12-19-2023, 09:26 PM | #1877 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I had a battery in a phone die once
12-20-2023, 06:16 AM | #1878 |
Drives: 2013 frs red
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Irace86.2.0 (12-20-2023) |
12-20-2023, 07:32 PM | #1879 |
Drives: Q5 + BRZ + M796
I upgraded my prior MacBook Pro (mid-2010 edition) with a Samsung SSD, and I upped the ram from 4g to 16g, which extended it's life for several more years before I passed it onto my wife when I bought a new model. Apparently that year had battery swelling issues, which began in 2019 unbeknownst to me, and it became obvious this year, when it couldn't charge and began lifting the trackpad. It made it thirteen years, as a high-use item--not bad.
Most of my iPhones have started throttling around two years, but never did they entirely bite the dust or refused to last a good chunk of the day, but these batteries see heavy use (several hours in the day) and fast charging at least once a day, plus night charging. This would be like driving a car more than just hours because car batteries are proportionally so big. This would be like driving 350 miles and fast charging all the time. Most people don't do that. The average person will trickle charge the battery at home to top off the 35 miles they drove, or they will wait ten days between charges, and in that case they will charge 35 times in a year, which is much different than 365 phones charges. If a phone battery lasts over a thousand charge cycles in several years before its performance and "range" suffers then a car battery could last 28 years. Really rough math because it would depend on the battery chemistry, discharge and recharge rate, usage, weather, etc, but phones are a heavy use item, so their batteries see a lot of abuse. For reference, lithium iron phosphate batteries have near zero fire risk, are cheap, are plentiful, are good for most driver's basic needs, are good at charging, not the best battery range, but will last 2000-3000 cycles, with the best case scenarios lasting 10,000 cycles. Those best case scenarios are grandma drivers who recharge at home using 120-220v low amp charge rates, who live in LA, California climates, who only charges from 20% to 80%. For that example, if 20%-80% represented 150 miles of range with 30 miles per day, that would be 5 days per cycle, so 73 cycles in a year, so that would be 136 years worth of cycles. It would be 27 years if the battery only lasted 2000 cycles.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (12-20-2023) |
12-27-2023, 11:18 PM | #1880 |
The Dictater
Drives: '13 Red Scion FRS
Not sure where to put this, so here it is lol. Just some thoughts...
So I actually visited a Lucid dealership today. First time sitting in the Air [midrange whatever it's called]. Super nice interior and looks great in the lighter colors, even white. Didn't have time to go for a drive but got to play around with the controls a bit. Not really a fan of things like lights and wipers being on a touchscreen, but otherwise everything was in just the right place to reach. Cabin is large with plenty of leg and headroom, but there isn't a ton of trunk/frunk space. Rear seats do fold flat for more cargo room though. I didn't like the glass roof thing on the Model X I checked out once, but it's implementation on the Air is pretty cool. Seats were excellent and had all the adjustability I could want, including extended thigh support which I've used before in another car and are nice to have on long drives. Zero pressure salesman, though it might have helped that I was the only non-employee there. We just chatted about the car and such.
Also: "Build Thread" |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Irace86.2.0 (12-28-2023), Lantanafrs2 (12-28-2023) |
01-15-2024, 06:07 PM | #1881 | |
I thought this was worthy of a double post...
So apparently Musk was right that the US has all the lithium we would ever need. Just one area of California to be exact.
The Salton Sea has even more lithium than previously thought, new report finds https://www.latimes.com/environment/...-boiling-point Quote:
https://www.cnbc.com/2022/05/04/the-...t-lithium.html Also, Microsoft's AI analyzed 32 million materials in 80 hours to come up with a battery that would be ideal in price, availability and performance that is a sodium-lithium hybrid with other proprietary, undisclosed materials. Clearly AI has a large roll to play in accelerating science and technology in all types of fields. https://www.theverge.com/24027031/mi...ry-material-ai
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (01-16-2024), WolfpackS2k (01-18-2024) |
01-16-2024, 03:57 PM | #1882 |
1st86 Driver!
Some more info on Hertz dumping their Teslas. It was the units they were using with Uber and other ride sharing companies that apparently were getting abused.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (01-16-2024), Wally86 (01-17-2024) |
01-18-2024, 09:32 AM | #1883 | |
Drives: '12 C63 P31, '23 GRC
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
01-18-2024, 10:00 AM | #1884 |
1st86 Driver!
Well, the green wackos, as you call them, are also driving EV adoption so there may be some compromise there.
01-18-2024, 10:27 AM | #1885 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
01-18-2024, 10:32 AM | #1886 | |
Pavement Grey
Up here in Oilberta, we have companies wanting to mine some natural resources from the rocky mountains...and the government will let them because our provincial government is a bunch of mini-trump oil loving non-greenie morons. The approval delays and start delays are due to a large majority of the population against it. |
01-18-2024, 11:35 AM | #1887 | |
1st86 Driver!
Of course, given that I'm now an EV owner I may be classified as a green wacko, so there's that.
01-18-2024, 02:24 PM | #1888 | |
Pavement Grey
like put down ICE, EV can do no wrong, "just deal with it" is the the acceptable way to deal with EV shenanigans, FOR THE ENVIRONMENT!!!! even if you arent, CHEAP EV's EXIST! ITS CALED A CHEVY BOLT!!!" |
The Following User Says Thank You to Sasquachulator For This Useful Post: | Dadhawk (01-18-2024) |
01-18-2024, 03:31 PM | #1889 |
^this is why DadHawk is not. lol
01-18-2024, 04:38 PM | #1890 |
Pavement Grey
Similar Threads | ||||
Tcoat banned? | Hotrodheart | Off-Topic Lounge [WARNING: NO POLITICS] | 95 | 07-06-2019 01:46 AM |
Does anyone know why pansontw got banned? | Soloside | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 10-26-2018 04:20 AM |
Got banned from gf's complex | jdmblood | Other Vehicles & General Automotive Discussions | 11 | 07-12-2015 12:46 PM |
Why have so many users been banned? | xuimod | Site Announcements / Questions / Issues | 9 | 03-08-2015 02:23 PM |
Banned Toyota GT 86 Advert Banned | Nevermore | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 11-16-2012 07:27 PM |
