Old 06-12-2020, 12:46 PM   #267
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '17 BRZ, '24 CX-50
JDL 4-2-1 EL header
Originally Posted by solidONE View Post
IT is odd that the torqu tapers off sharply on that dyno. Maybe timing is being pulled at 6400rpms.
It’s certainly possible. For reference; here’s my dyno from earlier in the thread. Unfortunately this was only a 7100rpm run but the torque holds on pretty well, with a slight taper past 6750 but not as steep of a fall-off.
OnPoint Dyno’s Dynapack reads very similarly to the CSG Dynapack (that is to say, low) based on the numbers I’ve seen from both.
JBezugs is offline   Reply With Quote
Old 06-16-2020, 08:39 AM   #268
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by Code Monkey View Post
@TMF, are you still on this exhaust? My tune is a road racing tune as well.
Now ya'll have me concerned, I don't know why I didn't see the torque completely falling off on the graph. That was a 5th gear pull, not sure that should make a difference though, although it is a lot of strain on the engine.
And yes, I'm still on the same exhaust setup (JDL 4-2-1 EL header, JDL overpipe, JDL catless frontpipe w/ single resonator, Tanabe Concept G catback).
Might need to follow up with my tuner on that.
Originally Posted by Celica00 View Post
Jeez @TMF when you went into that turn going 125MPH, I just about had a heart attack vicariously. What brakes are you using?
Haha yea, that turn is a hair raiser.
OEM brakes, Carbotech XP12 pads in the front, XP8 in the rear. I don't see a reason to upgrade brakes on this car other than reducing consumables. I am on Hoosier R7's as well, so that helps too
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
The Following User Says Thank You to TMF For This Useful Post:
Code Monkey (06-16-2020)
Old 06-16-2020, 08:42 AM   #269
TMF
TMF's Avatar
Drives: '14 FRS TT5
I'm assuming that is on pump gas and not E85, right? My torque curve looks similar on my pump gas dyno. https://www.ft86club.com/forums/show...&postcount=162
Still curious what is going on with the E85 graph though.
Old 06-16-2020, 10:06 AM   #270
JBezugs
Good Job Subaru!
JBezugs's Avatar
Yep, that dyno graph is on 94 octane. I'm also running the stock over pipe and front pipe.
I'd be curious as well, the torque fall off is earlier than normal and quite significant.
Old 10-13-2020, 01:31 PM   #271
Hades
Hades's Avatar
Drives: 2013 Scion FRS
I don't recall if I posted my dyno numbers after I went to E85, but here are my numbers.
You'll probably say, "these look low!" and "there's no comparison!", which are both accurate statements. But the one constant here is that these dyno runs were conducted in compliance with NASA's dyno testing procedures, which usually read low.
Nice torque curve!
I'm assuming that is the 93 dyno. I'm thinking with these headers I can get to ~190whp avg. with e85. This would give me more WHP for competition and not need to run a wing (I'm not sure which way would be faster, but I've read a lot saying > HP is better than the aero in these classes).
Hades is offline   Reply With Quote
Old 10-13-2020, 10:17 PM   #272
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by Hades View Post
Nice torque curve!
Mine latest graph was E85. Are you looking at classing with NASA? If so, with E85, full exhaust, etc you'll end up around 183 avg hp.
Old 10-13-2020, 11:27 PM   #273
Hades
Hades's Avatar
Ah, thanks. So similar to all the other headers on the market. The torque curve is still good, though. It sounds like there's really not any headers that can do ~180whp avg. on 91/93 with NASA corrections (maybe ace but doubtful).
Old 10-14-2020, 12:58 AM   #274
PulsarBeeerz
Drives: JRSC BRZ SOLD
949 Racing ran the Ace 350 and the JDL 4-2-1, but stuck with the JDL because it had a similar power band to ACE with less drop off at 7000+.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Hades (10-14-2020)
Old 10-14-2020, 02:15 AM   #275
CSG Mike
CSG Mike's Avatar
They also spent a lot more time tuning the JDL!
Solid header.
TommyW (10-14-2020)
Old 10-14-2020, 03:33 PM   #276
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Solid header.
Let's say they spent a lot more time tuning the ACE and got it within the margin of error of the JDL, is there any reason to buy the now way more expensive ACE350 over the JDL 4-2-1?
This is a genuine question, because between the higher price, the near requirement of buying motor mounts, and the need for some clearancing, it doesn’t make too much sense to me.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 10-14-2020, 04:22 PM   #277
CSG Mike
CSG Mike's Avatar
With equally top shelf tunes, the Ace still makes more power over a wider powerband, and also weighs less, so when you want the absolute best, yes.
Many folks will spend the difference on the JDL 4-2-1 and call it a day, and still have fantastic results.
I believe 949 already had a pre-existing relationship with JDL (JDL makes fantastic Miata headers as well), and used the Ace as a stop-gap until their 4-2-1 arrived.
CSG has both the JDL 4-2-1 and Ace in their catalog, and *tries* to stock both, but both are almost always backordered.
Old 10-14-2020, 04:33 PM   #278
PulsarBeeerz
So I wouldn't be doing my due diligence without asking for proof of that claim. I remember a JDL 4-1 vs 350 dyno and confusion of a JDL UEL as a 4-2-1 dyno. Still hoping to see a comparison of the JDL vs ACE. Not trying to press you or anything but as neither header is what this community would consider inexpensive at $1400-2K gotta know all the info. lol
Goingnowherefast (10-14-2020)
Old 10-14-2020, 04:57 PM   #279
Goingnowherefast
Gotcha. Thanks for the reply. It's definitely an interesting conversation to have since I think most will agree that the ACE and the JDL are probably the best headers on the market today.
The engineer in me also says we could use some data to substantiate this claims.
Old 10-14-2020, 05:05 PM   #280
CSG Mike
CSG Mike's Avatar
One day, someone will fund some dyno time and purchase both headers to back to back test on the same dyno!
I would do it the same way i purchasd 5 ace headers for my own testing, but I'm turbo now, and the 4-2-1 came out after i boosted, so it's not really viable for me at the moment.
Any volunteers?
I bet if someone local purchased both and a tune, CSG may comp the dyno time for the sake of comparison.
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
