Old 11-02-2011, 03:03 PM   #127
madfast
Drives: 2010 Evo X MR-T
Originally Posted by fred_boosted View Post
My goal is 300 whp.
12.5:1 is still too high.
After market piston? 10:1? Is this possible?
Originally Posted by WingsofWar View Post
people do aftermarket pistons all the time. especially to raise or lower cr
the only potential problem is the use of dished pistons to direct the DI spray when they use stratified charge for cold start. if we have full ecu control, perhaps we can turn off stratified charge, and thus no need for the dished pistons?
or we can hope for the aftermarket to fix things:
madfast is offline   Reply With Quote
Old 11-02-2011, 03:04 PM   #128
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This will not stop me loving to build cars and DRIVING THEM!
Thanks for give me advices, I'm willing to learn from you guys! Always!
I just wouldn't expect any kits for awhile...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:06 PM   #129
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Great! 86 x 86 like I was hoping. Now, do we have forged internals?
Neutral_Eyes is offline   Reply With Quote
Old 11-02-2011, 03:06 PM   #130
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ryridesmotox View Post
True... but when will that be? I'm guessing not long cuz with all these "leaks" Toyota has to know tuners and racers are going to use this car... and most of the racers will want to go FI so I see them "leaking" the ecu encoding fairly quick. Maybe they will even lower the compression a little bit.
I doubt they'll lower compression, doing so would reduce power too..
Toyota has been very strict on ECUs from what we've seen so I'm not convinced they'll open that up either.
I hope I'm wrong though. N/A builds benefit from it too
Hopefully it's not even a Toyota ECU, just a modified Subaru one :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:06 PM   #131
skinsfn36
skinsfn36's Avatar
Drives: 2006 Honda Civic Si
As this will be my DD, and I'm sure many others, I'm still going to hope for a TRD FI option, I want this car and its warranty to last what its supposed to.
skinsfn36 is offline   Reply With Quote
Old 11-02-2011, 03:07 PM   #132
madfast
Originally Posted by Nurburgring View Post
That dyno curve looks amazingly similar to the Honda F20C, albeit with lower rev limit and peak hp. Are we absolutely sure this engine is not running some form of variable cam lift?. I don´t mind, but I´m sure the press will bash it for "no torque" in every review, just like what happened with the S2000.
i've been looking around and it seems the 2GR-FSE also has the mid rpm dip in torque... on the promotional "dyno" only. on actual dyno runs, there isnt an obvious dip. so i attribute this to the scale of that "dyno". imo once we put this car on a real dyno, that tq curve should flatten out.
Old 11-02-2011, 03:07 PM   #133
skinsfn36
skinsfn36's Avatar
I'm going to hope its a Subaru and Cobb can get their hands on it, but only time will tell.
Old 11-02-2011, 03:08 PM   #134
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
Ok, go head laugh at me.
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 11-02-2011, 03:08 PM   #135
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Agreed. But he was naming turbos in his post but probably doesn't even understand A/R, trim, etc.
You can easily throw a turbo kit on anything, but if you don't know how to do so you may have very unpleasant (or expensive :P ) results. That's all my point was.
True, but I'm sure most people don't understand that stuff... Most people think bigger is better. I'm thinking twin scroll turbo would be beastly on this motor.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 03:09 PM   #136
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
12.5:1 is retarded. You don't need that much for direct injection on a gasoline motor. And with that much compression they should be getting more power... something seems amiss.
Recall the FA20 is a cousin of the FB20, which only makes 140HP. Extracting 60 more HP while still meeting worldwide emissions with lowest-common-denominator fuel is quite an achievement. 12.5:1 static CR is nothing new; drag racers have been running over 13:1 with carburetors since at least the 60's. DI + 12.5:1 static CR is not terribly aggressive; other posters have already pointed out Mazda is doing 14:1 static CR with their Skyactiv engine, though they back it down to 13:1 for stupid garbage USA 87 octane.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-02-2011, 03:09 PM   #137
fred_boosted
Sure I can wait...
Not planning on doing custom stuff..
But I gived up.
Old 11-02-2011, 03:09 PM   #138
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I know of racers that will prefer NA power over FI power. I think you are referring to the straight line 1/4 mile racers. This car isn't for that.
tranzformer is offline   Reply With Quote
Old 11-02-2011, 03:10 PM   #139
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Turbo builds are easy with the right parts... the hardest thing is making sure you have every piece you need all at once cuz once you start, your car is down until its 100% done... it takes a while too, I don't know how people think they can do a turbo upgrade in an hour and a half, lol yea right!
This is why I'm hoping it's cheap enough that I can keep my WRX. It gives you a lot more flexibility in projects if you have a second car up and running while the other one is down.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 11-02-2011, 03:10 PM   #140
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thank you.
I thought you guys are treat people gently like EVO and STi tunners did. But it seems not.
No one laughed at you. Your post spawned multiple conversations
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
