#43 | |
Drives: 13 BRZ
If you're talking about the structure above the radiator its mostly gone. It's main purpose was support for the factory hood latch and the hood but with aftermarket hood latches on the sides of the hood it isn't really even necessary. It is only there to support the hood/bumper seal.
Thanks!! |
#44 | |
Drives: Q5 + BRZ + M796
There are ways to legally swap a car, but it isn’t easy.
#45 |
Probably, arguably, one of the cleanest, home-built swaps I have seen. Nice work.
![]() You said earlier you got the motor from a race team you worked for. What is your background, career, etc? I’m seeing a car hoist and equipment that looks like you are not in a personal/home garage, but people have all sorts of things in their garages, so I could be mistaken. Just curious. Again, nice work.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | kask2_6.0 (03-30-2021) |
#46 | |
Drives: 13 BRZ
Needed a new project... LS3 soon!
Thanks! I’m an automotive engineer and mainly specialize in testing and development. And do some fabrication work on the side as a hobby. I wish this was my garage but thankfully I had a friend who was kind enough to let me tie up his lift for a bit. It really is an impressive shop that he has at his house. Sent from my iPhone using Tapatalk Last edited by kask2_6.0; 03-30-2021 at 02:53 PM. |
| The Following User Says Thank You to kask2_6.0 For This Useful Post: | Irace86.2.0 (03-31-2021) |
#48 |
Drives: Whiteout '13
so clean and awesome build kask2, wondering how did you get the hood pins part of the headlight attachments? makes it look so fricking good jejeje, If you can " shine some light" for me when i do mine on how you made yours would be amazing!!!
Thanks, again cleanest engine bay ever! |
#49 | |
It's very simple, thread the bolt through the hole with a nut... |
#50 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Is the support beam across the front where the intake goes completely gone or relocated?
#51 | |
Drives: 13 BRZ
The vertical piece that holds the factory hood latch is completely gone. The piece that goes above the radiator is still there but most of it is cut away for the intake to pass through. Right now it is really only holding the hood/bumper seal in place. The hood is very solid with just the aerocatch latches on the sides. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to kask2_6.0 For This Useful Post: | B T (04-15-2021) |
#52 |
Might I ask what the total cost is? Dropping even an LS1 into my FRS would be a dream come true for me.
#53 | |
Drives: 13 BRZ
I haven’t added it up because I’d rather not know ![]() The biggest cost factor is going to be what you decide to do with electronics. This was obviously on the pricier end with the motec ecu and aim pdm. But if you use a GM ecu, factory dash, etc. it would be a lot cheaper. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to kask2_6.0 For This Useful Post: | Riftur (04-16-2021) |
#54 |
Actively learning
Drives: 2013 FRS US MT
Awesome build! Can’t wait to hear it!!
| The Following User Says Thank You to brianbui23 For This Useful Post: | kask2_6.0 (04-20-2021) |
#55 |
Drives: 13 BRZ
Got it on the dyno this weekend for tuning and it went surprisingly smoothly. You always run into something unexpected with a new build but I only had a couple of minor issues. The throttle body was occasionally going into limp mode due to a mismatch of throttle command an throttle position. The throttle position sensor in the throttle body is the issue. I’m thinking the throttle body I bought on eBay is actually a counterfeit so I ordered a new one. That should hopefully solve the issue. The only other small issue I had is that the sight tube on the coolant tank was starting to melt a bit. I will have to use a different material.
This weekend I will swap the throttle body, change the sight tube, insulate the headers, and start designing mounts to swap fans to spal high output units (VA01-AP90/LL-66A). I currently have slim spal fans (VA10-AP70/LL-61A) but they are struggling to keep up while idling. It looks like I will have plenty of clearance for the higher powered fans. I had no overheating issues at all with the car on the dyno for the entire day with the help of the fans in front of the car. Highway driving is staying steady around 195F. Video: https://www.instagram.com/p/CN5jsVMg...=1kvkkhj4dkobf ![]() ![]()
| The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post: |
#56 | |
Drives: 16' BRZ
Crazy build!! Thanks for sharing.
| What is needed for | Aluma007 | Engine, Exhaust, Transmission | 9 | 11-25-2018 03:20 PM |
| Electric Power Steering Adjustment Project - Help Needed | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 12-07-2015 08:34 PM |
| Logged Track Time Datasets Needed for my Web Project! :) | Zamyatin | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-11-2015 02:59 PM |
| HELP NEEDED!!!! | sklimo | Issues | Warranty | Recalls / TSB | 26 | 06-14-2013 12:48 PM |
| MOD's Needed. Help Please! | GT-ROKIN | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-06-2012 02:18 AM |
