Old 06-15-2015, 07:46 AM   #127
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Is it a common upgrade path with this chassis to get brake ducts and then a BBK when you've reach the limit of whatever pad you running or did most people just get a BBK without ducts?
The reason for all the questions is I want to leave the car as stock as possible while making it as safe and reliable as possible. I really like the dynamic of the chassis and don't want to screw it up with an improperly setup aftermarket suspension.
Can anyone give me an estimate on how much time on track you get to a tank of fuel or half or quarter tank. I know each track and driver will be different. I want to have an a real estimate of how much fuel to bring and not have to leave to get fuel. Fuel retails for about 3x the cost in the paddock vs a gas station up here.
TRAKRAVN is offline   Reply With Quote
Old 06-15-2015, 07:35 PM   #128
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@TRAKRAVN last SPDA lapping day at DDT I had to cut my 5th session early as I was almost gonna run out of fumes. I filled up in North York though, so count that into my usage. If I were you I'd bring another 20L with you and that should be good
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
TRAKRAVN (06-15-2015)
Old 06-15-2015, 08:07 PM   #129
strat61caster
strat61caster's Avatar
I budget a full tank for the day, 10+ gallons for 100 minutes of on track running. Makes sense, some very rough math follows: locally average speeds for non-premium cars are around 60-70mph (~1mile/minute), average fuel economy is around 10mpg, so you pretty much end up at a bit more than 1 gallon/10 minutes. A conservative estimate would be 1.5 gallons/10 minutes, so I'd be bringing 15 gallons to the track, ~13 in the tank and 2 on hand or however it shakes out, 10/5, 7/8, whatever.
If I arrive at the track with a full tank (or as near as possible from the nearest gas pump, usually <25 miles, puts me at 12 gallons in the tank) I'm solid but will need to fill up before heading home (usually same station on the way out). Someone more aggressive than me may be cutting it a bit closer if not outright needing to top off a gallon or two to finish the last session and get to a station.
ineedyourdiddly
Old 06-15-2015, 09:18 PM   #130
TRAKRAVN
Thanks guys, I just went to get four 10L (2.6 gal) cans since my two 25L cans I usually take didn't fit the trunk well. I was going to bring five cans but I was worried it would take up to much room in the trunk with my suit bag, tire pump and socket set.
From Brampton, DDT and TMP use up about 1/4 tank in travel to the track from my rough estimates. Mind you I have only driven the car less than 500km so far so ts hard to estimate fuel usage.
If they weather and work schedule hold out I will be at TMP all day Friday.
The Following User Says Thank You to TRAKRAVN For This Useful Post:
strat61caster (06-15-2015)
Old 06-17-2015, 09:55 PM   #131
sickmint79
Drives: bmw
i went to bbk and have no ducts. i bought the gt3 plastic guys but i think i lost them... so not installed. just bought rotor paint and caliper heat sticker guys to take some measurements next time i'm out. i only had one dry session, at a new track, on monday - didn't take the wheel off to check the rotor temps, caliper looked good though ie. no additional cooling needed, although i wonder if still beneficial? more interested in my results once i get to a track i'm more confident at (27th/28th of this month) - i'll have more data to go on then.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
The Following User Says Thank You to sickmint79 For This Useful Post:
TRAKRAVN (06-19-2015)
Old 07-17-2016, 05:59 AM   #132
churchx
churchx's Avatar
Drives: 2014 GT86
Can someone advise which cans to get for extra fuel to take to track? I mean volume/dimensions wise that well fit in our car cabin or trunk (probably already rather full with extra wheels set and misc other stuff)?
Old 07-17-2016, 06:56 AM   #133
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
I put a 20L jerrycan in the passenger footwell.
infinity21 is offline   Reply With Quote
Old 07-20-2017, 09:53 PM   #134
Briggs81
Drives: 2015 Scion FR-S
Hi, everyone:
So I'm increasing the number of HPDEs I'm doing (open lap days) mostly, and it strikes me there are suspension bolts and what not I really should be checking before I head out. (I'm pretty good about the more basic stuff -- rotor, brake pads, caliper bolts, wheel lug nuts, fluids, tight caps, etc.).
What specific bolts related to track use should I be checking before track days? Pictures and torque specs appreciated, but of course I can get those by digging a bit.
Much appreciated.
Briggs81 is offline   Reply With Quote
Old 01-20-2018, 01:26 PM   #135
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
helmet question. Does a SA2010 still qualifies for this years track events or do I need to get the SA2015 for this year? I read an info that they change the required helmet every 5 years? thanks!
tintumz22 is offline   Reply With Quote
Old 01-20-2018, 05:35 PM   #136
strat61caster
Most groups will take the two most recent certifications so 2010 & 2015 right now. A 2010 helmet should be acceptable until 2020 certified helmets are available.
Although individual track groups may have more or less restrictive requirements. If it's not mentioned on the group website, email the event organizers to confirm, they want to make sure their customers are happy.
ineedyourdiddly
tintumz22 (01-20-2018)
Old 02-13-2018, 02:41 PM   #137
tintumz22
tintumz22's Avatar
Alignment needed on first day of track? Camber bolts for front. Car is stock in suspension and wheels/tires.
Old 02-13-2018, 02:49 PM   #138
FirstWinter
Drives: Car
Needed? No. Nice to have? Yes.
FirstWinter is offline   Reply With Quote
Old 02-13-2018, 02:54 PM   #139
tintumz22
tintumz22's Avatar
technically second track day. First on this car. Okay. I'll hold off until I get the feel of the car and just add those mods accordingly. Thank you!
Old 02-13-2018, 03:46 PM   #140
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Without an alignment you will wear the shoulders pretty badly, you might save more in tire wear than the alignment's price.
1.5-2 degrees of negative camber are needed just to keep from destroying the outer edge of your tires at the track (camber bolts can get this, but for even wear you'll want camber plates).
14stu is offline   Reply With Quote
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 09:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 04:56 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 01:54 PM
