Old 05-14-2014, 06:19 PM   #127
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Hmm. That's hard - it isn't really all that loaded with those options, but 11k is pretty low mileage. For that price though, you can get a higher-mileage (30-50k mile) '09 2.9L, which gets you more power and the newer engine, as well as the newer electronics. I'd probably go for that over an 11k mile '07 2.7.
chrisl is offline   Reply With Quote
Old 05-14-2014, 06:32 PM   #128
phenoyz
Drives: 2011 Honda Fit Sport
Got it. Thanks.
one more question: are cayman engine reliable? the regular and s
phenoyz is offline   Reply With Quote
Old 05-14-2014, 10:15 PM   #129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That's actually YG's line and I'm still struggling to understand it...not that Drake is any better.
Also saw a base Panamera 4 the other day. It cried out for mercy, to end its pitiful existence.
I figured it out. He really said Maxima shitin on dat 911:
http://www.liveleak.com/view?i=3a2_1400065983
Old 05-14-2014, 10:23 PM   #130
OrbitalEllipses
Drives: Attitude
What the fuck...
Originally Posted by phenoyz View Post
is a 2007 regular cayman with low miles
NO aftermarket done on it STILL a good buy? for $30k
Cayman S money. Nice mileage, but you can find a better deal with reasonably low mileage - not 11k low, but still 'low'.
Old 05-15-2014, 02:00 AM   #131
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by serialk11r View Post
I'm not sure that it's more than just a stock oil pan issue, but having a stock pan on a 2ZZ is kind of a guarantee to lose your engine. Some people lose their engines on the street!
Also it doesn't respond to mods as well as a Honda F20 or K20.
A friend of mine regularly tracks his Elise and we will be doing a K24 motor/Type R tranny swap into it this summer. It's going to be a beast!!!
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-15-2014, 02:07 AM   #132
zdr93523
zdr93523's Avatar
Got it. Thanks.
06-07 cars have IMS bearing failure issues. I think the problem is a little exaggerated/overblown on the internet vs the actual total number of cars. 08+ cars do not have those issues due to a change in IMS bearing and block design.
www.makesmodels.com
www.camautomag.com
Old 05-15-2014, 03:04 AM   #133
serialk11r
Drives: '06 AM V8V Coupe
I thought 2003+ IMS were updated and failed less, but you can always get a LN replacement bearing and put it in.
Old 05-15-2014, 08:19 AM   #134
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
BRZ vs S2000 vs Cayman S (my take)
Agreed. This is way WAY overhyped. If you do a search for documented cases of IMS failures for the Cayman you will find a handful at best. If the internet didn't exist nobody would even know the Cayman had an IMS. It's a much bigger problem for older Boxsters & 911's. In fact there was a class action lawsuit against Porsche for those models' engines, and you can bet those lawyers would have included Cayman owners if the case could be made for them. But there wasn't enough proof that it's a significant issue for the Cayman.
Honestly, the best advice you can get for buying a Porsche is this: "buy the nicest S model you can afford." The base Cayman is still a nice car but for me, if I'm going to deal with the increased cost of owning a Porsche then I want increased performance as well. The base Cayman is no faster than an S2000.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 05-15-2014, 10:02 AM   #135
OrbitalEllipses
Drives: Attitude
Base models are for plebeians and poseurs.
Old 05-15-2014, 11:55 AM   #136
chrisl
986 Boxsters have IMS bearing failure issues ('97-'04). 987.1 Boxsters ('05-'08) and Caymans ('06-'08) still do have an IMS bearing, but it was dramatically beefed up, and the failure rate is pretty much completely negligible. 987.2 ('09-'12) cars don't actually have an IMS anymore, so that failure mode is gone completely in those cars.
The bigger concern is if you track the car a lot. 987.1 cars are prone to oil starvation in high sustained lateral G corners, especially if you run R comp tires or slicks. This can be largely solved with an Accusump, but it's definitely something to be concerned about. This was also fixed in the 987.2 cars by changing the oil pickup system. They also sometimes need an upgraded air-oil separator or they can pull oil through the intake (again on high-g corners, especially with high engine vacuum). Finally, the 987.1 S engine may have issues with the rod bolts if you spend a lot of time right up near the redline (from what I've heard, the 2.7 isn't as prone to this, due to the lighter/smaller engine internals).
Basically, the car is a very reliable car when used as a daily driver with occasional track/high performance driving, but it does need a couple of things if you want it to be reliable under heavy track use (from what I've heard at least).
Old 05-15-2014, 11:56 AM   #137
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@ftc~brz
Old 05-15-2014, 11:58 AM   #138
OrbitalEllipses
Drives: Attitude
The bigger concern is if you track the car a lot. 987.1 cars are prone to oil starvation in high sustained lateral G corners, especially if you run R comp tires or slicks. This can be largely solved with an Accusump, but it's definitely something to be concerned about. They also sometimes need an upgraded air-oil separator or they can pull oil through the intake (again on high-g corners, especially with high engine vacuum).
Pancake engine problems...
Old 05-15-2014, 12:09 PM   #139
zdr93523
zdr93523's Avatar
Agree with everything.
Sent from my LG-D800 using Tapatalk
www.makesmodels.com
www.camautomag.com
Old 05-15-2014, 12:19 PM   #140
ftc~brz
Done
Drives: WRB BRZ
no need heated seats....no drive in winter...learned my lesson. peasant I must be. @OrbitalEllipses
ftc~brz is offline   Reply With Quote
brz, cayman, s2000
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 07:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-27-2012 11:26 PM
FRS/brz VS Porsche Cayman jurjurson FR-S / BRZ vs.... 22 08-15-2012 04:14 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 04:49 PM
