Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-16-2021, 03:51 PM | #15 |
義理チョコ
In your clip, I hear two different sounds. Does it click as you press the pedal, or only upon release?
Also, when you release the pedal, does it not make the sound if you slowly engage the clutch to spin up the input shaft? I ask because, if this sound is from dumping the clutch while in neutral, yeah, that's a normal knock in the transmission from harshly spinning it up through the slack.
07-16-2021, 03:57 PM | #16 | |
Drives: 2020 BRZ/86, 2020 BMW 330i
07-16-2021, 04:00 PM | #17 | |
義理チョコ
https://www.ft86club.com/forums/showthread.php?t=77390
The Following User Says Thank You to Ultramaroon For This Useful Post: | Arthur-A (07-16-2021) |
07-16-2021, 04:03 PM | #18 | |
07-16-2021, 07:00 PM | #19 | |
義理チョコ
Oh! Also, if your clutch pedal bottoms out with a metallic click, the cheap crappy bumper fell apart. I replaced mine with a piece of that adhesive-backed felt years ago. Haven't had to touch it since.
07-16-2021, 08:43 PM | #20 | |
Found an old video with the same noise. People in the comments say it's normal. |
The Following User Says Thank You to Arthur-A For This Useful Post: | Ultramaroon (07-17-2021) |
07-17-2021, 01:46 AM | #21 | |
義理チョコ
Yup. They all do that. It's not even the clutch that's making noise. It's gear lash. Worth discussing in detail.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Arthur-A (07-17-2021) |
08-19-2021, 03:29 AM | #22 |
Drives: 10Series 0945
It’s normal just like the inconsistent jerky 1-2 shifts. You know what’s not normal the way my dashboard rattles and buzzes over harsh roads.
08-25-2021, 12:32 AM | #23 |
Drives: 2017 subaru brz
@Arthur-A Curious if the dealership ended up just saying it's normal and sent you off? I'm pretty sure my car does this too and it is very annoying. Almost feels like my overall clutch system is loose especially when you are trying to navigate parking lots in slow speeds and engagement just clanks and you can feel it.
08-25-2021, 02:17 AM | #24 | |
08-25-2021, 03:43 PM | #25 |
Similar Threads | ||||
Clutch pedal loud squeak | Neekowahhhh | Issues | Warranty | Recalls / TSB | 616 | 06-06-2022 01:47 PM |
Transmission noise when clutch pedal released. | Oxyg3n | Issues | Warranty | Recalls / TSB | 12 | 02-05-2021 12:26 PM |
Loud Clunk while driving | Flame9020 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-23-2018 09:28 PM |
Loud clunk from rear of car | tennisfreak | Issues | Warranty | Recalls / TSB | 14 | 11-26-2014 12:55 PM |
Loud pop/clunk under braking. | Panda Grahams | Issues | Warranty | Recalls / TSB | 2 | 07-26-2013 03:13 PM |
