Old 11-17-2013, 08:01 PM   #127
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
The Following User Says Thank You to quik1987 For This Useful Post:
bedabi (11-25-2013)
Old 11-17-2013, 08:05 PM   #128
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Originally Posted by rcm47 View Post
That's why I get so pissed when Subaru fan boys try to take all the credit and say the car is all Subaru and that the FR-S/GT86 are rebadged subarus.
Look at the BRZ, looks NOTHING like part of the Subaru line up. It doesn't even have the Subaru corporate wing grill. Thank god.
Originally Posted by quik1987 View Post
Much better
sprintertrueno86 is offline   Reply With Quote
Old 11-17-2013, 08:20 PM   #129
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
That STi doesn't actually look too bad - I'm still reserving judgment on the regular wrx though.
chrisl is offline   Reply With Quote
Old 11-17-2013, 08:28 PM   #130
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
Not bad but I still like my FR-S, thanks for sharing the sneak peak though
subwaynm is offline   Reply With Quote
Old 11-18-2013, 03:42 PM   #131
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
now lets see them reverse their decision about the 5-door...
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 11-18-2013, 09:43 PM   #132
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The WRX and STI specs now announced, it makes me think a bit.
You see, the specs from these current models and the soon to be released one are quite similar. Perhaps Subaru is going back in time where in Japan they didn't focus on horsepower or torque but instead on the car as a whole it self. Good to see this.
Old 11-18-2013, 10:31 PM   #133
1086
1086's Avatar
Drives: UM86 - 6MT
It unfortunately resembles a civic ... shmeeeeh ...
1086 is offline   Reply With Quote
Old 11-18-2013, 11:32 PM   #134
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Originally Posted by SkitterSkotter View Post
So the new WRX has 268hp...that's pretty awesome. Now the main thing to do will be to wait and order their stock exhaust manifold+turbo and ecu and then bolt that up to the FR-S. Though I do wonder about the compression they are using. I would love to be able to use stock wrx parts. I feel like 268 would be ideal for this application.
The Legacy's FA20 DIT is 10.6:1, it might be the same with the WRX.
adprokid is offline   Reply With Quote
Old 11-20-2013, 01:51 PM   #135
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Not a ton of new information, but a few new pictures. Motortrend article.
Since its introduction in the U.S. in 2002, the Subaru WRX has been an enthusiast staple. Expectations couldn't be higher for the newest model, and Subaru gave us a taste of things to come earlier this year with the WRX concept. Now, the 2015 Subaru WRX has been fully revealed at the 2013 Los Angeles auto show, and things look promising for the successor to the famed rally special. The 2015 Subaru WRX is based on the current-gen Impreza sedan's body, and, as you might expect, features a similar profile. The WRX, however, gets a unique hood, rear doors, rear quarter panels, headlights, taillights, bumpers, and front fenders. Those fenders receive the characteristic flares, while the model's distinctive hood scoop is set more deeply to improve visibility. The front end vaguely resembles that of the concept, with the hexagonal grille jutting out past the headlights. Those headlights maintain the basic shape of the concept, but don't get the same wild, 3D LEDs. A C-shaped LED accent envelops the main lamps within the housing, which utilizes full LED low-beam lights on higher-trim models and halogens on others. Subaru says the front end look is meant to "evoke a raptor's stare."
Of course, you can't have a WRX without a turbocharged flat-four engine and a performance-oriented all-wheel-drive system, and the 2015 model delivers on both fronts. Subaru borrowed the turbocharged, direct-injected 2.0-liter boxer four-cylinder from the Forester XT, and employs a high 10.6:1 compression ratio, twin-scroll turbocharger, and the Subaru Dual Active Valve Control System. The engine gets different camshafts and higher-rate valve springs, among other upgrades unique to the WRX, to bring output to 268 hp and 258 lb-ft of torque, which peaks between 2000 and 5200 rpm. That represents an increase of 3 hp and 14 lb-ft of torque over the previous-gen model's turbo 2.5-liter. A six-speed manual transmission, the first-ever application in the WRX, is standard. All previous WRX models were available with five-speed manuals, and Subaru says the new transmission provides a wider ratio spread and features carbon synchronizers on first and second gears. In place of an automatic option is an available Sport Lineartronic CVT. As the WRX engine is related to that of the Forester turbo, a CVT makes sense from a logistical standpoint, but the choice may puzzle many enthusiasts as continuously variable transmissions aren't typically known for being sporty. To those doubters, Subaru says that the Sport Lineartronic CVT has been "engineered to enrich the performance driving experience," while maintaining the smooth, fuel-efficient characteristics the transmission type is known for. When in Sport Sharp mode, the CVT automatically shuffles through eight pre-selected stepped gear ratios, and the driver can choose