Old 10-11-2016, 01:08 PM   #127
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Arcadien Angel View Post
No can do, says your mailbox is full.
Freed up some space
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Arcadien Angel (10-12-2016)
Old 02-01-2017, 02:28 PM   #128
Kris86
Kris86's Avatar
Drives: RHD Gt86
remember to take some videos
nice build bro
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
The Following User Says Thank You to Kris86 For This Useful Post:
SPCorBUST (02-01-2017)
Old 02-13-2017, 12:25 AM   #129
SPCorBUST
SPCorBUST's Avatar
After a little over 4 1/2 months, the 3k break in is complete.
Break in oil is (mostly) out and Motul 300V 5W-40 is in with a new STI filter and a (now half) full tank of E85 and man WOT never felt so good.
I'll be doing a bit more break in while on the high boost pulley and then I'll switch to the C38 with the high boost pulley before switching to the race pulley and then upping the rpms. The latter has me a bit concerned, it depends on how things go with the race pulley to start.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 03-29-2017, 01:09 AM   #130
Khánh
Khánh's Avatar
Drives: sc00ter
great build man!! Can I PM you about your setup?
Khánh is offline   Reply With Quote
Old 03-29-2017, 11:45 PM   #131
SPCorBUST
SPCorBUST's Avatar
Definitely!
Sent from my SM-G925T using Tapatalk
Khánh (03-30-2017)
Old 03-30-2017, 01:01 AM   #132
Hicklinc
Drives: N/a
Are you going to dyno it
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 03-30-2017, 01:35 AM   #133
SPCorBUST
SPCorBUST's Avatar
Yes, I'll dyno it again once I switch over to the C38 + HBP, so it will be showing a gain by just switching over to the C38, but on the HBP both times. Don't think anybody has done that yet. And then again once I go from the HBP to the race pulley, don't think anybody had done that yet either.
It's gonna be like when I tuned the C38 when I had the KW kit, and when I did the C30 HBP. Nobody had tuned those before me either. Didn't plan to be that way, just seems to sort of keep happening... Lol.
Hicklinc (03-30-2017)
Old 03-30-2017, 01:44 AM   #134
Khánh
Khánh's Avatar
Drives: sc00ter
Definitely!
you are a popular man.. no space to send you PM haha
Old 03-30-2017, 04:11 AM   #135
SPCorBUST
SPCorBUST's Avatar
should be okay now
Old 03-30-2017, 04:16 AM   #136
SPCorBUST
SPCorBUST's Avatar
Azusa
Big Tujunga
dj2020 (03-31-2017)
Old 03-30-2017, 07:54 AM   #137
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Looking forward to seeing the results. I've only had one track weekend so far with the high boost C30 and I was a little underwhelmed. It does now hang on the Sebring straights with current gen V8 Mustangs and Camaros but I built the motor for more. I chose 11.5 CR just to have a little more margin for higher boost but I'm sure it's stealing away a bit of power in my current setup. Looks like a C38 is where I need to go especially if I can lower my shift points a few hundred rpm as well. What is the size and projected boost differences between the C38 high boost and race pulleys?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 03-30-2017, 02:11 PM   #138
SPCorBUST
SPCorBUST's Avatar
When I had the C38 with the KW kit, I was making 15 psi. My JR C30 HBP is currently doing 11.5 psi. JR C38 HBP was documented by VitViper hitting almost 14 psi. I had a conversation with Oscar Jr. and my takeaway was that the race pulley is something like 17/18 psi with someone else running an even smaller pulley closer to 20 psi... (I won't do that) I know psi isn't everything either.
What any of these power levels are like on 91 I'm not sure, but I am pretty sure its not recommended to run 91. (at least here in CA) I will only have hp figures for E85 once I'm done with everything.
dj2020 (03-31-2017)
Old 03-31-2017, 12:45 AM   #139
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Can't wait to see this dyno sheet, the one dyno sheet to rule them all.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 04-17-2017, 03:06 AM   #140
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
Awesome build! Can't wait for more updates!
86two6 Thursday Meets in SoCal.
IG @86two6
Greddy86 is offline   Reply With Quote
