#127 |
Drives: 2017 BRZ PP , 2005 Saab 97X
That said, in both the SE and XSE with the bigger wing, it needs some... less oem looking rims and some meat
style wise its good, but the tire/rim combo are cheap. Maybe toyota assumed it would be swapped out anyways? |
#128 | |
Senior gif poster
Drives: 2013 Asphalt FRS
I also in good conscious cannot put bigger wheels on the corolla than I have on my FRS. My plan at the moment though is to eventually get some RPF1s on the FRS, and then the FRS stock wheels go on the corolla. That's the trickle down part effect. This is the upper trim XSE model that does have the 18s I'm talking about: |
| The Following 2 Users Say Thank You to DandoX For This Useful Post: | Clutch Dog (04-24-2019), tjed147 (08-09-2019) |
#129 |
Senior gif poster
To add to my running review as I drive this car around more:
Something about this car that is interesting in terms of comparing it to the twins. The power is obviously less but the torque figure is about the same. The torque on the corolla is is 151lb-ft at 4,800 rpm. Which makes it feel like it has some grunt, but make no mistake it is not as fast as the twins, but in a straight line it really isn't as far off as you might think. In terms of handling the car drives really well for a hatchback but again the twins have spoiled me and although the corolla doesn't have tons of body roll, compared to the oem suspension on my '13 FRS it has more body roll than I would personally like. Also it does inspire some confidence but again not at the same degree as the twins, throwing it into a corner will net you typical fwd understeer, but the raw cornering grip isn't much to be impressed about, which the body roll doesn't exactly help. Also note this is on the 16 wheels. Although the performance is less than the twins as to be expected, it is very comfortable. The ride is better than the twins, it does a good job absorbing some serious bumps. The road noise isn't super quiet but if your used to a twin it is quiet. There isn't that much feedback from the clutch, that combined with the super quiet engine and muted exhaust I find myself checking the tac far more often as I can't as easily judge the revs by feel and sound alone (which is very easy in the twins as you know). |
#130 | |
Site Moderator
Drives: Supra
257-HP Toyota GR Corolla Turbocharged Hot Hatch Is Coming
https://www.caranddriver.com/news/a3...onfirmed-2022/
#131 |
GR Corolla
Well we've heard the rumors and now the mill has turned up a notch...
Courtesy of Car Sensor via The Drive we could get a 296 HP, AWD Corolla 5 door. Obviously it's all clickbait conjecture at this point, but that would certainly leave me feeling a bit better. ![]() I was bummed about them not giving us the GR Yaris but... if my math is correct, the GR Yaris has .091 HP per lb (257 HP/2822 LBS). The current Corolla 5 door weighs 3060 lbs, so if the GR version adds 100 lbs to the curb weight (which honestly, it probably won’t - the transmission will be heavier, but I suspect there will be weight savings elsewhere), it will still have .094 HP per lb. It could get all the way up to 3253 lbs and keep the same power to weight ratio as the Yaris. All that is to say, I’m suddenly a bit more excited for a GR Corolla. My FR-S will be 10 years old next year, so I might seriously consider a switch. |
#132 | |
So, it's not news.
Instagram: @spike.grc
| The Following 8 Users Say Thank You to spike021 For This Useful Post: | Captain Snooze (04-23-2021), KR-S (04-22-2021), PulsarBeeerz (04-23-2021), ScoobsMcGee (04-23-2021), Spuds (04-22-2021), strat61caster (04-23-2021), Tcoat (04-22-2021), weederr33 (04-23-2021) |
#133 |
So it's more news than we've had to date. Thanks for your input though.
#134 |
Because compromise ®
Drives: Red Herring
"Could Offer" is meaningless. Same as "might offer, might not offer", "possibly offer, possibly not offer".
From the article: "Could Offer", "might outperform", "alleged to", "possibly that", "claims to be". Yep, quality reporting right there.
#135 |
Only happy when it rains.
Drives: series.blue
No matter what they offer in the rest of the world, I would not put it past Toyota of North America to use the name and give us a normally aspirated 2.5 4 with front wheel drive.
| The Following 8 Users Say Thank You to why? For This Useful Post: | DarkPira7e (04-23-2021), dpfarr (04-24-2021), KR-S (04-23-2021), spike021 (04-23-2021), Spuds (04-23-2021), Tcoat (04-23-2021), Transport3r (04-23-2021), weederr33 (04-23-2021) |
#136 |
Drives: 17 Asphalt 86
Meh I have a feeling it'll be similar to the Mazda 3 turbo. A more or less standard corolla with a turbo.
#137 |
Sarcastic SOB
Considering Toyota has a significant stake in Subaru, that would be a stretch for the NA market. It could be the hatch STI they'll never make again.
I'd guess it will be like the Corolla S was but maybe some better running gear. I'm holding out for the GR MR2
#138 |
| The Following 8 Users Say Thank You to Tcoat For This Useful Post: | Irace86.2.0 (04-24-2021), KR-S (04-23-2021), PulsarBeeerz (04-23-2021), spike021 (04-23-2021), Spuds (04-23-2021), Transport3r (04-23-2021), wbradley (04-23-2021), why? (05-14-2021) |
#139 |
And some suspension tweaks, some seemingly random aero bits, and a badge.
| The Following User Says Thank You to Tcoat For This Useful Post: | spike021 (04-23-2021) |
#140 |
Pavement Grey
So like the 2006-7 Corolla XRS?
| '98 Toyota Corolla, $20,000 | FR-S2GT86 | Other Vehicles & General Automotive Discussions | 4 | 08-07-2021 12:23 AM |
| Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited | Busybee | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 02-24-2019 01:05 PM |
| 2000 Toyota Corolla Sedan (Witner beater) | FRSToyota86 | Canada Classifieds | 0 | 10-23-2014 12:00 PM |
| Toyota working on a sedan version of the 86/FR-S? Toyota Furia Concept | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 01-15-2013 12:45 AM |
| Official Photos of All-New 2014 Mazda3 Hatchback and Sedan Allegedly Leaked | vh_supra26 | Other Vehicles & General Automotive Discussions | 17 | 10-21-2012 12:14 AM |
