Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-06-2012, 10:23 PM | #1 |
Drives: BRZ DGM
Which camber plates are you running?
Those who are running kw's, which camber plates are you using?
08-08-2012, 04:23 PM | #2 |
Drives: BRZ DGM
guess everyone is using stock stuff idk
08-08-2012, 04:32 PM | #3 |
Vorschlag has camber plates available. Others are using the Whiteline Com-C mounts instead of camber plates. The plates uses on the older Imprezas are compatible with the car so take your pick.
08-08-2012, 10:18 PM | #4 |
Drives: BRZ DGM
Which year imprezas?
08-09-2012, 12:06 AM | #5 |
Drives: 2014 Widebody Cosworth FR-S
The front plates from the 93-07 Imprezas should fit the front of the BRZ without an issue. We just installed the Whiteline Comp C upper mounts and set them to give max caster and camber, and we are loving it so far. Really seems to help with steering input and feel, and the added camber is always nice as well
Thanks, Rick |
08-09-2012, 09:02 AM | #6 | |
Drives: Peugeot 106 XSi
08-09-2012, 09:57 AM | #7 | |
- Andrew |
08-09-2012, 10:06 AM | #8 |
Andrew - so the holes are oriented like in a "GD/GG", not GC?
08-09-2012, 10:25 AM | #9 |
Track Junkie
Drives: Faster than the Stig!
Im using vorschlag they make a sweet product.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
08-09-2012, 11:34 AM | #10 |
Nice! I like that they are already positioned for max caster. They also look thick enough that the plate doesn't bend over time. I don't know how many Cusco, TEIN and HKS camber plates I've seen that are no longer adjustable because the plate has bent over time and you can no longer move the strut back and forth.
08-09-2012, 06:10 PM | #11 |
Drives: BRZ DGM
08-10-2012, 12:20 AM | #12 | |
Thanks, Rick |
08-10-2012, 08:53 PM | #13 |
The Following 3 Users Say Thank You to vividracing For This Useful Post: |
08-10-2012, 09:34 PM | #14 |
Drives: CBS BRZ Limited
The Following User Says Thank You to schtebie For This Useful Post: | vividracing (08-11-2012) |
Similar Threads | ||||
Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 06:51 PM |
Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 10:09 PM |
Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 10:30 AM |
CUSTOM PLATES OR REGUALR PLATES? | Koomoo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-21-2012 09:38 PM |
