go_a_way1, MisterSheep
Old 03-09-2013, 01:48 PM   #1065
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Originally Posted by Moshpit37 View Post
Not today, but 2 days ago I finished the install of my Eibach Pro Kit springs.
looking to put spring on mine too just use the stock shocks..any camber issues when installed the lowering springs?
looks good not to crazy low that will be hard to drive around with... how much drop? im looking for like a inch or 1.5 in
Old 03-09-2013, 02:01 PM   #1066
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
There is a little bit of negative camber now, especially in the front, but considering that the factory setup is almost exactly neutral, I view this as a welcome development. The Pro Kit is advertised as a 1" drop, which is about as low as you want to go with the stock struts. Anything more and you need aftermarket struts, and that isn't worth the money for me. This is just a temporary stop-gap for me until I can afford air bags anyways.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following User Says Thank You to Moshpit37 For This Useful Post:
marky (03-09-2013)
Old 03-09-2013, 03:17 PM   #1067
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Perrin inlet tube. FIRST MOD!!!
Chimpo is offline   Reply With Quote
Old 03-09-2013, 08:17 PM   #1068
roddy
roddy's Avatar
Drives: '13 Ultramarine
Drove it.
Old 03-09-2013, 10:41 PM   #1069
marky
marky's Avatar
going to dip my front lip like i see you guys doing looks good also will help on rock chips...
do you guys let the dip dry then peel it off ? or peel the masking tape off while the dip is still wet so its wont stick to the masking tape causing it to pull it off not making a straight line..
also how many coats and applying clear dip gloss ? i have one can left and its like a little under half way empty..
thanks
Old 03-09-2013, 11:49 PM   #1070
whataboutbob
AutoX-10/10ths every run
AutoX'd it at El Toro CA.
Build thread:Here
Old 03-10-2013, 12:06 AM   #1071
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
installed the jdm knee pads and now I am waiting for my works ABM axelback
oso_25 is offline   Reply With Quote
Old 03-10-2013, 12:56 AM   #1072
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
Broke 400 miles and installed the shark fin antenna! (now on to the diffuser, spoiler, springs, mudguards, DRLs....)
Captain_Awesome_Pants is offline   Reply With Quote
Old 03-10-2013, 01:38 AM   #1073
KriSD21
KriSD21's Avatar
Drives: Ultramarine Scion FR-S
thanks
i let the plastidip dry on the masking tape. 3-4 coats. use a long piece of tape instead of a bunch of little pieces so you have a straight line. use one hand to peel while the other hand is on the plastidipped part, so you guide it. not sure about the clear dip because i prefer the matte look. good luck =]
KriSD21 is offline   Reply With Quote
The Following User Says Thank You to KriSD21 For This Useful Post:
marky (03-10-2013)
Old 03-10-2013, 03:27 AM   #1074
ImTurtle
ImTurtle's Avatar
Drives: WHITEOUT SCION FRS
Picked mine up today!
ImTurtle is offline   Reply With Quote
Old 03-10-2013, 03:36 AM   #1075
suaveflooder
Congrats! You will love her! Thankfully, you picked the fastest color
suaveflooder is offline   Reply With Quote
Old 03-10-2013, 03:39 AM   #1076
ImTurtle
ImTurtle's Avatar
Since I'm a turtle I'll need the fastest color :happy0180:
Old 03-10-2013, 03:43 AM   #1077
suaveflooder
lol
Old 03-10-2013, 04:01 AM   #1078
Jlin
Drives: FRS
i hope you didn't pick it up with 160+ miles on it!
Jlin is offline   Reply With Quote
