#127 |
I'm in a similar boat but with 1-2. Haven't had it happen inner normal acceleration in a long time but at higher RPMs it will do it once in a while. At first I thought I just fucked up my shift but I'm positive it's not me now
#128 | ||
Drives: BRZ, STI, GT350R, Supra, 987.2
If you do purchase another transmission, I'd be willing to go through your trans for a very reasonable price to try and learn what is going wrong with 5th gear synchro. I plan to do this to my trans when I install our stronger straight cut gearset. Quote:
Thanks, Eric |
#129 | |
#130 | ||
That Guy
Drives: 2013 asphalt FRS MT
What else do you have done? Quote:
I ran Motul for about a week before I dumped it. I'm guessing that fluid is great in a hot climate, but up here, even in near summer it was atrocious. Now I'm on a mixture of two Redline fluids (MT85 & 90) and it's working flawlessly. |
#131 | ||
That Guy
I ran Motul for about a week before I dumped it. I'm guessing that fluid is great in a hot climate, but up here it was atrocious. Now I'm on a mixture of two Redline fluids MT85 & 90. We went with the mixture after looking at the specs for the factory specs, and the Motul stuff. We were aiming for a low temp viscosity that was just a little less than factory, to help with the cold weather operation. I haven't had any troubles with shifting in anything from 5 degrees to 40. |
#132 | ||
Drives: 2013 FR-S Whiteout MT
When in doubt, throttle out!
#133 | |
Well, I'm located in Phoenix. Orange County isn't terribly far, we could tear it apart together in a day easily. PM me if interested. I has beer .Thanks, Eric |
#134 | |
#135 |
if youre going 80 and go down to 4th. You run out of revs quick after boosting a bit..
#136 |
#137 | |
That Guy
I agree with the others, that a clunky 5th isn't a likely indication of fluid being the problem. That said, a different fluid might be able to mask the problem, and extend the life of the wearing part.
| The Following User Says Thank You to Calum For This Useful Post: | FRS Johnny (10-05-2016) |
#138 |
Anyone use syncromesh before? Friend said to try it out. I remember that I'm using amsoil right now, and never really had a problem with motul before.
#139 |
Drives: '14 981CS, '99 NB1
I'm still a big fan of Honda green label MTF. It was designed for transmissions like ours that contain yellow metals. I used it exclusively in my old 400hp Hondas, and it's the OEM spec'd fluid for the S2000. It's not too expensive, I'd just change it with every other oil change and it kept the tranny shifting super smooth.
#140 |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I have an issue with both fourth and fifth grinding as well. My engine is stock. I too changed the fluid to Amsoil. I will ask the dealer about it under the manufacture warranty when they swap my side glass. I had minor issues from the beginning. One of the reasons why I haven't boosted yet is trying to figure out what to do with the gearbox first.
_ _ _ _ Last edited by Fenix; 10-05-2016 at 07:14 PM. |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 11:18 PM |
| Modular Hood Louver Kit - Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 276 | 07-08-2023 05:03 PM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 10:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 02:44 PM |
| ▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set | vividracing | Transmission and Driveline | 0 | 07-12-2016 02:32 PM |
