Old 10-29-2011, 03:06 PM   #127
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
To be honest... I'm not 100% sure... the one shop that runs them is pretty secretive about it... here is a link to one of their cars if you want to see it... They wont even let him post pictures of the new manifold I believe. Its nuts haha, how secret they are being about a "dead" GM platform like the Cobalt. I am pretty sure they are using a stock ECU with modified programming via HP tuners dual injectors are not stock. They are simply using them to get enough ethanol in the cylinders. The factory turbo cobalts have direct injection (LNF engine), the factory supercharged cobalts (LSJ engine) have standard port injection. Everyone uses HP tuners for domestics it seems like.
http://www.cobaltss.net/forums/pictu...d-list-263582/
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 10-29-2011, 03:25 PM   #128
madfast
Drives: 2010 Evo X MR-T
interesting. im guessing the stock ecu wont have provisions to tune a second set of injectors. so perhaps they are using something like a meth injection kit and spraying e85? if the FT's ecu is programmable, tuners will have to learn how to tune both DI and PI together, seamlessly, on the ecu.
madfast is offline   Reply With Quote
Old 10-29-2011, 03:36 PM   #129
ryridesmotox
I'm sure you are right but they haven't released any info, they were going to sell it to people so I'm thinking the tuning isn't that big of a deal. We have stock widebands on the turbo cobalts, so I think maybe the injectors for their respective cylinders are on the same loop, just driven by the AFR or something... but honestly I have absolutely no idea. As far as I know the manifold injectors are fed from the fuel tank as usual, the DI fuel also comes from the fuel tank via the same pump as the manifold injectors, they just use a large, LARGE pump. This setup is pretty much only for running ethanol on the DI LNF motors since we run out of fuel system at about 410lbs/ft of torque on ethanol (where I'm at right now). We can't get enough ethanol in the cylinders. They were going to just release the manifold and injectors for people to buy and install but they cancelled it cuz I guess it wasn't cost effective. IE- for the cost of that setup, I can just tune the car for C16 and run that instead of ethanol. Using a Meth/H20 injection system would not get close to the fuel I would need to run straight E85... Heck even that car's "secondary" injectors in the intake manifold are 60lbs injectors haha that's pretty big.
Old 10-29-2011, 04:00 PM   #130
Redliner
Redliner's Avatar
Drives: Peugeot 206; Suzuki GSR600 k8
In the article, they say that there will be lsd only for the sportier version whitout the rear-seats. Damned thats very sad. Hope they will offer a lsd as an option in the basic car.
Redliner is offline   Reply With Quote
Old 10-29-2011, 04:07 PM   #131
madfast
the R version will have a mechanical LSD whereas the regular car will have a Torsen LSD...
Old 10-29-2011, 04:11 PM   #132
sfwg
Drives: 2007 saturn ion(dd)
ryridesmotox:whats your user name on the .net? im on there too!
sfwg is offline   Reply With Quote
Old 10-29-2011, 04:17 PM   #133
Redliner
Redliner's Avatar
Oh thanks, thougt a Torsen Diff is just a normal
Old 10-29-2011, 04:31 PM   #134
nogaroblues4
Drives: 2011 528
Forgive my ignorance but can anyone tell me the difference is between a mechanical LSD and a Torsen LSD?
Thank you
nogaroblues4 is offline   Reply With Quote
Old 10-29-2011, 04:34 PM   #135
madfast
Thank you
http://auto.howstuffworks.com/differential4.htm
Old 10-29-2011, 04:35 PM   #136
ryridesmotox
it's the same. I usually post in the lnf sections and war stories lol... What do you have?
Old 10-29-2011, 04:44 PM   #137
nogaroblues4
Drives: 2011 528
Still a little confused, The article states that a Torsen is a torque sensing mechanical diff. So what is the advantage of a non torque sensing diff?
Old 10-29-2011, 04:46 PM   #138
sfwg
<saturn most of my car friends have cobalt ss'
Old 10-29-2011, 04:49 PM   #139
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
If you lose 100% of traction on one drive wheel a torsen transfers 0 torque to the other wheel. This is rarely a problem though unless you like jumping the car a lot around corners or offroading. Maybe in extremely slick ice too.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-29-2011, 06:20 PM   #140
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Basically if you are in an extremely tight turn and lift a wheel, you won't get power until the wheel touches down again, similar to an open diff. As long as you have some traction on the wheel that is slipping it will transfer some percentage of the torque to the opposite wheel, meaning when you are powering out of a turn the power will shift to the outside wheel. You can "fake" it by pulling up the ebrake, not so much to lock up the wheels but enough to give some resitance for the diff to push against. A mechanical locking diff will actually sense differences between the shaft speeds and apply a certain amount of lock to try and equalize them, so it will still work if one wheel is lifted.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
brz review, fr-s review, fr-s reviews, ft-86 reviews, scion fr-s review, scion fr-s reviews, subaru brz review, subaru brz reviews, toyota ft-86 review, toyota ft-86 reviews, toyota ft86 review
First Spy Pics of Scion FR-S / Toyota FT-86 Production Test Mule! (Updated 5/17) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 495 08-14-2020 08:15 PM
Autocar's Toyota FT-86 / Scion FR-S First Drive Review Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 128 10-31-2011 04:57 PM
Scion FR-S Cover Article in new Road and Track Magazine Maxim Scion FR-S / Toyota 86 GT86 General Forum 314 08-30-2011 11:14 PM
Scion or Toyota ? 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2010 09:56 PM
Tell Toyota we don't need Scion FT-86 Dark Scion FR-S / Toyota 86 GT86 General Forum 28 10-15-2010 08:26 PM
