went on without a problem. I guess the 70" is for the smaller pulleys, if you're on the base 3.48, stay with the 97.5" belt. Using the Goodyear/Continental Gatorback 4060975.
Old 12-29-2015, 02:28 PM   #137
Cal3000
Drives: Panda FR-S
When I was changing my belt, I had one hell of a time getting it over the alternator. For me, it was easier slipping it over the blower pulley. I had an extra hand with someone holding the tensioner pulley while I slipped it over the blower pulley. I used the Autozone 3.8 Genesis belt. I forgot what the part number was.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 12-29-2015, 02:31 PM   #138
Foobar
SLO NO MO
Foobar's Avatar
Vortech Supercharging - FAQ and Notes
Thanks, that would be the 97.5 inch belt which is what originally came with the Vortech. I ordered a couple of them and will put it on tomorrow.
The Following User Says Thank You to Foobar For This Useful Post:
Cal3000 (12-30-2015)
Old 12-29-2015, 07:53 PM   #139
DJCarbine
Thupercharged
DJCarbine's Avatar
I usually cheated on my belt swaps, I would undo the idler pulley next to the blower pulley and get the belt all slipped on, then bolt on the idler pulley. The change in angle of the belt causes it to be "shorter" when you try and slip it on a pulley. If the pulley is off, the belt can be properly aligned and then you just thread the pulley in while you have the auto tensioner released with your wrench. I ziptie the wrench to the bracket vortech has you bolt on that comes off the supercharger bracket and onto the timing cover area so I don't have to fight the tensioner.
I also want to say I removed the dipstick tube to gain more clearance for the tensioner/wrench, but its been a while
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
Old 06-15-2016, 07:02 PM   #140
MattHoffman
Drives: BRZ Limited
So is there two ways to hook up bypass valve?
MattHoffman is offline   Reply With Quote
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 12:45 PM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 04:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 02:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
