Old 09-11-2015, 09:10 PM   #127
JS + BRZ
Drives: 2010 MS3
My wife always laughs at it whenever it squeaks. LOL
JS + BRZ is offline   Reply With Quote
Old 09-20-2015, 04:00 PM   #128
DC2R
Drives: 2014 Scion FR-S
Just went to dealer. They had fixed before but this time they said to clean outside of window with Windex and then come back if that don't fix it
DC2R is offline   Reply With Quote
Old 09-28-2015, 10:35 AM   #129
FR-STY 86
FR-STY 86's Avatar
Drives:
Both of my windows squeal for up to 2 days after heavy rain or washing my car.
I wanted to take the TSB (S-SB-0009-14 : Outside Door Weatherstrip) into dealership, but it says it is for vehicles produced BEFORE the Production Change Effective VIN JF1ZNAA1#E8705465.
Mine is JF1ZNAA1#E970####.
So does this TSB not apply to my car? Suggestions?
Thanks
FR-STY 86 is offline   Reply With Quote
Old 09-28-2015, 10:43 AM   #130
Thanks
Take in in anyway. Mine was after the VINs and they did it no problem. Made a huge difference.
FR-STY 86 (09-29-2015)
Old 10-29-2015, 07:07 PM   #131
Agent 86
Drives: 2017 Cayman S
Originally Posted by Agent 86 View Post
The video posted above depicts exactly what was happening with my windows (both) when wet. My car is 11 months old, has about 5400 miles and lives in the garage when not driven.
Honestly, the squeaking sound was a bit embarrassing.
I figured the squeaking had to be caused by friction between the glass and the moulding since I was able to eliminate the squeaking by pulling the glass inward as I raised the glass. So, how do you reduce friction???
This is what I did...
1.) I cleaned the outside moulding strip with an old T-shirt and alcohol. I lowered the glass and then cleaned the moulding inside the door as far as my finger would reach along the entire length of the moulding.
2.) I used a chunk of carnauba past wax (Mothers) that I had laying around to completely coat the outer glass surface.
3.) I lowered and raised the windows a couple times to get wax on the moulding where it came into contact with the glass.
4.) Used a microfiber cloth to wipe off the wax the glass.
That's it!
It has been at least 3 months, many washes and some rain and still no squeak at all!!!
Quoting my own post.
So, 2 days ago we had rain. I lowered my passenger's side window and the squeaking sound was back. So, the wax application to the glass lasted a bit over 5 months.
I should also mention, I washed my car last Saturday using the soap in a more concentrated application to remove tree sap accumulated on my car from the parking space at work.
All in all, i think this solution is a win.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 11-17-2015, 06:36 PM   #132
ROADRACER
Drives: unlimited cheap build N/A track car
Just to chime in here...I have had my car to the dealer three times regarding this issue.
1. To get them to inspect and order the parts listed in the TSB.
2. To have the parts installed.(they didnt help the wet window skreech)
3. To have things re-adjusted to stop this terrible skreech.
After three trips and many hours waiting around the dealer I was told " this is as good as it gets".
After the first rain I discovered it skreeches as bad as it ever did. I hope the wax thing works, because Scion doesnt seem to have a solution or the motivation to provide one.
ROADRACER is offline   Reply With Quote
Old 12-03-2015, 08:20 AM   #133
Agent 86
It works! The squeaking is caused by friction. Try this, raise/lower the window while "gently" leaning the glass toward the interior of the car. The squeak goes away.
The wax reduces the friction between the glass and the trim to the point where there is no squeaking. For me the wax application lasted a long time.
What I don't know is if liquid wax would work or last as long. If you have wax on hand, give it a try. You have nothing to loose.
Old 01-05-2016, 05:08 PM   #134
PNW FRS
PNW FRS's Avatar
The waxing thing worked for me (so far...)
I was getting the loud squeak when lowering or raising the windows after a rain...
I tried the Carnuba wax procedure posted earlier in this thread.... and it has stopped the squeaking (so far...). Notable about this process is that once the window was down (with wax on it...) and I used the rag (with wax on it) to clean the inside of the window opening... the rag came out with a BUNCH of dirt, etc. on it.... so there was a lot of stuff that could have been rubbing against the window at various points along the width of the window.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PNW FRS For This Useful Post:
Sigh-on-Rice (01-05-2016), Tcoat (01-05-2016)
Old 02-13-2016, 05:58 PM   #135
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I took my FRS to the dealer for them to look at my wet window squeaking. I live in LA so it BARELY rains but I wash my car every week so I still get the squeaking windows.
They ordered weather strippings and window stabilizer bars. Car is still sitting at the dealer.
N1rve
Old 02-13-2016, 09:32 PM   #136
PNW FRS
PNW FRS's Avatar
If you mean there is a squeaking sound when you roll the window down or up -- that is, the noise is INSIDE the door -- then they can spray some lubricant down into a known area that dries out over time. I just had this done on my 2013 which developed this noise a month of two ago. It took two visits (applications) to stop the noise.
If you mean there is squeaking (friction/rubbing) noise when the top edge of the window rubs up on the weatherstripping.... then what the dealer is doing sounds appropriate.
2013 Asphalt / MT
Olympia, Washington
Old 02-14-2016, 01:48 AM   #137
N1rve
N1rve's Avatar
I am having them fix the squeaking noise when rolling up and down. I don't have the squeaking at the top edge.
N1rve
Old 02-14-2016, 07:26 PM   #138
PNW FRS
PNW FRS's Avatar
It's a "lubricant" fix... not a weatherstripping fix. If they want to do that in addition to the silicon they'll spray on the rollers inside the door... I guess that's their prerogative. I had to do that fix last year when the "window-top" friction starting causing some weird pinching deformation of the weatherstripping.
2013 Asphalt / MT
Olympia, Washington
Old 02-14-2016, 07:30 PM   #139
N1rve
N1rve's Avatar
Did you ever have your window stabilizer bars replaced? I don't recall anyone having those replaced.
N1rve
Old 02-14-2016, 07:32 PM   #140
Ultramaroon
not playing cards
Ultramaroon's Avatar
Does your window index 10mm, or 20mm? There's a TSB to replace both door switches of the earlier serials when it was discovered 20mm was excessive.
Pockmarks on windows? Dang Lad Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 09-27-2012 04:52 PM
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 11:11 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-22-2012 12:39 AM
Tinted Windows koolhawk CANADA 20 06-19-2012 08:27 PM
Windows 7 Theme ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 0 05-28-2011 04:27 AM
