Old 09-11-2015, 02:12 PM   #127
JS + BRZ
Drives: 2010 MS3
I'm doing this for my friend who has a OFT. So please excuse my noob question.
We are in LA so we run 91. His car has a drop-in filter with EL header. He just installed his Powerblock.
Which map to use from this list? Not sure why there are multiple files for Stage 2 EL 91. Thank you so much!
JS + BRZ is offline   Reply With Quote
Old 09-11-2015, 02:25 PM   #128
Shady195
Drives: '13 10 Series FRS #1203
Different CAL ID's in the ECU.
If hes using an OFT it will show the correct one automatically AFAIK, if you're using another means, you need to figure out the correct CAL ID to use.
Shady195 is offline   Reply With Quote
Old 09-11-2015, 03:19 PM   #129
JS + BRZ
Drives: 2010 MS3
Got it. Just talked to another friend who has it. He said the same thing. Guess the manager will tell me what the ID is once I plug the device to the laptop.
Thank you!
Old 11-24-2017, 08:58 PM   #130
Viper8
Drives: Scion FRS
Originally Posted by Shiv@Openflash View Post
I did some dyno testing on E85 yesterday and the results were as expected. Still picked up power in the 5500-6500rpm. But lost a fair it of power above that. Unfortuantely, it's the 6500 and up area of the power curve that usually performs so well on E85. And I was not able to get it back through custom tuning. I didn't exhaust all tuning possibilities but it doesn't look likely. So for those who run exclusively on E85 (and love the top end it provides), the Power Blocks may or may not be what you are looking for. I'll post dyno numbers after I spend more time on the dyno and exhaust all tuning possibilities
Cheers,
Shiv
Shiv,
I realize you tested this a long time ago (3 years), but any chance you could post your dyno results E85 + Blocks + tune vs. Blocks + tune? You mention better power is seen at lower RPMs with the E85, at the cost of power up top. I'm more interested in area under the curve and was looking for a visual means of comparing.
Thanks!
Viper8 is offline   Reply With Quote
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 04:19 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
Tales from the Dyno: UEL E85 power Shiv@Openflash Engine, Exhaust, Transmission 20 01-20-2016 09:58 AM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