from six- and eight-speed manual shifting modes using the steering wheel-mounted paddle shifters. CVT-equipped models also feature the Subaru Intelligent Drive system, which allows the driver to customize the driving experience by choosing from three modes, including Intelligent, Sport, and Sport Sharp. Each transmission gets its own version of Subaru's Symmetrical All-Wheel-Drive system. Manual-equipped models receive a viscous coupling locking center differential that splits torque 50:50 front and rear in normal driving conditions, and applies power to the wheel with the most traction when the Vehicle Dynamics Control system detects slippage. CVT models come exclusively with a Variable Torque Distribution (VTD) version of the all-wheel-drive system, which utilizes a planetary gear-type center differential and electronically controlled hydraulic transfer clutch to distribute torque. In most situations, the VTD splits torque 45:55 for a rear torque bias and better handling agility. The system constantly adjusts torque distribution based on the driving conditions and input from steering wheel angle, yaw, and lateral g-force sensors. The 2015 WRX rolls on a set of aerodynamically optimized 17-inch alloy wheels wrapped in 235/45R17-size Dunlop Sport SP Maxx RT high-performance tires. Electric power assist steering was used, and combined with the tires, sport-tuned suspension, and stiffer chassis compared to the outgoing WRX, the electric steering system yields response that Subaru says was benchmarked against some of the best-handling sports cars. The body features more high-tensile-strength steel than the previous model, and uses special stiffening elements. The improvements continue inside the new WRX's cabin, which is more spacious thanks to a wheelbase that's an inch longer than the outgoing model's. The dashboard is lower than before, and a higher seating H-point combined with lower door sills and doors that open wider contribute to easier ingress and egress. Almost 2 inches of legroom have been added in the rear, and the larger trunk also benefits from standard 60/40 split folding rear seats. Automatic climate control comes standard, while hands-free keyless entry, push-button start, heated front seats, a nine-speaker Harman/Kardon premium audio system, and navigation with Aha smartphone integration are available as options. Soft-touch materials are used in the dash, door trim, and center console armrest. A flat-bottom steering wheel comes wrapped in leather, and features audio and Bluetooth controls along with tilt and telescoping adjustment. Behind that is a dual-gauge cluster layout with a 3.5-inch central LCD screen, which can show oil level and selected gear. A new 4.3-inch LCD screen placed high and inset in the center stack can display a boost gauge, rearview camera feed, audio info, climate control settings, or VDC functions like traction control. Drivers can take in all this info from the comfort of the "Whiplash-reducing" front sport seats, which come standard covered in high-grip fabric but are available in leather. An eight-way power adjustable driver's seat is also available. The turbocharged, all-wheel-drive formula that has served the WRX well for more than 10 years appears to still be intact with the 2015 model, but we'll have to wait until we can drive it to see if it's a worthy successor -- and to find out if a CVT is an appropriate option for the performance car.
mines13 is offline   Reply With Quote
Old 11-20-2013, 02:22 PM   #136
brillo
Drives: 2013 Firestorm FR-S
I think it looks good, way better than the current model.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
bedabi (11-25-2013)
Old 11-20-2013, 02:37 PM   #137
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Man... Still no photos of the rear Subaru? Are they ashamed of the back end or something. I think it looks good. Definitely not a terrible looking car, but I'm not amazed by it either. Interior looks much improved for sure.
00NissanNinja is offline   Reply With Quote
Old 11-20-2013, 02:47 PM   #138
M-17
Ninja Cat Mod
M-17's Avatar
The Following 10 Users Say Thank You to M-17 For This Useful Post:
00NissanNinja (11-20-2013), adprokid (11-21-2013), Giccin (12-17-2013), LivingLegend (11-20-2013), Meehow86 (11-21-2013), RJ_203 (11-25-2013), RRnold (11-25-2013), tech4pdx (11-20-2013), Whitigir (11-20-2013), ZetaVI (11-20-2013)
Old 11-20-2013, 05:06 PM   #139
Levi
Drives: Toyota
This car is a total fail. What is Suabru thinking? There is no progress. It is nothing that an Subaru Impreza with FA20 and Turbo. Lame. Look at the CLA 43 AMG and the upcoming RS3 Sedan? Sure they cost more, but they also offer more. Really disappointing to the level of BMW.
Levi is offline   Reply With Quote
Old 11-20-2013, 05:50 PM   #140
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
So all they did was give a new front fascia to the current Impreza?
Wow....innovative
TylerLieberman is offline   Reply With Quote
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 01:18 PM
APR Carbon Fiber Rear Bumper Valance Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Exterior Parts - Lighting 10 07-31-2015 12:39 PM
GReddy Supreme SP Cat Back Exhaust Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 7 07-15-2015 05:21 PM
Tomei Expreme Ti Test Pipe Titanium 80mm Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 1 06-15-2015 12:45 PM
