Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
2nd gen vs 1st gen Subaru OEM part numbers - comparison
I've been digging through the suspension parts diagrams for the 2nd gen cars and thought I'd post some notes. Some things are the same, some things are different, some things need more research.
I will do my best to keep this updated and hopefully will have some of these parts in hand soon. ![]() Interesting things so far: 1. New rear top mounts. They MIGHT transfer over just fine but 2nd gen rear top mount part number is not listed as fitting 1st gen. Front top mount is also a new number but is listed as fitting 1st gen. Front upper spring perch is same 1st vs 2nd gen as are the upper spring pad things (front and rear). 2. There are 2 different rear springs listed and I'm not sure why. Both are listed for manual and auto. Not clear if right vs left. 3. New rear lower control arm is a new part number and is NOT listed as fitting 1st gen. The numbers match 2015 to 2020 chassis WRX and STI. They likely will still fit, and aftermarket adjustable arms are generally the same part for WRX/STI and BRZ. 4. Different front control arms, possibly due to new aluminum uprights? Listed as not fitting 1st gen. ![]() ![]() Obviously that's not EVERYTHING. Will add more later. And sorry Toyota folks, I'm just more familiar with the Subaru parts resources. Most parts should cross over from BRZ to GR86 but we do know the springs and swaybars are different. Please do note that these part numbers may (and often do) change and you should double check before ordering anything online or from your dealership. - Andrew |
The Following 18 Users Say Thank You to Racecomp Engineering For This Useful Post: | Bonburner (11-24-2021), Code Monkey (11-23-2021), dragoontwo (11-23-2021), fableluke (11-24-2021), finch1750 (12-02-2021), FrickingReallySlow (11-23-2021), Jdmjunkie (11-23-2021), Jianlun (02-27-2022), Kiske (11-24-2021), marco_mc22 (11-23-2021), MrSkubi (11-25-2021), nathand (11-23-2021), RToyo86 (11-23-2021), Spankopotomous (12-13-2021), Stonehorsw (11-24-2021), timurrrr (01-04-2022), Yoshoobaroo (11-23-2021), ZDan (11-23-2021) |
#2 |
Drives: Toyota 86
Do you guys already have one in your shop?
#3 |
#4 |
Also, I didn't add this but 2nd gen front brake calipers and rotors use same part numbers as 1st gen non-brembo. That was expected, but we wanted to be sure piston sizes or something not obvious didn't change.
Rear calipers are the same as well. Had some trouble with rear rotor part numbers, likely the same though. I did NOT check any other brake part numbers. - Andrew Last edited by Racecomp Engineering; 12-09-2021 at 12:25 PM. |
#5 |
I’d be interested to know if, that even though the front control arm part numbers are different, if they will still fit and be an “upgrade” for the 13-20 cars.
Considering the large and small bushings are the same (ball joints aren’t sold separately anymore iirc), I would guess it would fit. |
#6 | |
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | norcalpb (11-23-2021) |
#7 | |
It sucks not knowing if “CC” means the pickup points have changed, or if it’s just a stronger, revised version. Still debating buying them for the hell of it. I have 170k on my current FLCAs so they are in a different condition than new. I get creaks when they flex. |
The Following User Says Thank You to norcalpb For This Useful Post: | Racecomp Engineering (11-23-2021) |
#8 | |
Drives: Scion FR-S 10 Series
https://minkara.carview.co.jp/smart/...4954/note.aspx |
The Following User Says Thank You to Jdmjunkie For This Useful Post: | Racecomp Engineering (11-23-2021) |
#9 | |
![]() Looks like the ball joint is mounted more inwards on the new hubs…beginning to doubt the arms are the same. |
#10 |
Drives: 13 SWP BRZ
#11 |
Drives: 2013 frs
I wonder if the part number for the subframe is different. While the part number is different for the rear LCA i am pretty sure it's the same lenght. So I wonder where the extra .4" of rear track width is coming from.
#12 |
Drives: 22 BRZ limited
You could go to the Subaru parts website and check it out.
The Following User Says Thank You to dragoontwo For This Useful Post: | Adamf220 (12-14-2021) |
Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors | vlad128 | BRZ First-Gen (2012+) -- General Topics | 7 | 06-29-2018 04:05 PM |
Part numbers or part diagram? | pacemkr | Engine, Exhaust, Transmission | 6 | 08-22-2016 01:44 PM |
Canadian specific Subaru BRZ part numbers | boomslang | BRZ First-Gen (2012+) -- General Topics | 0 | 07-28-2014 06:29 PM |
How do I get JDM part numbers? | InstantNoodles | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-09-2012 04:29 PM |
Subaru part numbers for stock brake rotors? | blalor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 06-28-2012 02:31 PM |
