Old 08-01-2012, 03:33 AM   #127
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
Originally Posted by Moshpit37 View Post
But that will shift gears. Unless I'm missing something I'm pretty sure you get a gear shift every time you touch the paddles.
I'm pretty sure while in D you click paddle once an it shows the gear you are in then you click again to change gears. After a few seconds it goes back to D. I could be wrong. I'll try it again. The last few days I've been driving my Tacoma 4x4. I've been neglecting her since I bought the my FRS. That has been strange sitting so high and it handles way different.
Grateful Dave is offline   Reply With Quote
Old 08-01-2012, 03:52 AM   #128
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Nope. I checked on the way back to work and it definitely shifted as soon as I touched the downshift paddle.
Edit: Sorry for the thread jack. Let's get back on topic and if need be bring this to the discussion thread.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 08-01-2012, 05:08 AM   #129
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
The plastic in the inside gets scratched too easily, especially the door panels. Everyone knows what I'm talking about.
Style is offline   Reply With Quote
The Following 4 Users Say Thank You to Style For This Useful Post:
Hawaiian (08-01-2012), kramrle (08-04-2012), Laika (08-02-2012), n7011n (08-01-2012)
Old 08-01-2012, 09:30 AM   #130
kndonlee
I just posted my impressions. You should have a mod just delete any irrelevant posts, and edit the existing posts for continuity.
The only thing that should be in there are "Thanks" for the posts rather than the general, "please listen to my 2 cents dribble"
kndonlee is offline   Reply With Quote
Old 08-01-2012, 10:06 AM   #131
WRJad
Drives: 2013 Subaru BRZ
Subaru needs to improve their paint quality and painting process. My BRZ has numerous paint defects its not even funny (not sure how it made it past QC). Since the defects are at the rear of the car I try to not look at them, but they are there. I should raise a big stink over the defects but I don't want half the car repainted and have it not match.
WRJad is offline   Reply With Quote
Old 08-01-2012, 10:33 AM   #132
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
2013 Scion FR-S Auto Owner-
Transmission (Auto):
The only complaint I have, as most people know, is that I wish that the auto had a launch feature or was able to get off the line faster.
For those that seem to think the auto launches fine, Id suggest finding a friend with a manual to compare it against. You will see what I am talking about. It is the one thing that is causing the auto to be so slow compared to the manual.
I cant describe it and I wish that I had taken video of my track time when my friend and I went to the drag strip to see just how much of a difference there was between auto and manual.
After the initial launch and when the car got past the RPM where it lugged it seemed to keep up very well even though the manual was still pulling ever so slightly ahead.
This was run after run after run.
I feel adamant that if the auto was able to launch without having to lug up to speed that it would be the best damn auto on the market that is not a DSG. Other than that major flaw (in my opinion) the auto is amazing. Drool worthy.
I mean the launch of the auto is going to hurt a LOT of auto x times which is what I am planning on doing.
I dont care that the manual is faster. I expect it to be.
What I did not expect was my friend being able to run a 15.5 with a huge speaker box in the back along with all of the spare tire components while I was able to manage only a 16.4 at best with everything known to man stripped out of the back of the car.
I dont like comparing cars, I hate it. But I feel this example would best explain how disappointed I was with the times.
When you used to drive a 2008 Pontiac G5GT with 171 HP and 167 TQ and stock it ran a 16 flat with a slush box auto and weighed in at 2991 lbs with everything in it, its a little disheartening when your 2013 Scion FR-S runs a mediocre 16.5-16.7 with everything in it at 200 HP and 151 TQ and weighs in at 2800 lbs.
Again this is not because I care about the 1/4 mile times but because I was expecting no more than a 5 tenth of a second difference from auto to manual.
Yes, I am well aware that gearing as well as when that peak power is made makes a difference. But people with an auto can not launch at the right RPM range to allow the car to snap up and go like the manual. Instead we just chug along until we get to the right point.
Memphis is offline   Reply With Quote
The Following User Says Thank You to Memphis For This Useful Post:
Style (08-01-2012)
Old 08-01-2012, 10:36 AM   #133
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
BRZ Limited MT:
-Engine Performance (Feel, noises, etc)
Lacking low-RPM torque, really needs to be turbo-charged. DI chirp is just unacceptable.
-Exhaust Sound Performance (Sound Quality)
My preference would be to NOT pipe sound into the cabin, but I understand that some like to hear their cars more than I do
-Transmission (Performance, Quality)
Clutch engagement point should be moved inward toward the floor
-Tire Performance (Wear, Noise, Handling)
A car designed for superior handling should come with higher performance tires
-Interior Parts/Panels (Fitment, gap, deformation, etc)
The side extensions around the center control cluster were designed solely to torment people of height...if I had a dollar for every time I've drilled my knee hopping into the car without being careful, I'd be a wealthy man. Note that I'm 6'4".
