01-20-2023, 10:49 PM | #1485 |
chicken tonight
Nope
What's your A-surface, there? Looks almost like parchment, or vellum paper.
01-20-2023, 11:08 PM | #1486 | |
What you are seeing is the resin core that I used to get the angles and creases up the side right. The inside of the doors was paneled so that saved me a pile of structural building.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
01-20-2023, 11:20 PM | #1487 |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (01-21-2023) |
01-21-2023, 12:55 AM | #1488 |
The Dictater
Drives: '13 Red Scion FRS
Not one of mine, but my friend painted this guy for D&D. It came out really damn good so I wanted to share. I wish I had a better camera (or better photography skills) phone pics don't really do it justice. I've got a few of my own coming up.
Also: "Build Thread" |
The Following 5 Users Say Thank You to Spuds For This Useful Post: | Dadhawk (01-21-2023), NoHaveMSG (01-21-2023), soundman98 (01-21-2023), Tcoat (01-21-2023), x808drifter (01-21-2023) |
01-21-2023, 09:03 AM | #1489 |
My grandson is 3d printing a bunch of these and asked if I would paint them. It will be yet another venture into the unknown for me.
01-21-2023, 11:13 AM | #1490 | |
The Dictater
I don't use it, but that's mostly because I'm stubborn.
01-21-2023, 01:01 PM | #1491 |
Had to look up the term. Yep pretty much how I do most of my figures but with far far more different colours than green and brown.
The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (01-21-2023) |
01-21-2023, 03:36 PM | #1492 |
1st86 Driver!
Were you ever able to get it to do a nose stand?
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
01-21-2023, 04:39 PM | #1493 |
Not really. It was more a thing for the pickup version than the van. The extra body weight in the rear made big difference even in stock form.
Mine also had the whole drivetrain including the heavy C6 tranny and 9" rear end from a 69 Fairlane adding weight to the rear. The 351 has to sit further back than the stock six so when all added up the distribution was way different than the pickup. It also had the benefit that even with the rear jacked up my COG was considerably lower than stock so I didn't have to slow to a snails pace on curves. Still probably like the 4 foot mark but still "better".
01-22-2023, 08:00 PM | #1494 |
I have doors. The hinges are a tad ovescale but they are more to hang the doors on in the open position so it isn't too obvious. The closing part of the deal is just a bonus. Once all black you will hardly see then anyway.
The doors were made by skinning over the cut out resin parts with very thin styrene and the hinges are the Lindbergh kit parts for the front doors of the Dodge. They fit better than the pictures make them look and will need some tweaking after paint anyway. The doors are not wrinkled like they look here that is a trick of the smudged marker ink and the resin showing through the styrene. This is how it will be displayed. The inside of these doors was really easy to model since the structure was covered with paneling and the latch mech is all hidden. The outer lips are all scale thickness.
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (01-22-2023), NoHaveMSG (01-22-2023), soundman98 (01-22-2023), Spuds (01-23-2023), Ultramaroon (01-23-2023) |
01-23-2023, 12:15 AM | #1495 |
chicken tonight
That's brilliant! Closeups of the hinges, please.
01-23-2023, 07:52 AM | #1496 |
Well not that brilliant and sort of lazy really. Without getting really fancy with folded brass and tiny pins there was no way to duplicate the bends in the hinges to get them to function with the curves and distances required while keeping them scale sized. Since I do not have the materials nor skills to deal with brass it had to be materials I had on hand.
I experimented with styrene rod and tube but it just wasn't strong enough. Would have been fine and even scale in appearance if I was to just glue it all together with the doors open but there was no way they were going to close. Then I tried just using different tape (masking, duct and aluminium) but again to get anything small enough it just wouldn't stand up. I was about to give up on the opening idea when I remembered that the base kit had opening doors. Although a little large they were strong enough and as well as opening and closing gave me the ability or removing the doors completely when showing the interior. The bottom parts with the eyes were inserted and superglued into slots cut into the resin body. The parts with the posts were cut off the larger piece and glued directly on to the styrene door skin. Very strong and stable but lift right off. I will take some close ups tonight.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (01-23-2023), Ultramaroon (01-23-2023) |
01-23-2023, 09:07 PM | #1497 |
Here you go. Simple and effective.
Will virtually disappear under a coat or two of paint.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (01-23-2023) |
01-23-2023, 10:13 PM | #1498 |
chicken tonight
Experience and passion showing clearly.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (01-25-2023) |
Similar Threads | ||||
TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
