#127 |
Drives: '06 AM V8V Coupe
Wait Subaru has VVL (variable lift I'm assuming?)? When did this happen? :O I thought it was only BMW, Nissan (with the VQ only) and Toyota (on certain European engines and stuff only).
#128 | ||
Drives: N/A
While VVL has been around for a long time many companies didn't make it standard or equip it on all or most of their vehicles until recently. Subaru made VVL standard on all their vehicles by '05 I believe. |
#129 |
What does VVL stand for then? I'd think VVT is a better acronym. Toyota always added the i to VVT-i, so there's no confusion there.
Anyways. |
#130 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
There are a full range of methods that ultimately accomplish the same thing but to certain degrees. Vanos, Mivec, VVTLNeo, VVT-i, Vtec ...the list goes on..
#131 |
Okay I guess I just got confused by terminology, as most of the current methods have switchable cam lobes that vary intake valve operation in both lift and timing.
Speaking of which, I wonder why Valvematic is taking so long to reach the US...I don't think there are any engines with it over here are there? Nissan VVEL and BMW Valvetronic got here at the same time as the rest of the world. |
#132 | |
MODERATOR-SAMA
From my experience Dual Mivec has been the best system iv tested, its like Vtec on steroids. controling cam lift and timing on both intake and exhaust on all RPM ranges.
#133 |
professional smartass
Drives: 16 speed mountain bike...
That makes sense.
What good is sucking in more air if you can't get it back out?
#134 |
I don't think any Toyota engines don't have VVT-i (not all have dual VVT-i though maybe), Valvematic doesn't interfere with VVT-i, besides probably losing the second cam lobe and hydraulic actuator. Valvematic has the cam push a roller which is attached to a separate shaft, which is connected to a...I think I saw it called "finger follower" which actuates a second roller on a lever which actuates the valve. The camshaft timing can be adjusted independently.
They use the 1.6L 1ZR-FAE on the Lotus Elise base model in Europe...wonder why we Americans don't get that Guess it's not cost effective to give us 2 different engines, when we have the biggest market?
#135 |
Okay I just realized, Valvematic's extra shaft adds like an inch of height to the engine...guess the hopes of seeing it on the FT are pretty slim
The 1ZR-FAE is 34mm taller than the 2ZZ-GE, so on a boxer...that's going to be double that. 10mm stroke reduction, increased compression would cover only 1/3 of that extra height although maybe the engine being farther back helps.
#136 |
Turbo Mafia Presidente
Drives: U Mad?
Vvtl-i was on the GTS Celica, Dual vvt-I is on the new tC and Dual AVCS is on Subaru.
#137 |
Kuruma Otaku
Subaru also has AVLS, which is kind of like VTEC but only on one of the intake valves.
Because titanium. |
#138 | |
#139 | |
Kuruma Otaku
Vid that's been posted before: [u2b]RHNXbGGvOdc[/u2b]
Because titanium. |
#140 |
So Valvematic is the easiest system to understand out of all the variable lift systems. Nissan VVEL is some crazy wack stuff...
So it's actually pretty simple, the camshaft can be thought of as a "high performance cam" with maximum lift and duration. If this cam directly acted on the valves, you'd always have this profile and that would be bad for part load and low rpm operation. What valvematic has is 2 sets of levers (essentially, they have a lot of parts but they act as levers) between the cam and the valve. The first of these is directly actuated by the cam lobes, and always moves some fixed amount (determined by the cams). It has a second follower attached to the same shaft. The space between the follower and the cam-actuated roller is adjustable. The follower then actuates the second lever which actuates the valve itself. At low lift setting, the follower has some space between it and the second lever, so most of the distance it travels it doesn't touch the second lever, so the valve doesn't move. At high lift, the space between the follower and second lever is small, and the valve thus moves a lot more. So if you look at a lift vs. time graph, lower lift means you shift the curve down and zero out anything below 0, which gives you reduced duration as well. Combined with VVT-i, you can also horizontally shift the curve by some amount. http://www.autozine.org/technical_sc...ine/vvt_5.html That website has a good animation. EDIT: diagram, only VVEL is animated. So I was pointing out that the 1ZR-FAE has 34mm extra height compared to the 1ZZ-FE because of the second shaft. On a boxer this increase in height would be double that increase in width, so we won't be seeing it most likely If they reduce stroke to 75mm, and then increase compression ratio to say, 12:1, that would take off 32ish mm. If the width grows by a full 36mm, that would create some issues...and 75mm stroke is unlikely as people said. Rather disappointing since Valvematic reduces pumping loss by a ton (especially if the exhaust timing is right), and allows for better flowing ports.
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 01:44 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 12:35 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 12:30 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