-Unusual Interior Noise (Squeaking, rattling, etc and location)
There was a rhythmic whining coming from the right-front that I attributed to tire noise that seems to have subsided some. There is an intermittent soft thumping/rubbing sound that seems to come from the trunk at highway speeds for which I have yet to pin down a source.
-Front Seat Functionality
The seats are too firm to provide good comfort to a large range of passenger sizes and shapes. While the seats hold one in place nicely, they are a bit hard and cause me some sciatic nerve issues on longer drives. The passenger seat does this to my wife within minutes of getting in the car, hence she never rides with me. A slightly softer seating material would probably mitigate some of this, as would adding more seating adjustments. For me, as a taller driver, raising the seat front to provide thigh support would be wonderful. Providing some lumbar adjustment would be great for shorter drivers like my wife.
-Rear Seat Function (... troll question? haha)
Oxymoron?
-Exterior Parts/Panels (Fitment, Gap, Wheel/Tire Size, Design of Wheels, etc)
I hate the little Toyota dimpling of the hood around the front logo, it really detracts from the elegant lines of the car.
-Interior Function (Visor, Mirrors, etc)
Visors need a stiffer spring-rate, I can no longer tuck my wallet there without running the risk of it flying out.
-Audio Equipment Performance
Lack of a high-fidelity option is a minus, but then this has been a Subaru weakness for decades.
-Center Cluster Switch usability
Functional, but the layout doesn't imply significant amounts of development thought. Could use some cleaning up.
Stu baru is offline   Reply With Quote
Old 08-01-2012, 12:02 PM   #134
Style
LXXXVI
Style's Avatar
Doing a neutral drop would destroy the engine right? Just want to make sure lol
Old 08-01-2012, 04:08 PM   #135
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
FRS owner here
"I" feel that the door position locks could be spaced a bit better
i'm talking about those little grooves in the door hinge that lock the door in 3 seperate locations (barely open, middle, and fully open) I feel that the middle position in it's current state is too wide, ina lmost any normal parking situation it requires that no other car's are present if you park in the center of a standard parking space
and if there is a car, the other car has to be perfectly parked as well, if it is even an inch closer to your car, i am forced to be mindful of how far i open the door. I don't mind being cautious, but it is a pain because i never know if the "spring" force of the door might accidentally force it open and touch the other car or a wall
i know it may sound silly, but even like 2-3 degrees less of swing at the medium setting is all that i'm suggesting.
Old 08-01-2012, 08:36 PM   #136
xravexboix
xravexboix's Avatar
Drives: 12 Camry Hybrid on 19" RE30
Send a message via AIM to xravexboix
Done. I'll post up discussion topics once we're set.
http://instagram.com/p/NzcqIvtcQO/
xravexboix is offline   Reply With Quote
Old 08-01-2012, 10:15 PM   #137
mojojojo
mojojojo's Avatar
Drives: 2013 Scion FR-S (MT)
Scion FR-S and I know this is beating a dead horse, but the engine with the DI fuel system or whatever is making the cricket noise.
mojojojo is offline   Reply With Quote
Old 08-01-2012, 11:06 PM   #138
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
-Other Electronic Switch function/usability
Can they adjust the sensitivity of the Passenger seat belt sensor? Just putting my phone on the seat causes the alarm to beep.
|-Goku-| is offline   Reply With Quote
The Following User Says Thank You to |-Goku-| For This Useful Post:
djliquidsteele (08-04-2012)
Old 08-01-2012, 11:37 PM   #139
xravexboix
xravexboix's Avatar
BTW, please keep posting on any other things you may have. TMS/SOA/FHI are monitoring this thread.
I'll update the original post shortly with some feedback.
Old 08-01-2012, 11:49 PM   #140
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
There ought to be an option to automatically lock the doors at a certain speed for manual drivers, or when shifting from Park to Drive for automatic drivers. Conversely, the doors should unlock when the car is turned off for manual drivers, or when the shifter is moved from Drive to Park for automatic drivers. Some variant of this would be OK too.
Subie is offline   Reply With Quote
The Following 6 Users Say Thank You to Subie For This Useful Post:
elenien (08-18-2012), kgc (08-03-2012), kramrle (08-04-2012), rice_classic (08-05-2012), russv (08-03-2012), smbrm (08-02-2012)
Podcast Feedback dorkymork Off-Topic Lounge [WARNING: NO POLITICS] 1 10-26-2016 06:07 PM
Feedback Etiquette Calidrifter Site Announcements / Questions / Issues 0 06-22-2012 07:42 PM
Feedback: Exterior Color Preferences xravexboix Scion FR-S / Toyota 86 GT86 General Forum 75 09-23-2011 12:37 AM
Frostwire or Limewire...need feedback and suggestions Shevon Off-Topic Lounge [WARNING: NO POLITICS] 3 01-13-2011 11:08 AM
