Old 04-09-2022, 08:34 PM   #127
Calum
That Guy
Drives: 2013 asphalt FRS MT
It mostly just makes the rear more predictable IMO
The Following User Says Thank You to Calum For This Useful Post:
jeepmor (04-22-2022)
Old 04-11-2022, 01:55 AM   #128
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Originally Posted by Xed32 View Post
Getting a track alignment was one of the first things I did. The factory alignment was dangerous for my driving style. So much over-steer on off camber corners that some off-ramps terrified me. Thought it was something to do with falkens I had on my '16 brz or damage or something and got that stock aligned 3 times by different shops who told me it was fine. When I got the '20 brz and did more research I found it was that terrible factory alignment. Wen to 0 toe in front, slight toe in at rear, slightly less camber in the back and maxed out the 16mm camber bolts at the front. Car drives wonderfully now. Moving to the top hats and the traction mod are just extra enhancements to get it dialed as this car needs lots of front camber and the angle of the trailing arm is too severe for a true rear wheel sports car ( its an impreza part). Sliding the back out all the time isn't fun to me no matter how Toyota & Subaru describe it.
This is pretty much what I did, and why I did it, and I am also happy with how it turned out.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following User Says Thank You to JohnH For This Useful Post:
Old 04-22-2022, 11:22 PM   #129
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Oh man, now I'm chomping at the bit to get these put on. The extra power boost provides in these cars makes the stock setup a lot more twitchy.
I see less toe and more camber alignment notes. Anyone have any numbers to share? I have camber bolts up front already, and rear LCA arms and this MCA mod sitting on the bench. I'm taking notes on all this but don't have any numbers to go on.
Is there a thread on alignments and the numbers that I've missed. I have looked, but only find the more here, less there commentary. I don't mean to detract from the thread, but do see how it all ties together as a package for handling, not just bolt on magic.
jeepmor is offline   Reply With Quote
Old 04-23-2022, 01:12 AM   #130
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I recall my current settings being around 0.5-1mm toe out front and 1-1.5mm toe in rear.
My last alignment was done trackside at a shop run at the facility. I sort of just let the guy do what he wanted after giving him some guidelines on the car being daily etc.
Took the car out and made 3 separate adjustments to fine tune it.
I've also tried 0 toe front 1.5mm[1/16] toe rear, 3mm toe in rear[this was a misunderstanding via tech], 0 toe front and 0 toe rear.
I like having around 1.5mm toe in rear, and 0 toe front or touch of toe out.
If you want the front end more stable on highways stick with 0 toe front.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
jeepmor (04-23-2022), Racecomp Engineering (04-23-2022)
Old 04-23-2022, 01:35 PM   #131
jeepmor
This is the MCA traction mod thread, I won't hijack this off course with any more alignment questions. Thanks for input, but I'll do some reading and start a new thread on alignments if I have more questions.
Old 04-16-2023, 01:10 AM   #132
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Just wanted to followup on this thread. I tried getting the MCA traction mod, only to find out they were backordered, and shipping from Australia costs a ton. I ended up find the GP Sports traction mod due to this thread. It's unique due to the way it reinforces the subframe bushing, and includes a rear subframe bushing as well.
I really liked this mod more than I thought I would. Highly recommended. The rear suspension feels more compliant, with the same springs.
Wangspeed is offline   Reply With Quote
The Following 6 Users Say Thank You to Wangspeed For This Useful Post:
DocWalt (04-17-2023), MrSkubi (04-17-2023), MyHybridBurnsGasAndTires (04-16-2023), norcalpb (04-16-2023), RedReplicant (04-16-2023), yberther (04-25-2023)
Old 04-16-2023, 06:34 AM   #133
makinen
makinen's Avatar
Drives: Toyota 86
Have you noticed rear ride height changes?
Some reviews that I found in minkara told that rear springs should be changed to the strong ones.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
Old 04-16-2023, 10:13 AM   #134
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
No ride height change for me, but I'm also on pretty strong springs at 400F/400R.
Old 04-16-2023, 11:26 AM   #135
MConte05
Drives: 2023 GR86
GKTech has released something similar, at an extremely good price point.
https://us.gktech.com/fr-s-gr86-brz-...-mod-arm-combo
MConte05 is offline   Reply With Quote
The Following 2 Users Say Thank You to MConte05 For This Useful Post:
Old 04-16-2023, 01:54 PM   #136
norcalpb
norcalpb's Avatar
Did you read that this piece may lower rear ride height?
This is very cool! My only concern would be the survivability of those heim joints.
Old 04-16-2023, 11:20 PM   #137
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
I investigated that one. I don't like the direction that they mounted the spherical bearing at the subframe. It's going to max on alignment, which is really bad. Even in the pictures on their site, at full droop, you can see it either maxed or near max.
The Following User Says Thank You to Wangspeed For This Useful Post:
Old 04-17-2023, 12:52 AM   #138
makinen
makinen's Avatar
Drives: Toyota 86
Yes, several reviews mentioned.
https://ameblo.jp/naughty-bear/entry-12371533584.html
https://minkara.carview.co.jp/userid...2485/note.aspx
norcalpb (04-17-2023)
Old 04-17-2023, 01:06 PM   #139
norcalpb
norcalpb's Avatar
Dang it, this was my largest fear with this kind of mod as I just got a relatively expensive alignment done.
Old 04-17-2023, 01:46 PM   #140
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Shouldn’t effect ride height. You are just changing the pickup point for the trailing arm. It may require slightly stiffer spring rate. MCA even states there's doesn't effect alignment.
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 11:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 03:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 10:14 PM
