Old 01-03-2017, 07:51 PM   #127
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
so i let my car warm up too much, time to wait
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 01-03-2017, 11:17 PM   #128
carbonBLUE
Reverse Burnouts
100k mile change. No metal shavings, still has some red in it, hard to tell in this bottle but it still has some transparency. I would definitely recommend doing this at 60k miles and NOT 100k miles. You might be wondering why I went so long before a change? Well the sooner my engine/transmission go the sooner I get to v8 swap @BirdTRD
EDIT: got late trying to get the temps right in the transmission, will finish tomorrow and put my impression down of the fluid change. the car was running perfectly fine before. so maybe not much of an improvement i can feel but at least the fluid is changed out. also, considering dumping 6 more quarts through just to clean it out a bit more since i didnt finish today
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
VoltsFRS2013 (04-29-2018)
Old 01-05-2017, 04:59 PM   #129
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yeah, that whole "shift indicator to get the right temp" process is a pain in the ass! Your old fluid doesn't look as bad as I thought it would, but I suppose looks aren't everything!
BirdTRD is offline   Reply With Quote
Old 01-05-2017, 07:52 PM   #130
carbonBLUE
Reverse Burnouts
yeah i dumped the first batch out before i thought of saving it and sending it to blackstone lol had it in the container and everything all i had to do is slap a lid on it and send it off lol
(wont forget you)
2011 Infiniti G37x
Old 04-01-2017, 01:27 AM   #131
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
I'm curious has anyone used a mityvac pump to pull most of the fluid from the transmission? Been searching but all I could find were people changing the oil with them.
I'm going to be changing my trans and diff fluids soon and this looks like an easier way.
2015 Subaru BRZ Limited AT6
Premium 615 is offline   Reply With Quote
Old 04-14-2017, 11:48 AM   #132
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Great thread, really informative! I recently bought a 2013 brz limited from Florida with 38k miles. Very little service history but it seems to me that under certain shift conditions the AT behaves a bit clunky. I'd like to put all fresh fluids in for a baseline going forward.
I've become tight with the local guys who work at a Meineke in town and I pay them cash for a really good deal on consistently good work but basic things... So would you trust them with an ATF service? It seems complicated as hell and this isn't something to mess with.... But on the other hand the labor would cost barely anything and the personnel there have a lot of experience. I guess I'll start by getting some quotes!
Sent from my STV100-1 using Tapatalk
majixmatrix is offline   Reply With Quote
Old 07-31-2017, 06:46 PM   #133
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Good day
Has anyone removed the pan, gasket and old filter/strainer and replaced the fluids?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-03-2018, 08:31 PM   #134
jeschris45
Drives: Yellow FR-S Rs 1.0
I will be doing my transmission fluid change this weekend. I saw the diagram where it showed the refill plug, refill hole and overflow plug. I am not sure whether I am missing something in the diagram from earlier post. I was wondering where is the drain plug to drain the atf.
jeschris45 is offline   Reply With Quote
Old 01-04-2018, 02:25 PM   #135
BirdTRD
Simply Forgotus
BirdTRD's Avatar
http://www.ft86club.com/forums/showp...2&postcount=13
Old 01-08-2018, 01:14 AM   #136
jeschris45
One quick question. While I was doing the automatic transmission fluid change, the last step of checking the correct level of atf at the appropriate temperature using the over flow plug, am I supposed to remove the overflow plug while the car is on or turned off. I actually turned off the car once it hit the correct temperature and then removed the overflow plug and waited for to drain until thin like a thread.
Does it matter that I turned the engine off?
Old 01-08-2018, 08:44 AM   #137
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by tonystewart View Post
Good day
Yes I have, needed to weld a temp probe bung on the pan and replaced the valve body for a SSP.
Lunatic is offline   Reply With Quote
Old 04-21-2018, 04:20 PM   #138
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
A little late now, but yes that definitely matters. The fluid set procedure should be done while the engine is running. This allows fluid to be retained in the torque converter while setting the level.
If you turn off the engine, and set the fluid level, you are setting the fluid level low as this allows fluid to drain back to the pan from the torque converter.
NotSoJDM is offline   Reply With Quote
Old 04-22-2018, 03:37 PM   #139
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Are you positive the car needs to be running to check the fluid?
shaynek is offline   Reply With Quote
Old 04-22-2018, 04:17 PM   #140
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yes. The service manual instructions are a bit confusing but if you go to page PM72 (2. AUTOMATIC TRANSMISSION FLUID AMOUNT ADJUSTMENT) you'll see that step 2) section (2) is "Start the engine" and the final step 9) is "Turn the ignition to off", it never says to turn the off engine in between.
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
shaynek (04-22-2018), Tristor (08-26-2018)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 03:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 03:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
