Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-12-2024, 12:42 PM | #1 |
Drives: Subaru BRZ
Engine rattle when AC turns on
Hello everyone! Hope all is doing well,
I have a small concern regarding my 2013 Subaru brz manual transmission I have a rattling sound coming from the engine bay every time my AC compressor turns on. It's like something is lose, The sound goes away if the ac compressor turns off, or if I press on the clutch pedal, also the sound goes away if I shift the shift knob from left to right (neutral position). here is a video for your reference. https://www.youtube.com/shorts/2XHeeVqwcj4 Thank you for your time reading this and I hope you can help me. Note: I recently replace my throw out bearing and clutch. flywheel is still stock, I think? I bought the car used |
05-12-2024, 01:52 PM | #2 |
Drives: 2018 BRZ
Sounds like normal transmission input shaft chatter due to elevated RPM when the AC compressor is engaged. Do you have any stiffer transmission mount bushings and inserts? These amplify the noise.
Depressing the clutch disconnects the engine from the input shaft, stopping it from spinning and thus not making these noises. Moving the shifter puts some pressure on the forks which might also quiet it down. |
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | jamestemperante (05-12-2024), tomm.brz (05-12-2024) |
05-12-2024, 03:37 PM | #3 |
Drives: Subaru BRZ
I think transmission mount is still stock. The rattle comes when I'm not pressing the clutch pedal, when I press on the clutch, the rattle goes away.
05-12-2024, 05:04 PM | #4 |
Drives: brz 2017 hksv2
it s still the throw out bearing. Even the newer one is loud i ve changed FOUR of them, all installed by certified subaru techs (not a scammy shitty garage but people who already rebuilt many different brz's) all of them lasted super silent like 15 minutes maybe less
Then all of them started chirping at idle when clutch not engaged ignore it. |
The Following User Says Thank You to tomm.brz For This Useful Post: | jamestemperante (05-13-2024) |
05-12-2024, 07:54 PM | #5 | |
extra what?
I didn't hear any difference until the fan started. All you're capturing there is wind noise. Make a good recording of the difference you hear between clutch engaged/disengaged. ...inside the cabin with windows closed.
The Following User Says Thank You to Ultramaroon For This Useful Post: | jamestemperante (05-13-2024) |
05-16-2024, 08:50 AM | #6 |
Master Collaborator
Or it could be something worse:
This came out of a Dodge Caravan with less than 100K miles on it. It made the same noises as you are describing...AND...still started and ran! Only difference is this had an automatic transmission. Stranger things have been found. |
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post: |
05-21-2024, 12:37 PM | #7 |
Drives: Subaru BRZ
I'll try to get another video out of it. for the past few days. rattle is a bit less noticable. It usually loud when I use the car during the day when temp are hotter. I live here in the Philippines.
06-02-2024, 01:59 PM | #8 |
Drives: 2013 Scion FRS
Did you swap out with a light-weight flywheel? Mine rattles now because of that. I'd reckon its either the flywheel or throw-out bearing. My TOB took a shit at around 50k miles, so if you haven't changed yours yet, it's probably time.
ScreamingElectron - SnakeShit |
The Following User Says Thank You to riboyster For This Useful Post: | jamestemperante (06-05-2024) |
06-05-2024, 07:38 PM | #9 |
Drives: Subaru BRZ
I don't know if my car has an aftermarket flywheel. Bought my car used @ 42k KM.
06-05-2024, 11:56 PM | #10 |
Drives: 2015 Subaru BRZ Series.Blue #709
Sounds normal to me. It could be the OEM front pipe or over-pipe heatshield that might be rattling whenever the A/C is turned on. I had that happen before when I was all stock.
07-26-2024, 04:39 PM | #11 |
Drives: Subaru BRZ
Hello guys sorry for the late reply.
Here is another video of the rattle, I hope you can hear it, rattle goes away when I press on the clutch. https://www.youtube.com/shorts/CtrJgbTc6W8 |
07-27-2024, 02:29 AM | #12 |
Do you have lightweight flywheel or pulleys?
The Following 2 Users Say Thank You to gpvecchi For This Useful Post: | jamestemperante (07-31-2024) |
07-31-2024, 04:41 PM | #13 |
Drives: Subaru BRZ
I'm not sure if I have a light flywheel, I bought the car used. I recently changed my TOB and clutch
07-31-2024, 04:45 PM | #14 |
Drives: Subaru BRZ
attached here is a more clear sound / video of the rattle. Pls excuse my toe nails tho. lol |
Similar Threads | ||||
Engine rattle, drivers side engine bay. | MikeMont | Issues | Warranty | Recalls / TSB | 2 | 01-24-2020 10:27 PM |
Ticking/rattling after engine install, turns into...? | Alfrz91 | Engine, Exhaust, Transmission | 0 | 10-01-2019 01:18 AM |
EBC stays on for awhile when engine turns off | brosifSmith | Software Tuning | 3 | 06-03-2019 01:43 PM |
Engine rattle | MacJunkie | AFRICA | 12 | 04-01-2015 07:12 AM |
Moving in neutral....Engine turns off? | deedz | Issues | Warranty | Recalls / TSB | 23 | 04-23-2013 09:23 PM |
