Old 07-08-2018, 09:39 AM   #127
tomm.brz
Drives: brz 2017 hksv2
Expect you didnt posted 2+2 logs with same conditions to compare things in a good way
You posted an acceleration from a random speed to another random speed (which 90% of the people can t reach with a single geae because you are basically the only. One in this forum to have a longer FD rather than a shorter, FD that objectivelt sucks more torque compared to a shorter one)
And asked us to make the same log saying that your car feels like a 280hp car
Or am i wrong
The Following User Says Thank You to tomm.brz For This Useful Post:
Spuds (07-08-2018)
Old 07-08-2018, 02:54 PM   #128
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by Lantanafrs2 View Post
I would love to see acceleration numbers once you put the header on it. Weight loss you're talking about is worth 20 or so hp by itself.
I'm not a drag racer as I generally don't like to put hard launches on a clutch. Don't have a real accurate way of testing 0-60 but I suppose I could use some sort of GPS app just to get an idea.
Yeah old school rule of thumb was 100lb = 10hp. I have 234lbs lost so ~23hp gain along with the headers/tune over stock. In theory of course!
SuperTom is offline   Reply With Quote
Old 07-08-2018, 05:43 PM   #129
86TOYO2k17
Drives: 2017 toyota 86
GPS apps are pretty inaccurate/inconsistent unless you buy some type of external gps device specifically for testing. Personally, I think the best way to get the most accurate/consistent testing would be to film your speedometer and do a 40roll or 3500rpm in 3rd to whatever the top of third is to negate the traction and shift speed variables. Or at least a 5roll to 60+ to eliminate the traction variable.
Old 07-08-2018, 06:08 PM   #130
86TOYO2k17
Also doing some quick math. If a car is 2800lbs with 200hp = 14-1 ratio. Losing 100lbs makes it a 13.5-1 ratio or 1.037 better ratio. 200 x 1.037 = 207.4hp this is at the crank.
You’d have to do the equation yourself based on your base to current weight, as well as your baseline whp to new whp or baseline crank to new crank to get the exact hp equivalent ratios for weight reduction.
Old 07-08-2018, 07:11 PM   #131
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
My weight to power ratio is 12.1 compared to stock at 16.8.
I am measuring whp not crank hp. Its a very much different car when i drive both mine and my gf's stock brz.
Crank hp, weight to power ratio is 10.3 (mine) and stock is 13.8
Dr. BRZ is offline   Reply With Quote
Old 07-08-2018, 08:17 PM   #132
SuperTom
SuperTom's Avatar
I know you said you've done a lot of weight reduction as well do you have a list of things you've. Just curious in case I missed something that could be beneficial to my build.
That's what its all about weight to power. If you cant get anymore power go lighter
Old 07-08-2018, 10:16 PM   #133
Turbo
Drives: FR-S Turbo
I removed front and rear bumper beam and same time
I'm curious if you considered making your own light weight replacement?
I want to open up the lower grille to increase airflow through the rad and oil cooler, but when I pulled the grill out I found it's actually the bottom of the bumper beam is in the way blocking the airflow. Put it back together and figured I'd either TIG something up or FAB it out of carbon/fiberglass composite.
Turbo is offline   Reply With Quote
Old 07-08-2018, 10:23 PM   #134
SuperTom
SuperTom's Avatar
No I'm fine without them. Japan version of the car doesn't have them its a US 5mph thing
Originally Posted by Kostamojen View Post
Low speed collisions will probably cost more to repair, but bumper beams don't change how effective crumple zones are on a chassis in high speed accidents. Cars in Japan and other countries have had little to no bumper beams for quite a long time, the primary purpose for bumper beams in the US is to reduce insurance costs in those pesky 5mph tests.
Old 07-09-2018, 09:24 AM   #135
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Or am i wrong
Lol again the same arguments from the same people. I provided at that time a complete log file and anyone could compare whatever range of speeds he liked even with a shorter FD. Of course, you ignore that a file was posted and make again an argue for the sake of the argument. And the same discussion continued at that time even when I converted the data with a road dyno application to whp (which takes in account the FD, car weight etc.) just to make everyone's life easier, when I provided logs on 3rd gear instead of 2nd gear and so on ...
So, do you still want to be one of the fools over here and insist that weight reduction on non-rotation and most importantly rotational parts is useless, that it doesn't give the difference that some people think etc? It is your choice! At least let the others to share their experience.
The Following User Says Thank You to nikitopo For This Useful Post:
why? (07-11-2018)
Old 07-09-2018, 09:56 AM   #136
tomm.brz
I dont think anybody said weight reduction is useless. But everybody just said you are exagerating a lot with your statements, specifically about the pulleys, your expensive header, and your final drive and your out of sense opinion on how many hp your car has
Can you please link again the logs you are Talking about? This forum is highly dispersive at times and can t find them anymore, thanks
Old 07-09-2018, 11:11 AM   #137
https://careers.workopolis.com/advic...roblem-is-you/
humfrz (07-09-2018), Spuds (07-09-2018)
Old 07-09-2018, 01:19 PM   #138
humfrz
Oh, I just had to bookmark that one …
humfrz
Old 07-09-2018, 02:59 PM   #139
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You know how to find them and I won't waste any more the particular topic with this silly discussion. If your issue is my car or my mods, then you have a real problem with yourself.
Who said I am complaining about my job? Are you serious?
Old 07-09-2018, 03:09 PM   #140
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
http://www.ft86club.com/forums/showthread.php?t=127548
Also:
Understanding Fuel Trims ShadowReaper Software Tuning 13 04-01-2018 01:34 PM
Understanding Compressor Maps arthur93 Forced Induction 31 05-25-2017 10:49 AM
Understanding Oil tofurun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 06-10-2016 04:06 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 07:32 PM
Understanding/clarifying vendor qualifications mav1178 Site Announcements / Questions / Issues 21 03-18-2014 03:25 PM
