Old 12-24-2019, 02:00 PM   #127
bradyhuutch
bradyhuutch's Avatar
Drives: 2019 WRB BRZ PP
Looks like Enkei RPF1 18x8.5+35 clear without spacers, but I can't confirm this is a Performance Pack. Maybe the guys at Fitment Industries would be able to tell us.
https://www.fitmentindustries.com/wh...enkei-rpf1-trd
bradyhuutch is offline   Reply With Quote
Old 01-04-2020, 06:42 AM   #128
Mball19
Drives: Toyota 86 TRD/SE
Sparco Trofeo 17x7.5 +48 offset clear the Brembos.
Mball19 is offline   Reply With Quote
Old 01-04-2020, 07:14 AM   #129
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Prodrive GT1 18x7.5 ET 48 fit with naught a hair more .. probably less than 2 mm
Clutch Dog is offline   Reply With Quote
Old 01-12-2020, 04:43 AM   #130
Conti93
Conti93's Avatar
Drives: '02 Speedster n°586 - '23 GR86
Mak Rapide 8x18" ET35, lots of space:
Barracuda Karizzma 8x18" ET38, plenty of space:
Mak Veloce 7x17" ET48, doesn't fit without ~12,5mm spacers, depending on disc thickness at the hub:
Conti93 is offline   Reply With Quote
Old 01-18-2020, 07:32 PM   #131
Waffle
Drives: BRZ limited with performance packag
Hi, I'm wondering if anyone has fitted WedsSport RN-55M wheels on their BRZ PP? These will be the first set of wheels I get for my BRZ and want to make sure they will fit right without or with little other modifications.
Waffle is offline   Reply With Quote
Old 01-30-2020, 02:14 PM   #132
Chuckls
Moutain Runner
17x9+38 Rays 57CR. Might want a 1-2mm spacer if possible for the fronts.
Chuckls is offline   Reply With Quote
Old 03-01-2020, 08:34 PM   #133
doug1234
doug1234's Avatar
Drives: 2017 BRZ w/pp
Apex 17x9 ARC-8 et 42
Just installed the wheels with Maxxis VR-1 tire. Fix and look great. I have CSG Flex A coilovers camber -2.5 front and -2.0 rear. The ride height is the recommended height for the coilovers. Had more than 20 mm clearance between wheel and coilovers. This was measured by sticking my finger between the two with plenty of space to spare.
Sent from my Pixel 2 XL using Tapatalk
doug1234 is offline   Reply With Quote
Old 03-04-2020, 11:07 AM   #134
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
RS2 Wheels?
Originally Posted by mixxxx View Post
TRD forged 17x7.5+43
No spacers required
Are these the wheels supplied with the 2016 FRS RS2?
Muskoka800 is offline   Reply With Quote
Old 03-04-2020, 02:20 PM   #135
mixxxx
mixxxx's Avatar
Yes
mixxxx is offline   Reply With Quote
Old 03-26-2020, 05:15 AM   #136
Burkwa
Drives: 2012 toyota 86
Hi guys does anyone know if CE28NF 18x7.5 +43 will clear these brakes?
Burkwa is offline   Reply With Quote
Old 03-30-2020, 07:48 PM   #137
Masato-san
Drives: 2013 FRS whiteout
You can add Oz allegrita 17x8 + 48 to the list!
https://www.instagram.com/p/B-QEG9UH...=1hb1xnf5dr10a
Masato-san is offline   Reply With Quote
Old 04-04-2020, 02:07 AM   #138
Choerry
KPOP Stan
Choerry's Avatar
Drives: '19 86 TRD SE
Could probably add these to the list, as the 86 TRD SE uses the same brakes as the performance package.
Advan Racing TC4 - 18x9.5 +45
Option Lab R716 - 18x8.5 +40
AVID1 AV20 - 18x9.5 +38
XXR 527 - 17x9.75 +25
ESR Sr05 - 18x10.5 +22
Some other ones on FI:
Enkei Pf01 - 18x8.5 +45
Konig Ampliform - 17x9 +40
Work Meister S1 3p - 18x10.5 +14
Rays Engineering 57XTC - 18x9.5 +38
Gram Lights 57xtreme - 18x9.5 +35
JNC Jnc002 - 18x9.5 +35
Kansei Corsa - 18x9 +35
Enkei Pf05 - 18x9 +42
Choerry is offline   Reply With Quote
Old 04-04-2020, 02:34 AM   #139
Top Gun
Top Gun's Avatar
Drives: 2013 FRS, 2015 FRS Turbo
Does anyone know if Rota Titan 18x9.5 +38 will clear CTS-V brembo with STI 12.8" rotors? I want to do the retrofit BBK for the fronts.
Top Gun is offline   Reply With Quote
Old 04-06-2020, 12:31 PM   #140
pslater
Drives: 2017 Golf R
Which wheels clear 17+ BRZ Performance Package Brembos
TSW Interlagos 18x8 +35 fit. lots of clearance up front.
pslater is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
