#127 |
Drives: '06 AM V8V Coupe
Wow okay I should be more careful about trusting Wikipedia. They say the 4GR-FSE had D4-S, but the Lexus website says it doesn't lol.
As for the 2GR, I can't find anything on the internet about known issues. Sounds like a nice engine to me. |
#128 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
1. no large aftermarket support 2. carbon build up on low mileage engines
#129 |
I thought the carbon buildup was on the 4GR engines...they have direct injection, but no port injection.
#130 | ||
Drives: N/A
The ones with port injection shouldn't have the carbon issues. Although I have actually seen some cases of carbon buildup on Port injection. And looky lexus IS specs. The DI only 2.5L(4GR?) gets 12.0 SCR while the D4-S 3.5L(2GR?) gets 11.8:1. People wanting a decent turbo engine will probably want <10.5:1 or so going off the Mazdaspeed3 setup. BTW, 0-60mph in <8 seconds for base $33k 3400lb sedan. whoo boy that's fast and affordable. Now I'm feeling particularly violent just thinking about all the people whining about this car being slow and ugly. I'm going to eat some dead animals/plants and then kill some sick people(L4D2) to vent my frustration.
#131 | |
MODERATOR-SAMA
port injection is only present are certain engine conditions. At mid-high RPMS Direct injection comes on only. Both D4-S engines and DI engines have carbon issues, while D4-S can see more milage before you have to get the heads serviced by lexus and is covered under warrentie, some owners have extended warrenties because of this. DI only engines especially turbocharged/supercharged equipped cars build up soot reallly quickly. I read somewhere that 400hp 2GR-FSE Supercharged variant found in Japans Toyota Mark X has a bad shelf life.
#132 |
From the other threads, I am fairly sure that port injection is on most of the time, it only goes off at near max. throttle for maximum torque. At other times it's a mix to make the distribution of fuel in the cylinder as even as possible, to save fuel/emissions since these engines run stoichiometric A/F ratios for emissions. At mid rpm if the throttle is partially closed this should still apply. Maybe someone else can correct me if I'm wrong...
Of course if you only drive a D4-S engine say, on the track, you're mostly using just the direct injector, and that would be a problem. @Allch Chcar what's up? I don't get the "whoa there cereal"... |
#133 | |
MODERATOR-SAMA
Its not entirely clear why they are getting carbon, but they do know that DI plays a major roll in it.
#134 | |||
Drives: N/A
. I will be monitoring my intake to the valves whenever I make the switch to DI. That goes on my list of things to monitor like o-rings... Quote:
. Just because they have port injected doesn't mean they still don't have carbon buildup issues. From personal experience. ![]() Quote:
Either that or these Lexus guys are not giving it enough throttle . This is why Rotaryheads recommend red lining once in awhile, it helps reduce carbon buildup, supposedly .
#135 |
professional smartass
Drives: 16 speed mountain bike...
I wonder if regular use of Seafoam would do anything to negate the carbon buildup.
#136 | |
![]() Wait I shouldn't be laughing if I am interested in someday buying a Toyota car with direct injection... |
#137 |
Drives: N/A
It would be a band-aid but it could work...
#138 | |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
>.> I redline my cars probably at least once every time I drive them... And yes... that's including the DD'er ![]() Only when they're up to proper operating temperatures though.
#139 |
Drives: N/A
We are discussing engine swaps in the D4-S thread and D4-S in the engine swap thread...
#140 |
Drives: Bugatti Veyron
![]() So... if someone were to put an EJ207 in this would it be able to keep up with a..... ![]() Cayman R 330hp 2855lbs $ 66,300 ![]() 1 Series M Coupe 335hp 3362lbs $46,135 FT-86 (EJ207) 304hp ~2555lbs ~$ 35,000 Sorry, I was daydreaming. Last edited by quik1987; 10-05-2011 at 08:14 PM. |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
| Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
