Old 05-21-2015, 10:58 AM   #127
jaf89f
jaf89f's Avatar
Drives: Raven MT
Originally Posted by DC2R View Post
So they say top keep to the recommended 7500 changes, huh?
Changing my oil this weekend. Maybe swap it out at 5k
My conversations were more towards which product to choose, not necessarily the interval to follow...I would definitely shorten the interval somewhat to probably at least every 5K.
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 05-21-2015, 11:00 AM   #128
DC2R
Drives: 2014 Scion FR-S
Thanks for doing this legwork. We appreciate it.
DC2R is offline   Reply With Quote
Old 05-21-2015, 04:17 PM   #129
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
5500 mile oci on amsoil dominator with uoas. Turbo on e85.
The Following User Says Thank You to Reaper For This Useful Post:
GhostOp86 (12-09-2015)
Old 05-31-2015, 10:46 PM   #130
sw2oboi
Drives: 13 FRS
Valveline vr1 racing 10/30 is compatible with alcohol fuel. It's readily available at autozone for $9/qt. it's also high in zinc and phosphorus. Good for your motor.
sw2oboi is offline   Reply With Quote
Old 05-31-2015, 11:04 PM   #131
ramosryan
Drives: Frs 10 series
I will stay away from this post, since I was a top fuel mechanic and learned all oils as a bottom end guy including breakdown of oil . For a street car or track car you will never have the abuse of a fuel car. There are to many opinions out there. Nobody will prove right or wrong cause chemistry will never be shown. Some have better but most the same. If so worried about your oil then your barking up the wrong tree.
ramosryan is offline   Reply With Quote
Old 06-01-2015, 01:19 AM   #132
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
So what are you saying.. to use or not to use diff oil when using E85?
Kelbyat07 is offline   Reply With Quote
Old 06-06-2015, 12:19 AM   #133
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Sustina is okay for e85?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 06-21-2015, 11:16 PM   #134
FRS Johnny
FRS Johnny's Avatar
bumpp
Old 06-22-2015, 10:06 PM   #135
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
E85 specific oil
Just to chime in, I've been using stock Toyota oil with e85. I've just been halving my oil changing intervals. That seems to be the most important part
Edit: I should also mention I'm still NA. I've only got OFH with the stage 2 e85 tune
Kronos is offline   Reply With Quote
Old 08-02-2015, 01:23 AM   #136
FRS Johnny
FRS Johnny's Avatar
Heres my oil test. Eneos sustina 0w20. Ran I would say 80-90% on e85. One auto cross event. The rest of the miles were mostly through canyons, then some as a daily.
Old 10-16-2015, 05:08 AM   #137
ZZT86
ZZT86's Avatar
Drives: BR86
VOA / UOA for TGMO 0W20 SNGF5 - E85 only
Thought I'd share this with you all since it's something worth looking at & certainly something the guys over @ Bitog land would get excited about
Attached are VOA & 2 x UOA for Toyota TGMO 0W20 SN GF5 Synthetic motor oil (part # 08880-83325 Made in Japan), the UOA show details for E85 use only.
Car is tuned to run the juice but is pretty much stock otherwise including it's original air filter which is due to get changed next week. It's a DD which sees lots of FWY driving & gets to about 100C each & every time twice a day - it's pretty much babied as there's little to get excited about driving to/from work. I have been running the juice F/T now for over a year so about 24K kms, have dumped the oil often & thought the oil was always in really good condition.
@bluesubie - what ya think of these ? There's more coming . . . . . comments welcome.
File Type: pdf VOA_TGMO_0W20_SNGF5_Normal_17879261.pdf (70.3 KB, 657 views)
File Type: pdf UOA_TMGO_0W20_SN_GF5_SEP2015_Normal-WEB.pdf (149.2 KB, 502 views)
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
bluesubie (10-16-2015)
Old 10-16-2015, 11:48 AM   #138
bluesubie
Wow, nice job! A UOA and a VOA at the same time.
At first glance, oxidation in the UOA looks a little elevated but that's where having a VOA showing the virgin oxidation really comes in handy. I can't remember off the top of my head if TGMO is thought to have any ester base stocks, but esters by their nature show higher oxidation levels so it doesn't mean that you actually have oil oxidation.
For E85, I think this is pretty impressive. I've seen a few good WRX and STI uoa's on E85, and I've seen some where it really trashed the oil (could be a tune issue instead of just an E85 issue).
The only thing that jumps out at me is the silicon and you already mentioned the air filter. Although you did run the oil twice as long as last time and si is about the same. And ALS actually tests for fuel (% by Gas Chromatography) instead of estimating it based on flashpoint like Blackstone. I still can't believe the difference in fuel dilution in the twins vs. the DI WRX and Forester. I really wish Subaru would have also included port injection in their DIT's. 4-6% fuel isn't unusual in a Subaru DIT.
bluesubie is offline   Reply With Quote
The Following 2 Users Say Thank You to bluesubie For This Useful Post:
viscositosis.rex (10-18-2015), ZZT86 (10-16-2015)
Old 10-16-2015, 06:14 PM   #139
steve99
The tune is running as lean as possible at lower rpm below 3000 and lower loads under 0.8 for better economy when cruising arround town and on highway, then over 3000 and higher loads its going for max performance.
Above 3000 its running full DI till 7200, when a bit of port injection is switched back in as the DI is getting toward max usable pulse widths with a safety margin. Below 3000 its running the pretty standard pi/di split, except at idle where its full DI again, where stock runs a pi/di split
The Following 2 Users Say Thank You to steve99 For This Useful Post:
bluesubie (10-19-2015), ZZT86 (10-16-2015)
Old 10-16-2015, 09:15 PM   #140
ZZT86
ZZT86's Avatar
Drives: BR86
@bluesubie - really appreciating your thoughts, awesome I should make a service interval change in my service book to change out the air filter much sooner as I know damn well these cars get very dusty under hood. And yeah I can only imagine what 4-6% fuel dilution would be like on the oil - gee that's really high/bad.
Actually Steve ^^ knows the tune best as he tweaked it, I used to be able to smell the juice quite obviously & the numbers weren't quite right but reckon we're on a winner now - thanks again Steve
OCI now approaching 7500kms and the oil still looks good, that's as far as I'll take it, I will post UOA findings here soon
WTB: UEL HEADERS! Non specific Asian Delight Engine, Exhaust, Bolt-Ons 1 02-07-2014 04:51 PM
Specific Vishnu OFT threads... Tromatic Software Tuning 6 12-07-2013 03:09 PM
Looking for a specific spoiler ... Need help finding it. pwnisher Cosmetic Modification (Interior/Exterior/Lighting) 8 07-10-2013 10:56 PM
Anyone know where to get FR-S specific key chains? mmieszanek Scion FR-S / Toyota 86 GT86 General Forum 4 02-26-2013 04:28 PM
Specific iso bdanisi Engine, Exhaust, Transmission 1 02-12-2013 09:31 PM
