#15 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I'm not suggesting they lied. It could have been a product pulled from the wrong shelf, a product returned to the wrong shelf, something like that. Even so, the last 4 cars I have had tinted with standard tint and keyless entry/push start have never had a problem.
Suggestions were on other forums for other cars but the solutions ranged from waiting a few days (something got wet and needs to dry out) to removing the tint. This is going to sound dumb but did you put anything in the rear wing window or bottom left of the back window like a decal, stuffed animal on the deck lid - anything like that? Were any other services installed even if not at the same time? |
| The Following User Says Thank You to 2020BRZtS For This Useful Post: | CelicaJoe (02-18-2022) |
#16 | |
#17 |
I wish I had a solution but it's now out of my limited knowledge space. You could try a handful of different batteries in the fob. As @Tcoat mentioned you never know how long they have been on the shelf. When you push a button on the fob does it light up?
#18 | ||
If changing the battery a couple of times (to rule it out) then I am baffled. Maybe try the second fob?
#19 | ||
Edit: also can’t thank you guys enough for the help |
| The Following User Says Thank You to CelicaJoe For This Useful Post: | Tcoat (02-19-2022) |
#20 |
Dismember
Drives: 2013 Red Scion FR-S
Unplug the battery. Hold down the brake pedal for 10 seconds to drain. Sit the car for an hour just to be sure. Plug it all back in. Try again.
#21 |
#22 |
Ended up being the ignition switch!
| The Following 4 Users Say Thank You to CelicaJoe For This Useful Post: |
#23 |
Bringing the thread back with an update: fob stopped working again. Brought to Subaru and here’s what they’re thinking.
They noticed a bad accident on the car fax. Happened in 2017, lost control and car spun hitting a bunch of wooden posts. Driver side curtain and seat airbag deployed. Had the airbag module reset by myairbags, replaced the driver side seat and curtain airbag. I cannot remember if I replaced the seatbelt. Looking back at old records I don’t think I did, but it’s possible. Subaru thinks it could be the wiring harness (quoted me $3k for the repair, part is also on back order until may. She thinks because the ignition switch plugs into that main harness, possibly it’s shorting it out. They tested the switch in another car and said it works fine. They suggested taking the car to Toyota due to the alarm system being made by Toyota and seeing if they have any insight to potentially avoid such an expensive repair. Never imagined this could be related to an accident from 5 years ago, anyone have any input? |
#24 |
ProCrastinationConsultant
i have heard of airbag deployment burning up wires/connectors. though the scenario's i've heard of were all burned up airbag-specific connectors/wires.
wiring harnesses are not fun to replace. if that was the case, could also try looking into locating a junkyard car that was rear-ended or something that you could get the harness out of.
#25 | |
#26 |
anything's possible.
most likely only if there was a physical wire breakage, and that broken portion chaffed against another wire to cause the damage. you are in florida, so it's possible that the heat from the airbag deployment in the wires affected other wires, and then reduced the insulation thickness that the repeated heat/cool cycles of the florida heat did it in the rest of the way. i just find it weird that they're only speculating that it's the harness because 'the button works in another car'-- should be able to test for that with an ohm meter at both ends of the harness-- both continuity across individual wires(should be near-zero), and also resistance between wires(should be near-infinite).
#27 | |
#28 |
Drives: Car
Just out of curiosity, do you have anything plugged into the center console. The Keyless access receiver is right by the shifter. I have seen Inductive phone chargers and other electronic device wires around the console cause exactly what you're dealing with.
One BRZ had a dash cam cig plug that was made so bad it was causing so much interference the keyless access wouldn't start. Unplugged it, started, plug back in, wouldn't start. I would try and eliminate any aftermarket anything near the center console, or even remove the console and make sure the keyless receiver isn't damaged or partially plugged in.
| The Following User Says Thank You to BlkTrax For This Useful Post: | soundman98 (03-12-2022) |
| What'd it cost to get your windows tinted? | Series.Ru | NY / NJ / CT / PA | 21 | 08-26-2014 11:55 PM |
| Scion fr-s Tinted windows | Scionshaun | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 05-14-2013 12:28 PM |
| Got my windows tinted! | BryanGT | Northwest | 2 | 03-07-2013 05:51 PM |
| Finally tinted my windows and.... | TheChopShop | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-22-2012 12:54 AM |
| Tinted Windows | koolhawk | CANADA | 20 | 06-19-2012 08:27 PM |
