#15 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Are you talking about the chirping? I had them replace the high pressure fuel pump under warranty and it fixed the chirping. The problem is that the chirping will come back. Mine did in about 2000 miles with the new pump.
Also, you can change the tune back to stock when you bring the car in should you ever need to.
#16 | |
Drives: 2013 Asphalt FRS
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
| The Following User Says Thank You to NickFRS For This Useful Post: | ngabdala (05-08-2013) |
#17 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
So what's the solution? I know there's a thread about this issue but its way too long and when started reading it I couldn't find a straight answer (no solution???)
| The Following User Says Thank You to eurominican For This Useful Post: | ngabdala (05-08-2013) |
#18 |
AFAIK there is no permanent solution
| The Following User Says Thank You to ngabdala For This Useful Post: | eurominican (05-08-2013) |
#19 |
Just went back to the thread and that's the consensus. Hopefully the 2014 MY Will come with new fuel pump with no chirp noise and they will replace defective ones with new one bc this shit is annoying *crossing fingers*
#20 |
The crickets don't bother me. I just had the pump changed because I was afraid it would get worse. It hasn't.
#21 | |
#22 |
Drives: Pavement MT GR86
Hhhmmm I have a later build number 13 and with 2200 miles no crickets.... You can hear the injectors a little like on my friends evo x but nothing crazy
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | ngabdala (05-08-2013) |
#23 |
Drives: 89 240sx S13 SR20DET, 13 FR-S
Intake will not void out warranty..it depends what problem you may have with your car. Look up the Magnuson Warranty Act. The dealership has to provide proof that what you did to the car resulted in failure to whatever. IF your tranny goes out for example and you have a full CAI. This will not void out your warranty. The only thing for sure to void out warranties is turbo or supercharger but an intake exhaust coils any basic bolt ons should not void out warranty unless something goes wrong with lets say you put coils and your bushings go out..thats on you. But otherwise you should be all good.
as for intake..look into getting the full PERRIN CAI+inlet hose. Very good investment. You would spend about the same for a trd intake and all you get from a trd intake is a bigger box and a better filter for 400$ might as well go with the perrin. Deletes the sound resonator and cleans out your engine bay good. check em out. No tune required straight bolt on and no negative battery ecu reset like injen. True bolt on and CAI |
#24 | |
Drives: 2013 Whiteout Scion FR-S 6MT
#25 | |
Nope not yet with the mods. They're on order and I only notice the chirping when stopped.
#26 |
Drives: Scion FR-S 2013
Wow, that's a lot of info. Thanks guys. My chirping seems worse than the videos I've seen, so as soon as I get a chance, I'll be taking it in. The plug and play tune doesn't sound too bad. I'll be researching a bit more today if work stays slow. Thank goodness for industry-wide conferences; helps get car parts ordered, haha.
#27 | |
#28 | |
Drives: ex500r
| Quick Question | geb2391 | BRZ First-Gen (2012+) — General Topics | 2 | 04-08-2013 12:41 AM |
| Quick Question | akuhei | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 02-04-2013 10:29 PM |
| Quick Question??? | soontobrz | BRZ First-Gen (2012+) — General Topics | 12 | 12-16-2012 12:02 PM |
| Quick question.... | be6sti | Engine, Exhaust, Transmission | 8 | 11-04-2012 10:53 PM |
| New Member/ Quick question | sikse7en | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 11-28-2011 09:57 PM |
