Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-15-2022, 02:13 PM | #1 |
Drives: White brz
Hello everyone. New here. With a clutch question.
how are y'all doing today . New here . Long time lurker. Got my first brz and couldn't be more stoked. Mainly using it as my daily. Manual to keep it interesting . I've noticed on cold starts the car shifts fine but say I go on a long weekend drive it starts locking me out of gears. I can't get in to first from a stop. Or almost any gear. Usually 3rd will let me in then I have to go back and hit first. I've only had the car for 3 or do months and I feel like maybe I got sold a car with a problem. Any help or advice would be helpful. Thank you
01-15-2022, 02:45 PM | #2 |
ProCrastinationConsultant
how are you using the clutch and gears?
so you come up to a stoplight. you were in 4th. of course clutch in, do you go to neutral? row back down through the gears? do you sit on the clutch for the duration of the stop light, or only clutch-in again when the light goes green? while sitting at the light, have you tried clutching out for a second to spin up the transmission and re-try 1st? i've found if i roll to a stop in another gear, and then sit on the clutch(if i'm expecting it to be a short light), i'll sometimes have a similar issue getting into 1st, but only sometimes. as you, i'll either find another gear that will go in(usually 2nd goes in fine at that point) to move the syncro's and it'll mesh with 1st then, or i'll also just drop back to neutral, clutch-out for a second to spin the input shaft slightly, and it'll usually mesh again as it ought to in 1st.
01-15-2022, 02:48 PM | #3 |
Drives: Scion FR-S 10 Series
Do you know if it has a aftermarket clutch?
01-15-2022, 03:28 PM | #4 | |
Drives: White brz
01-15-2022, 03:29 PM | #5 |
Sounds like transmission oil viscosity issue when hot. Change transmission oil first. Lots of posts and even more opinions on what to use, do some research. I ended up at Motul 75W140 to keep similar to what you are describing happening when coming off the track after 20 min. We rarely get below freezing so have no issues when cold.
The Following 2 Users Say Thank You to Grady For This Useful Post: | humfrz (01-15-2022), soundman98 (01-15-2022) |
01-15-2022, 03:32 PM | #6 |
Drives: White brz
01-15-2022, 04:08 PM | #7 | |
Drives: White brz
01-15-2022, 04:11 PM | #8 |
yep, also sounds like you need to get the car out a little more to better diagnose it.
01-15-2022, 06:44 PM | #9 | |
01-18-2022, 02:10 PM | #10 |
Drives: Scion FR-S Series 10 #2462
1. Check your clutch pedal engagement point. If it's too low you will have to bury the pedal to the floorboard to get the gear to select.
2. Is it hard to get into reverse as well? This might help.
. 3. Change your transmission fluid. In fact, change all your fluids for a nice fresh start. GOOD LUCK! |
The Following User Says Thank You to MJones_RB For This Useful Post: | soundman98 (01-18-2022) |
01-23-2022, 05:32 PM | #11 |
Drives: White brz
Hell yea. Thanks again everyone
The Following User Says Thank You to BeeraReZ For This Useful Post: | soundman98 (01-23-2022) |
Similar Threads | ||||
Clutch question | Tracer29 | Engine, Exhaust, Transmission | 5 | 11-06-2021 01:59 AM |
Yet another clutch question? | StlBrz | Issues | Warranty | Recalls / TSB | 8 | 07-08-2018 09:19 PM |
Clutch cylinder question | ARTBRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 05-24-2018 02:38 PM |
Question about the clutch/TOB | Super Dave | Engine, Exhaust, Transmission | 27 | 06-07-2016 11:16 PM |
Question regarding the clutch | Frs x3 | Engine, Exhaust, Transmission | 1 | 12-02-2014 09:13 AM |
