Old 05-28-2018, 10:15 PM   #127
dnieves
Drives: FR-S 10 Series
Originally Posted by 02.ACCORD.DUDE View Post
I'm at about 92,000 miles and have had no issues.
Up until this last servicing appointment when life got in the way I've been consistent with maintenance (purchased the car with 30,000 miles) - I did change spark plugs around 60,000, could have stretched it a bit longer I think.
For me the car is strictly a daily drive - and I think that'll be the key for you. If the car you're purchasing was heavily tracked or self-modded I'd consider other options as the wear / tear and potential for part failure could be greater than anticipated...
I bought my car used with a handful of cosmetic mods and spent the first few months undoing most of what the previous owner did. The last remaining vestige of their ownership is the car's exhaust - which while nice was installed somewhat shoddily and doesn't sit centered in the bumper cutouts (pisses me off to no end, I've had a few shops try to straighten it when I took the car in for repairs but the fix was always temporary).
edit:
Oh also forgot to mention that the clips on my side markers are toast... The driver side marker keeps popping out regardless of what double-sided tape I try to use to hold it in place
Speaking of toasted sidemarker clips, you can get replacements here: http://www.ft86speedfactory.com/oem-...l#.WwypkmaG86Y
dnieves is offline   Reply With Quote
The Following User Says Thank You to dnieves For This Useful Post:
02.ACCORD.DUDE (05-29-2018)
Old 05-29-2018, 12:10 AM   #128
Originally Posted by 86_888 View Post
You must do all highway miles to get to 188,00 kms on the original brake pads.
Interesting about the plugs too.
I'm in the same club as @Tcoat. Just short of 200,000K, original brake pads and rotors, original plugs, second set of tires. Mostly highway miles. I can tell no difference in performance and my gas mileage is pretty steady.
Of course, not that its in virtual print I probably wont make it home tomorrow.
Ultramaroon (08-17-2019)
Old 05-29-2018, 11:45 AM   #129
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
I actually did order a pair of these and ended up losing them again
The roads in Northern New Jersey are just pothole city... I'll probably order another pair at some point, but for now the double-sided tape is holding true...
02.ACCORD.DUDE is offline   Reply With Quote
Old 05-29-2018, 10:54 PM   #130
dnieves
How about putting a drop of gorilla glue (or epoxy) to keep the clips in place? Good luck.
Old 08-17-2019, 09:00 AM   #131
Timmygt
Drives: 2013 gt86 gts
Originally Posted by Chaetagnath View Post
I'm at 93,000 miles. I've replaced the clutch and just had to replace the rear wheel bearings. That's about it.
Replaced the clutch? Was it an upgrade or failing
Timmygt is offline   Reply With Quote
Old 08-22-2019, 03:04 PM   #132
Timmygt
These cars are epically reliable. My car still drives like it is brand new. And it's just about to tick over 200000 kms.
I have had the tob go. And some snapped wheel studs. But aside from that it's been epic. Just took it in for the fuel filter change, brake fluid flush, gearbox, diff oil change along with radiator flush. Everything seems to be a OK. The mechanic told me nothing is leaking, nothing is needing replacement. He did say the clutch take up point was a little high. But, that's it. Still drives like it's brand new. I am going to see if it can make it to 300000 now.
The Following 2 Users Say Thank You to Timmygt For This Useful Post:
Adam_L (04-30-2020), Feistyfrog (08-22-2019)
Old 08-22-2019, 07:32 PM   #133
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Are you still on the original plugs right now at 150,000+ miles? (edit: shit never mind, took another look at your owner journal) I'm already surprised they lasted twice as long as their change date.
The Following User Says Thank You to KR-S For This Useful Post:
Dadhawk (08-22-2019)
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
rom tuning for improved gas milage ganz954 Software Tuning 19 12-02-2014 11:08 AM
Does Turbo effect gas milage?? beesmiff07 Forced Induction 86 10-30-2014 11:25 PM
WTB: FRS/BRZ high milage cools20 Cars for Sale/Trade 0 10-13-2014 02:10 AM
Milage App. execoll Scion FR-S / Toyota 86 GT86 General Forum 11 09-14-2012 01:23 PM
