Old 03-13-2012, 01:18 AM   #127
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by Want.FR-S View Post
Yes indeed, but that 89 AKI is never called a *premium* fuel in any region, right?
Right. Usually referred to "mid-grade" and basically a mix of regular and premium fuel (gets mixed underground as most gas stations have 2 underground tanks).
tranzformer is offline   Reply With Quote
Old 03-13-2012, 01:33 AM   #128
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Offtopic: I remember one time one gas station ran out of regular so they block off both regular and mid grade and set the price of premium with regular price. That free premium ran for about two days until the fuel truck came with regular.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 03-13-2012, 03:31 AM   #129
Allch Chcar
Drives: N/A
Also Off-topic: Premium gas sales are only like 10-15%(edit) of all Gasoline in the US. I've heard stories of stations switching out Premium to E85 and getting more sales!
Ontopic:
We should stop using AKI and switch to using the RON like everybody else. Then we wouldn't have these problems. A grassroots effort might do it.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 03-13-2012, 04:11 AM   #130
serialk11r
Drives: '06 AM V8V Coupe
1%??? Are you serious? Does that mean most luxury car buyers...are filling their "PREMIUM UNLEADED FUEL ONLY" cars with regular?
I'd be up for more E85 stations around here at least, ethanol+direct injection is a pretty awesome combo
Old 03-13-2012, 04:22 AM   #131
Allch Chcar
Drives: N/A
I double checked since I was going off memory but it seems I did forget a 0. It was 10% a couple years ago during the recession, 15% around 2000, I managed to find some numbers that said it was almost 30% in 1989!
-Allch Chcar
Old 03-13-2012, 07:34 AM   #132
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm still going with the marketing intern in new jersey seeing "premium fuel required" and simply on verging that to "93 octane" because that is their premium. It's going to be 91 "required"/93 recommended.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-13-2012, 10:19 PM   #133
tranzformer
Drives: Zoom Zoom
Should note that the manual states this regarding the fuel:
The engine is designed to operate at maximum performance using unleaded gasoline with an octane rating of 93 AKI (98 RON) or higher. If 93 AKI (98 RON) fuel is not readily available in your area, unleaded gasoline with an octane rating of 91 AKI (95 RON) may be used with no detriment to engine durability or driveability. However, you may notice a slight decrease in maximum engine performance and you may hear some knocking (pinking) of an engine while using 91 AKI (95 RON) fuel. Use of 91 AKI (95 RON) fuel will not affect your warranty coverage.
Old 03-13-2012, 10:32 PM   #134
serialk11r
stuff
Where are you getting the part about knock? I see this:
■ Fuel types
Unleaded gasoline (93 AKI [Research Octane Number 98] or higher)
If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available, unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
Sounds like it's one of those things where you might get some knock with 91 under hot weather and heavy acceleration at low speeds.
Old 03-13-2012, 10:37 PM   #135
tranzformer
Drives: Zoom Zoom
Just from the owners manual. Section #6: Vehicle Specifications page 420
https://pictures.dealer.com/subaruof...1914b5d7f4.pdf
Old 03-13-2012, 10:39 PM   #136
serialk11r
Ah okay yes, I found it too.
Old 03-13-2012, 10:43 PM   #137
tranzformer
Drives: Zoom Zoom
Interesting that they state the knock will have "no detriment to engine durability or drivability." I thought a continuous knock could definitely affect durability and drivability.
Old 03-13-2012, 10:54 PM   #138
serialk11r
Perhaps light knocking isn't too big of an issue (I wouldn't know), but I wonder what they mean by "driveability"...if I were driving and my engine made funny noises, I'd wonder what is going on even if there's no torque fluctuation.
Old 03-13-2012, 11:17 PM   #139
Allch Chcar
Drives: N/A
From what little I know, and until one of the more knowledge guys correct me, sustained knock is what will kill a factory engine. So yes a little bit is okay, otherwise the knock sensor would be pointless.
-Allch Chcar
Old 03-14-2012, 12:47 AM   #140
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
just read the manual, 93 is what they want in the engine 91 is acceptable anything lower will cause heavy knocking im
manual says use 91 as lowest octane rating
ohh yeah and dont use anything with more than 10% ethanol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
