Old 12-24-2014, 10:53 AM   #127
1Cor10:23
1Cor10:23's Avatar
Originally Posted by mav1178 View Post
#1, no idea, ask Ohlins.
#2, yes. The adjuster threads onto the end of the shock body. Grab the silver base of the adjuster (head is gold colored) and turn counterclockwise.
-alex
Thanks alex, I tested the compression by hand while varying the adjuster, seems like everything is a-okay but I'll give Ohlins a call after the break to confirm.
Regarding the rear shock adjuster, do you have to hold the hold piece steady while you turn the silver seat CCW? Is there a torque spec for re-assembly? Funny that the instructions make no mention of this step... Thanks!
Old 12-24-2014, 12:07 PM   #128
Sleepless
Drives: 2016 FR-S
Originally Posted by GT86_PRAGUE View Post
So, how are they after that time? Would you buy them again?
I've had mine for several months, several thousand miles, and many track days and am very happy with them on and off the track. I would buy them again.
Sleepless is offline   Reply With Quote
Old 12-24-2014, 12:19 PM   #129
dp1
driving smoother faster
Drives: Sold
^ that, awesome dampers and well worth the money for occasional track and AX use. I'm having them rebuilt now with 500lb rear springs and revalving. Would buy again.
dp1 is offline   Reply With Quote
Old 12-24-2014, 12:24 PM   #130
1Cor10:23
1Cor10:23's Avatar
@dp1 are you having them services through Ohlins? Do you mind me asking how much rebuilding runs around? Cheers.
Old 12-24-2014, 12:27 PM   #131
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No torque spec as you just need to tighten it enough to where the adjuster won't go anywhere.
-alex
Old 12-24-2014, 04:00 PM   #132
kster1
kster1's Avatar
I've been on the Ohlins R&T for about 8000 miles which includes maybe 10-12 track days. They are a great balance for street and track use and very solid in terms of build quality and reliability.
My only criticism would be the spring rate; I've switch over to 350/425 F/R and the car rotates much better. It also shows a better distribution of temps on a tire pyrometer. If I want to go stiffer in the rear (as @dp1 is doing), I'd send them in for a revalve. When I called Ohlins about this, they said it would be $125/corner with a one to two day turnaround.
kster1 is offline   Reply With Quote
Old 12-24-2014, 05:09 PM   #133
dp1
Drives: Sold
Ohlins Road & Track for FRS/BRZ suspension install/review thread
Yes, they are being rebuilt by Ohlins and they were kind to order correct 500lb springs for me from a well known spring manufacturer and to revalve since the difference in spring rate is more than 20-30% from stock. Can't comment on the price, give them a call, great customer service. Note that full rebuild price will be higher than revalve only price.
Old 12-24-2014, 09:50 PM   #134
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
How much did they charge you for revalve? Thanks!
Old 12-25-2014, 08:49 PM   #135
dp1
Drives: Sold
I am sorry but I can't disclose the full rebuild price. I am getting a full rebuild that includes revalving so I don't know how much for revalving only, but I had seen the same quote before for revalving per corner as mentioned above.
Old 01-12-2015, 07:06 PM   #136
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
I`m looking to purchase a set and just have them revalve with the higher spring rate in the rear even before i install them on my car.
one question. does it feel just as comfortable as they were with the 343lb springs, or is it now at that uncomfortable/track smooth surface only setting? i would assume with proper valving, it would still be very comfortable.
mokinbird87 is offline   Reply With Quote
Old 01-12-2015, 07:45 PM   #137
dp1
Drives: Sold
BTW, I ended up ordering 380f/425r spring rates. These are not progressive springs, so, depending on the adjustment, I suspect that they will work a little better for either low or high speed bumps. They are quite comfortable on the street with stock 345lb f/r springs and I expect that they will remain with the slightly stiffer rates. I'll post impressions in late March when they're back on the car and after Apr/May track days. I will probably do some AX from April on.
Old 01-12-2015, 08:02 PM   #138
kster1
kster1's Avatar
On the street, the higher spring rate (350F/425R) is noticeable when going over bumps and and ruts in the road. But it's not that much stiffer where I'd call it uncomfortable (at least for my tolerance). I don't daily drive my car but I do drive to the track which is 2-3 hours and it's not too bad.
Old 01-12-2015, 08:09 PM   #139
mokinbird87
BOXER FR
i think the Ohlins set up is more comfortable than stock, so I can`t imagine the stiffer setting all of a sudden becoming so uncomfortable. maybe if i make it up to Laguna Seca I can hitch a ride in your car @kster1 ?
Old 01-12-2015, 08:20 PM   #140
mav1178
mav1178's Avatar
@mokinbird87 why are you in need of a stiffer setup? Just because one prefers stiffer doesn't mean it works for others.
The tires you will run makes a bigger difference for "normal" driving, to be honest. If I gave someone rides with my previous setup (street - Toyo T1 Sport / track - Falken RT615K) vs now (street - Falken FK453 / track - Hanhook RS3), one would swear I changed my suspension setup. Sidewall stiffness makes a huge difference in ride quality.
-alex
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
